4 minutes ago, Trailblaster said:
I did a weekly follow up chat with Chevy chat and my order went from 4300 to 4200 status and currently located in flint from what they can see.
Can you please explain what is meant by 4300 to 4200 for us that are waiting for trucks and all we get are waiting transport. What do these numbers mean?
I saved this pic of the status codes from this forum. The customer service agent says it’s in transit and when I asked what code, she said 4200. I don’t know what the difference is between 4300 and 4200 so I’m waiting for my dealer to give me a call back
Here is some more info from the "Build Time" thread.  I think there is even more explanations in other posts in this thread, and a few others.
Edited by elcamino
My dealer called me back and said that they have a tracker on the trucks and that it’s aboard a train heading to NY where they distribute vehicles from for the New England area. He also said that GM increased the MSRP in February. I told him I ordered it in January so the original MSRP still stands but window sticker will show higher. I missed the $1700 increase by a week. Dealer expects to see truck roll in on the 20th of next week. Mine is the only non high country 2500HD coming in for quite a while. Everything else is a 2500 or 3500 HighCountry and no GMC 2500 coming at all
I have the original window sticker from when the truck was to be delivered (first time).  It is a lower price vs what the website says when building the same version.
I ordered my 2500 in September, and the dealer invoice is now showing a $1700 increase in MSRP and that is what they said I need to pay.  I've contacted Chevy and they said it is between me and the dealer.  Any tips on how I can get the dealer to honor the price of the truck as shown on the build sheet in September?  I haven't paid a deposit, and haven't signed anything.  Just placed an order, in my name.
The dealer got the truck and they know you want it so they are not likely to give in.
14 minutes ago, shakenfake said:
Only 12 days away buddy
Re read the posts and see how many times the dates have been pushed.
    • Hey everyone,   For anyone looking at roof-mounted lighting for the Hummer EV, we wanted to share our M&R Automotive 50" PRO Roof Light Bar for the 2022+ GMC Hummer EV.   The curved 50" bar sits close to the windshield rather than sticking way up above the roofline. The mounting position is designed to keep the setup relatively streamlined while minimizing wind noise and maintaining full use of the factory windshield wipers.   A few details:   50" curved PRO light bar Fits 2022–2026 GMC Hummer EV Spot + driving beam pattern TIR optics White main beam Amber DRL backglow Approximately 15,410 measured lumens through the lens Mounts to factory accessory locations No cutting or drilling required Wiring runs down the A-pillar toward the AUX connections Designed to minimize wind noise Lifetime warranty Off-road use only     The 50" is an interesting middle ground for anyone who wants the visibility and mounting position of a roof bar without stepping all the way up to the larger 60" setup. For the Hummer EV owners here, would you go with the 50" for the lower-profile look or step up to the full 60"?
    • My son got a hatchback withe the aero package for like 17k new. Great little car with amazing MPH
    • Yeah, I've given up years ago with that! I was able to load a few when I first joined the site sometime around '07. Then after maybe 20 pics, it said I exceeded the limit. Now every pic I try to post says I've "exceeded 1mb".   ONE MB??? That's Windows 95 ******, lol!!
    • I get the same results with pictures. Then I figure it out. Then I forget. Screw it.
    • I guess I'm the only one on this forum who can't get effing pics to load here! Do you have to resize them to post, or am I just blocked from uploads?   I have the same luck with automotive electronics ... but this is the ONLY site on the net that I have this problem!   I'd post pics of what I'm working on ... but I CAN'T! 🤬       Just fabbed up the kickdown cable (had to extend the cable mount WAAAY out from the throttle shaft to get a full pull), and parts arrived for the fuel lines on the 940 carb conversion project. Should be able to drive this thing by the end of the day. If not for work, I'd have had this thing done SIX weeks ago.   Got the jetting sorted out last week. Had a real bad tip-in bog that I couldn't seem to correct. Friggin float height was over 11mm too HIGH! eBay purchase, so no wonder everything is screwed up right out of the box! I ended up with a larger dual-squirt accelerator pump jet anyway instead of the single. Also moved the 70 primary idle jet (4 sizes too big out of the box) to the secondary idle circuit, and installed a 57 in the primary. Runs great on the fuel bottle!    Still using the computer for ignition. Going to drive it first and see if I want to go through the project of installing an intermediate shaft with a distributor drive gear, so I can install a block-mounted distributor and run points, 100% computer free. I should do that anyway just from a simplicity / reliability / tunability standpoint. The electronics left me stranded last year a couple times! I can't tweak the timing to my liking right now because of the computer. Tried twisting the cam-driven distributor already ... and the damned thing just reverts back to where it was! That's infuriating. But if it runs well enough I might save that for next season.   Just driving it in and out of the shop to work on other projects, it feels 1,000% more responsive with the carburetor. Also fires MUCH faster when cranking. Can't wait to drive it and see if I got more than 114 ponies, lolol.   Hopefully these don't go 404 like the last post ... https://postimg.cc/gallery/MjhrmZS   Seems like that site went back to dial-up internet! Maybe they'll fix that some day ...
