Hello All,
I have a 2018 5.3 silverado, currently have a 6.2 manifold and throttle body, cold air intake, new thermostat, (had high performance plugs until they started misfiring now back to GM), Borla dual exhaust, american racing long tube headers, and a tune.
I have a 7" lift with 35" tires.
Besides a supercharge or turbo I heard there is not a ton more I can do besides a high performance torque converter.
Any suggestions or advice on this would be very much appreciated, thanks in advance.
With a 7" lift and 35s I'd be doing gears instead of a converter. 4.56 all the way. Converters are great though but I think you'd get better gains from gears.
You can still gain a good amount of HP in NA form, just not as easy as with boost. Cam, a good set of heads and E85 could get you another 100 probably.
If you’re running stock cam, I would stick with stock converter or a 6l90 converter (if you have 6A). And like Lucas said above, regearing would be better in your application.
what “performance plugs” were you running?
Edited by CajunFries
Unless @Ryansal installs the cam himself - it would be far cheaper to do gears! Ask me how I know 😬  last month the intake lifter on cylinder #1 took a ****** (collapsed like most AFM lifters do). I'm on a TDY in Northern VA and without the conveniences of all my tools and garage, was forced to take it to a shop. But hey, I now have mild ported heads, a BTR Stage 3 cam, and just about every seal/gasket was replaced. Labor is expensive to say the least.
Converter. Why? Because the stock one has a weak lock up clutch and I'm surprised it hasn't let you know already. IF it were decent then gear first. IMHO-OC
i would swap in the converter from the cts-v or boosted camaro,  and disable the TCC entirely,  if stock stall is what you prefer then order the 2500 converter for the 6l90, and make sure you shim the the converter from the flywheel for proper pump engagement.
Thanks for the advice, I'll look into changing the gears.
HI thanks for the input, I don't know what type of plugs he put in, apparently the plug cables were getting fried by the headers and caused  #7 to misfire, as well as a few others not as frequently though, the guy that did my mods suggested I get a new torque converter that would "feel like I lost 800 lbs of weight  in the truck"
Depending on the combo, yep, a TC can make a huge difference not going to argue that. I've had as big as a 3600 stall and it was a lot of fun. If that's the route you go, custom trans tuning will be important though. You'll need to have full control over when and in what gears the TC is locked up. You'll want it locked up at the very least on the highway. I have mine set up where tow/haul acts like a quasi-sport mode. It holds gears longer and I keep the TCC unlocked the entire time. Much more playful that way. "Normal" mode has lower part throttle shift points and a lot more TCC lockup.
I would do the converter only for durability and maybe ask for 100-200 more rpms in stall speed.  Increasing the engines horsepower will increase the stall speed without doing anything to it.
Gears is the big one when you are lifted.  4.10s or 4.33s or 4.56s are popular, I would go 4.10s to keep the rpms about the same as if you had 3.73s on stock tires.  Maybe 4.33s.
I am considering swapping to the ctsv/ZL1 converter also. I have a 16 Silverado 5.3 6l80 full exhaust, tune , 6.2 intake, what’s the stall ratting on our stock converter , and what’s the stall rating on the CTSV/ZL1 converter? Is there really any benefits going  to one of those converters?
Hi Lucas and thanks for all the help, I understand If I get a TC i'd have to get my transmission tuned, however if I change the gears to 4.56 would I have to get the transmission tuned? thanks again
Can't answer that. Just understand that a TC is rated based on the torque of the engine they're behind. For example, a CTS-V-TC might say 2400 RPM, but that's probably based on what 550+ lb. ft.!?
Edited by lucas287
Some sort of calibration will be needed to tell the ECM that you are running a different gearset. Don't think that change is in the TCM.
running with out the tcc feels like a 500-800rpm higher stall converter
if you pull the trans install the upgraded pressure regulator valve, these have been  failing alot on the 6speeds and cause shutter, and burned up components, if you make over 500ftlbs, there is an upgrade for the 45,6th gear clutch from a powerglide kit..
if you like to rev the truck out.... only use 1,2,3, and 4th gear, as 5th and 6th is very weak
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
