So I get in my truck this AM and it will not start, starter just keeps running. Checked everything no codes thinking at this point here we go a trip to the dealer.  So what did I do last a full clean-up including removing the floor mats to clean.
Well it was dark when I put them back in and I did not get the drivers side in all the way it was touching the gas pedal, Installed correctly and all is good. Learn something new everyday!!
Edited by WeGone
  • Thanks 2
Yep, you initiated clear flood mode. I do that after changing my oil to allow the filter to fill and prime the system before starting.
  • Thanks 3
20 minutes ago, It's Tim said:
officially.
He already admitted it... no need to pour salt on his wounds. 🙃
34 minutes ago, It's Tim said:
officially.
OK so I also failed spelling, I'm also old and could care less 😜
You can smile now fixed it.......
Edited by WeGone
  • WeGone changed the title to I'm officially stupid...
Me to. Old. Failed spelling and stupid.
Not that small of a club.
You can add, you're a good sport to this list. 😉
Don't feel bad we all been there, I bought a new weedwacker a few years ago after old one died and the 2nd time using it wouldn't start after about a half hour trying to start it iam soaking wet from sweat pulled the plug out twice using a torch to dry the flooded cylinder out of fuel tried starting still nothing then realized the old one had a kill button this new one had a on off switch that I forgot about, switched to on and fired right up, I called myself a bunch of cuss words along with dumb S.O.B.
  • Haha 1
I'm guilty as well.  Long time ago back in 2005 or so in my 2002 Silverado, I was on a trip to TX and went to clean my windshield with washers.  Well I hit the wipers to wash and no fluid, did it again and nothing.  I figured the pump went out for the washer fluid.  Went and got a new one and and installed it and same thing, then I realized I was just hitting the one wipe button, not the wash button.  Lesson learned and I had an extra washer pump.    Life goes one.  One thing, this thread brought to my attention the "clear flood mode"  never knew about that.  Good to know!
  • Haha 2
Yes,  Good to know. As my first new truck ever I'm learning technology has moved far faster than I have 😁
  • Thanks 1
I can go farther back. Wife’s first new car in awhile 94 impala ss. I turned off the car and the radio was still playing with the key off. I thought there was a short. I sat for awhile pull out the manual after awhile it turns off. I finally figured it out.
Time to bring out the dumb things I've done.  One other was when I had my 1988 Beretta, Remember those?  Loved that little car with the 2.8 and 5sp.  Well changed the oil and forgot to put the cap back on, but had it on top of that nice shinny aluminum manifold.  Went to close the hood and it didn't want to close. Then there was this nice dimple in the hood. Car was black so you could really see it.  Needless to say, I never did that again.
Dad said, learning from mistakes is the best teacher, but is the hard way to learn.  :lol:
My turn again... Back to the 90s changed the front brakes on my daughter's Lumina dropped the jack jumped in to back out for a test run.... I forgot to pump them back up! stopped when I bumped the old 69 Falcon no damage love them old steel bumpers.
Ok father back. Doing a tune up on my 68 fastback Chevy impala. I was 19 years old not my first tune up. It was during lunch in front of about 20 people who worked for my dad. They loved to pick on me. Some are on the fender poking at me. Put the points in set with a gauge, no dwell meter. Plugs wires, plugs. Finish shut the hood back to work. Quitting time, it doesn’t start. About half the guys are rolling with laughter. I had the rotor backwards. A couple saw me do it. Didn’t live that down for awhile.
How about all those people telling your wife her headlights were still on lol
    250.3k
    BDS my HD
    BDS my HD
  • Who's Online   1 Member, 0 Anonymous, 503 Guests (See full list)
    • Hello hello looking forward to expanding my knowledge of the 2026 2500 HD that I just bought.   Truck has 3500 miles on it four-wheel-drive crew cab and I’m about to put a 6 1/2 inch BDS lift on it 18 x 10 -25 offset with 37’s   Already have the wheels and tires just waiting on the lift install in about three weeks   Question what surprises am I not gonna be happy with?  I’m not new to lifted trucks so I know that acceleration towing gas mileage all that is affected..   Question is those of you that have this truck this powertrain with a 10 speed Allison and have done the mods that I’m doing,,, how bad is it? Is that Allison constantly gonna be hunting for the right gear to go into? And what about towing, acceleration, fuel consumption as mentioned?    Lastly how come I can’t find any ring pinion gear set up for these axles and when could I expect to see them?   I apologize if there’s any typos I’m doing speech to text on my iPhone.
    • I've got a 2013 2500 6.0L Flexfuel. Drove the truck earlier today with no issues. Went to run an errand tonight and noticed key fob wouldn't work. Figured battery was dead, so replaced fob batter. Still wasn't working. Grabbed my other set of keys with the other fob and that one wasn't working either. So I manually unlock truck and insert key. Interior lights come on, dashboard lights up, turn key and truck starts. Turn truck off, like a moron, and try starting again. This time no crank, no click, no nothing. Lights still come on and dash lights up, but now I'm getting a service 4wheel drive, service tire monitor, etc. Check voltage on battery and Im showing 12.2v. Throw my battery charger on it and give it 15 mins and try starting again. But still no crank no start. Decide maybe its a bad battery, run to autozone grab a new one and put it in. Same issue. Disconnect battery and let it sit for 15 mins. Try again and still nothing. I had managed to roll the windows down earlier as its a humid night, but now I can't get them to roll up. Power locks are also not working now. Then randomly I try the key again, and it fires right up. Immediately I roll up the windows as we have nothing but rain forecast this week. I shut it back off wait 30 seconds and start up again. Worked a 2nd time. So turn it off, start putting things back together. Try one more time, and back to no crank no start. And now the car alarm starts going off. Had to disconnect battery and leave it that way for the night as I don't think my neighbors would appreciate my alarm going off again tonight. Any thoughts or help would be appreciated.
    • No one will care for you like you care for you. Do what you can for as long as you can. IMHO of course.
    • How about them NICKS!!!
    • Hi there.  Long time lurker, first post.    i have read the previous posts regarding the water ingress problem with this emblem.  I bought my 1500 SLT the  summer of 2025 new and after reading the MANY problems with these emblems failing I decided to install one anyways.  As per a YouTube video, I sealed ( or tried to) this sign with silicone sealant around the outer perimeter joint and the holes that were already somewhat sealed on the rear plate of the emblem.  And installed the connector assembly using dielectric grease on the connectors. The installation looked great and worked well for about 4 months……then FAILURE.  Grrrrrr…… I live in the great white north and wash my truck weekly in an automatic car wash  to keep the salt off.  Let me tell you that removing the old, failed emblem is a whole different animal than removing the OEM individual letters without removing the grill assembly. Mainly because the illuminated logo is built differently than the original letters which  you can remove the red surface lettering with a knife or some kind of blade which gives access to the tabs which hold the logo onto the grill. So I had to essentially destroyed the old emblem to remove it. Doing so killed my chance of doing somekind of autopsy on the failed , old logo.  But there was plenty of water inside when I ripped it apart.  Prior to installing the new assembly I tried it with the old harness and it works fine.   Does anyone have any insight as to where the water is getting into this emblem? I intend to seal the new logo with slow curing epoxy this time around using a syringe.  I think this newer emblem may be an updated unit which I hope GM got the vendor to fix. It has an October 2025 date on it.    If this one  fails,  I am just going to revert back to the non-illuminated letters….AFTER PULLING THE GRILL.    Any thoughts on sealing with epoxy would be appreciated. Thx!   Doug
