Back in January I took my truck into the dealer to have a minor start-up squeal/chirp investigated.  I knew it was the belt because I could see lots of black rubber belt "dust" all over the front of the engine behind the belt.  I could also mist a little bit of water on the belt while the engine was running and the sound would go away temporarily.  The technician determined it was a bad idler pulley so he replaced it but the belt was on backorder so he just reinstalled the same belt.  The squeal/chirp immediately returned.  I know these belts are one-time use only since they are stretch fit so I insisted on a new one.  They ordered a new belt and it has finally come in.  I'm just waiting on them to let me know when I can bring the truck by to have the tech slap it on real quick.
My concern is that there is a lot of the same black rubber belt dust on the engine again.  Could this all be caused by the "used" belt slipping on the pulleys?  Or is there an issue with alignment and/or another bad pulley?
Ours was almost as bad as yours, and the belt started to go bad around 6300 miles. There was belt dust on the front of the motor similar to what you have pictured. They replaced the serpentine belt, idler pulley, and A/C belt. The truck is about to roll over 12,000 miles and while I see some of the same wear occurring again, I don't have a squeak like I did before yet; ours only squeaked/chirped rhythmically when it was cold for the first few minutes.
My guess is there may be some kind of alignment issue going on or something has a bad bearing, but it's hard to say. They didn't say anything about anything else being amiss when they replaced our belts, but I'm sure they had their finest apprentice on the job and they were not thorough enough to check the alternator or water pump, or the state of the crank pulley. I really hate that they didn't put traditional belt tensioners on these engines and part of me feel like it's a design flaw. It also makes it way more difficult to change a belt in an emergency situation.
Our other vehicle, a 2019 Mini Countryman with only about 12,600 miles, has essentially no belt wear and it looks brand new, while our truck already has been through one set of belts and an idler pulley in less mileage. The hilarious part is the truck's manual says it's a 150,000 mile service interval on the belts. HA.
I agree with your sentiments.  The A/C belt looks flawless and new.  You can see it in the background of my picture - the markings/words on the back are still very clear and legible.  To me, this indicates no amount of slippage or wear.  The alternator/water pump belt on the other hand...
The back of that belt is completely devoid of any markings/words and you can see the wear on it.
Right, which makes me think it must be the water pump pulley because the alternator, idler, and crank pulleys contact the ribbed side of the belt, so it's the only one touching the back of the belt. Maybe the cooling fans blast rain and road debris directly at it and cause it to slip when the weather is nasty? These trucks have active aero shutters, though, so you'd think that wouldn't be an issue.
On a side note, if anyone knows of a better-than-OEM serpentine belt upgrade for the L84 5.3 engines, I'm all ears and am certainly down to try it.
I've been saying it for quite some time now -- At least 1 of the pulleys is misaligned from the factory.  5.3s and 6.2s are having the same problem, but I hear more about squeaking from the 6.2 owners on this forum than the 5.3s.  With that said, my dealer has only applied some dry lubricant per GM instructions.  It did quiet down the squeaking a little.  I'm still on the same belt my truck came with, and I'm at about 23,500 miles.  It seems that if you let it wear down a bit it'll quiet right up, and there's been no other issues with the belt.  A proper shim job, or proper aligning of the pulleys, would avoid this problem, but GM doesn't care.  There is a business term "satisficing".  It clearly applies here.
1 hour ago, lapoolboy said:
I don't think a pulley misalignment issue would be eating up the BACK of the belt though, right?
I think it's possible given the back of the belt is the contact surface for 1 pulley.  I'm no expert.  It's just a thought.  If the pulley isn't running parallel to the belt I could see some wear given the belt contacts over 180° of the pulley at all times.
Edited by Transient
I'm surprised that's not a trim package at this point: The Satificer
I'm also surprised that your dealer put anything on the belt as you're not supposed to put anything on a EDPM rubber belt like the "belt dressings" they would sometimes use on older style V-belts.
Perhaps in four or five years they'll admit there's a design issue and do a recall.
When they take that off to put the new one on, have them spin the water pump by hand and see how it feels.  We've put a few on already, the one last night seized and fried the belt during its degredation.
voided3 is right, belt dressing is a temp. fix for a bad belt and not good for those type of belts. I don't see it being an alignment issue as those belts will tear up the edges of the belt in an alignment issue and walk off the pully quick if not aligned right. I do see the ribs of the belt are cracked which means the belt is dry and probably old or some type of chemical got on it. There are plenty of better belts out there like Gates for one and many others. I would chalk it up to a bad old belt even though it was new.
Or as newdude said above.
Edited by Silverado4x4
How much $ per unit did GM save by removing the belt tensioner?   X 1 mil. units.
Probably a lot, which I'm sure was the driving motivator. I can't help but notice that the gas L8T 6.6 V8 in the HD trucks have a belt tensioner, though. That always implies to me that it's a more robust setup if that's what they use in their HD fleet trucks, though those trucks also have hydraulic power steering pumps and sometimes dual alternators so the needs are different.
GM is currently selling about 575,000 Silverados per year.  Retail price aftermarket for a tensioner on a 2018 is about $40.  To keep the math simple, assume 50% markup.  $20×575,000=$1,150,000 per year savings, assumed.  2022 is the 4th model year of the current design, so approximately $4.6 million in savings to date.
What about GM trucks? That's why I said 1 mil. Just a number to make a point. Didn't look it up.
SE = Satisficing Enough  🤣🤣🤣
They said the instructions came from GM.  Whether or not they screw it up, because they did it they/GM will cover it.  Until the truck is out of warranty, only Chevy dealers are touching it.  Makes it harder for them to deny warranty coverage.  Once the warranty is up the truck will be service by mechanics instead of technicians.
It took GM way longer than 4-5 years to acknowledge an ignition switch problem.  You're being too optimistic.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
