93 @ $4.59. E85 at $2.79, which is even more offensive to me. It suddenly went up 40% in price even though it’s only 25% gas currently. Meanwhile E10 only went up 15%. 🙄😵‍💫
$4.70 is the cheapest for 87 right now, most stations around are into the 5's for regular.
I paid $6.29 for 91 today, highest I've ever paid.
This weekend it went to 3.19 at Kroger’s in Montgomery Texas. As of this morning it’s still there. The Ridgeline is just under half, the Odyssey is at 3/4s. My walking spots are 18 miles round trip. No trips probably for a month. I banking I’m good for the turn around. My wife’s Genesis is good for two weeks.
Over $3 in Texas is a warning sign. 😬
Diesel is increasingly high 6's around the Seattle area. Saw $6.89 yesterday. 😬
87 has hit $4 a gallon and Premium $4.85. Wait! Am I getting premium at the same price @Atlas pays for regular? 😱
Probably, but prices are always higher here on the West Coast. And we're over $5 for regular now even at the cheap stations.
  • Sad 1
$3.41 today in W. Texas. Price has dropped a few pennies last few days.
$3.60 ish in DFW with price dropping by a few pennies each day
Still holding at $3.39 for 87 here. 93 octane was $4.17 and Diesel around $4.80's.
E85 in the mid to upper $2's from what I saw.
Meanwhile, electricity is holding around 15 cents per kWh and gas prices aren't a concern for the EV we put ~20k miles on in the last year. It also never needed an oil change. It did need tires at 25k, as I'd expect any 4-second car in our household to need by then. 😈
91 ethanol-free premium was clocked in at $6.89 last night at the ripoff station as we drove by. Now that the weather is nicer the fun cars will need some of that.
$3.37-3.39 in town.
Diesel jumped to $5.30 a gallon, big jump at the truck stop. Smaller stations at $4.99.
    rayredbone
    rayredbone
  • Who's Online   1 Member, 0 Anonymous, 480 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
