After hearing about the recall involving the GMC Terrain for their headlights being too bright made me think of the topic on this forum about GMC Sierra owners being told their headlights are too bright or flashed by oncoming drivers for bright lights while having their low beams on. Hopefully it doesn't come to a recall for our trucks.
I wouldn't be a bit surprised if there was a recall for the trucks. I can't tell you how many times I've been "flashed" at night. Considering we sit close to the same height as a Yukon.
The biggest problem with the Silverado/Sierra isn't the headlights.  Owners put leveling kits, raise the front or drop the rear to level and that throws the aim off. An inch or 2 makes a huge difference in the light plane down the road. It's all about aim and adjust which most don't do after leveling.  2 guys I work with leveled and didn't adjust their lights.  They were getting flashed; I adjusted them and "voila". No more being flashed.
Edited by mafd2
What trucks are you driving? My RST headlights leave a lot to be desired.
I drive at night a lot, I’ve never been flashed
  • Haha 1
Presumably its ones that are poorly aimed due to lift/level or loading.
Presumably we don't yet have enough info about how the refreshed ones perform
Lights used before the refresh:
1500 Sierra
 Headlamps, LED reflector with incandescent turn signals and LED signature Daytime Running Lamps    S       S       S       S       --       --       --
 Headlamps, LED reflector (high intensity) with LED turn signals and LED signature Daytime Running Lamps    --       --       --       --       S       S       S
1500 Silverado
Headlamps, halogen reflector with halogen Daytime Running Lamps    S       S       S       --       --       --       --       --       --
Headlamps, LED reflector with LED signature Daytime Running Lamps    --       --       --       S       S       S              S       --
Headlamps, LED reflector (high intensity) with LED signature curtain Daytime Running Lamps
1 -  Included and only available with (WGQ) Redline Edition.
2 -  Included and only available with (WJP) Midnight Edition.     --       --       --       --       --       A1    A2    --       S
'dashes' and 'S's' indicate not available or standard on different trims
A1, A2 refer to available on a trim, with the condition listed in the notes
I get flashed all the time with the Denali. Stock truck not leveled and not towing. I don't think they are overly bright either. Both rows of lights illuminate and I think oncoming drivers see the four lights and automatically think I forgot to dim. With the fogs on, it's worse .
Edited by smit303
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • Just don't turn the steering wheel as much?
    • Rockauto bud. I pass local stores for parts.   Findya something online.
