So the other day I noticed that someone had scratched the passenger door of my 20' Quicksilver Sierra.  I also have a chip from a stone strike on my drivers fender I'd like to do.
I have touched up vehicles in the past and it never looks great.
Anyone have any suggestions on a good touch up paint?  Any tips on application methods?
Thinking I may just get the proper paint code, touch it up, and after it cures, wet sand and buff it to try and bring it flush with the stock paint.
Thanks for any suggestions.
i suggest you don't wet sand. You'll end up sanding down the surrounding clear coat.
I've used automotive touch up based here in Louisiana with great results on several trucks.  They also have several tutorial vids.  I put a thin coat of base then a coat of clear then wet sand and buff.  I don't use the brush in the bottle.  I get good quality brushes from an art hobby shop.  You can get several shapes and sizes depending on the size of your scratch.
https://www.automotivetouchup.com/
1 hour ago, It's Tim said:
"Touch up" will look 20X worse.
Not if it's done correct with the right brushes and know what you're doing.  Done it too many times. Can't just blotch it on there. Then it'll look like crap.
Have done fine with ACDelco and Duplicolor touch up pens which provide several ways of applying the paint.  Less is more.
I've done literally dozens of chips on Pepper and IF I don't point most of them out you would look along time finding them.
Like @swathdiver I use ACDelco or Duplicolor pens. On a day over 55F wipe the area to repair with alcohol and a microfiber or a prep wipe if you have those. I use a paper punch to make a dot of 2,000 wet/dry and superglue it to a new pencil eraser. Good light and magnification required. Just dull the area with the 2000. Use a 0000 oil brush to fill the chip above the paints height. Applicator provided is WAY to large. Let dry for at least an hour. Use 2000 again wet this time to 'level' the paint. Then move to 3,000 foam backed 3M and then 5000 foamback. Depending on contour I wrap the foam back around a shop rag or around something flat like a domino sanded flat. Lastly I use 3M Perfect It and microfiber. Each step finer use only the time and pressure needed to remove the previous marks. That last one will bring it to glass and you've removed only microns of finish. 24 hours later, wax it.
This whole process is a 'touch' thing that must be learned but if you use the grades mentioned there is a great chance of success. Looks way better than stab and jab method detailers at used car lots do.
Straight simple colors without metallic, flips, pearls or tri-coats and so on work much better but even on those it still looks better than stab and jab and good enough until you collect enough to warrant painting an entire panel(s). I've done a dark blue party metallic right in the middle of a flat hood that was good enough to fool the purchasing manager at the dealership and his body shop. That one took a few days but results are the result of effort and patients.
Edited by Grumpy Bear
Will look 20x worse than what?  Leaving it alone; exposing the primer or steel?
If you do it right, it is a solid 20/20 or better
Edited by Rob Mugs
This is one of the reasons I went with a silver truck. I have 2 chips I can barely see on mine so far. If you take the vin number to your dealer they can order a touch up pen that will match your color code. The last one I got had paint one one end and clear cote on the other. I think it was around $25.
    250.6k
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 240 Guests (See full list)
    • I don't wanna do major surgery/upgrades, behind-the-dash work, add amps, change radio etc. on my '26 std cab WT. On the WT, it has the base 7" IOR infotainment setup, and only two speakers (doors). Since I listen to classical, looked around for speakers that do well and dug thru reviews. Two-way speakers were found to be better than 3-way. So I've ordered a pair of  Infinity Reference REF-9632IX 2 way speakers.  [These may  or may not have been discontinued / succeeded by the 3-way ...9633 ones.]    These speakers are lauded for 3 ohm and 94db sensitivity spec so they'll work well for ordinary base car radios without amps and offer better performance (quality,  strength) than  default base paper-cone speakers. They'll be installed in a few days and I'll let y'all know what I think. Bill W San Jose
    • Thanks!   Changed out the rear shocks today to Bilstein 5100s.  So far feel much better. The stock Rancho were wore out.  Lots of heavy hauling (2 moves, home renovations, etc).  Next up is new BFG tires Monday.  Cant wait the current tires have little to no wet traction and are super loud (hum)
    • Ok, I got the all the codes. What do you all think would be a place to start?
    • How about I just point to the factory pans stand pipe little drain plug and claim its a pan with a real drain plug !. I just couldn't swallow the fact that a Dorman pan which at this point is probably the only pan out there that fits the gas version truck cost that much up here in Canada so I decided initially anyway to skip it and see what I thought of pulling the pan method and down the road if I felt inclined enough then I would either install a drain plug kit in the factory pan if there is enough room for it, or have a bung welded onto it, or put an aftermarket pan on. The thing is if the pan is not pulled then the magnets in the pan can't be inspected and cleaned or if wanting to change out the filter. However of course it certainly would make the job easier to be able to drop the oil first before having to handle the pan if dropping the pan that go around was the goal.    I knew a guy locally that was doing custom field spraying years ago with a pickup pulling a ground driven sprayer, I believe it was a GM pickup with an automatic trans. He had a drain plug in his pan and would drop the oil out of it once a week and top it back up through the dipstick tube to keep refreshing a portion of the oil often and that made the transmission last far longer than had he done nothing. Soft fields pulling 500 gallons of water at the start of each mixed up sprayer tank batch and in low range sucking along. I imagine he got some tips from other custom sprayer outfits doing the same thing at the time and learning from their blown up tranny mistakes. Transmissions then had no lock up converter so would cook the crap out of the fluid slipping that much and it would not have been synthetic fluid either.
    • 3.39 Kroger’s in Montgomery Texas.
