Kroger’s in Montgomery Texas. 3.59 yesterday. 3.49 today. Weird. 😳
$4.35 85 oct.
Out and about yesterday on a long Saturday drive I passed a lot of Shell stations. My preferred, so I pay attention. Lot's of small town Illinois so not six stations in three blocks like the city.
Everyone of them over a radius of say 100 miles had regular at $4.19 but one which was the one closest to home at $4.15. However Premium pricing varied greatly between 85 cents over regular to $1.50 over. I'm not counting the price of the station with the lowest regular so the reference is the same for the remainder and all within the same brand. However the spread discrepancy holds across all brands.
@txab, any thoughts on that?
Question for you Grumpy, why is diesel so much more than gasoline? Seems to me that it may be slightly a little less refined than gas and it doesn't have 10% alcohol which presumably lowers the price of gas
Around 2008 if memory serves they took sulfur out. That was when diesel went up.
Swap costs and supply/demand balance. When a barrel comes out of the ground the entire range of products are present but not all at the same percentage.
Breakdown of Refined Products
The following table summarizes the approximate output from a standard 42-gallon barrel of crude oil:
Product Type Gallons per Barrel Percentage of Total
Gasoline 20 gallons 45%
Diesel Fuel 9 gallons 21%
Other Products 13 gallons 31%
Most of that diesel figure is 'straight run' or cut from the barrel. Gasoline 'cut from the barrel runs 0 to 20% at the crude. So in the crude unit there is more diesel the gasoline, usually.  The full refining experience however gives the tabled values. Ego there is half the diesel than gasoline after the 'first crack' That could be an FCC unit, or Isomax or....
Those units take heavy products and break the big ones into little ones. Those numbers are harder to get hold of but directionally it ends up the same.
Really light products are very profitable. Ethylene and Propylene to name two. Those are cracked from slightly heavier feeds like NG and Propane and Ethane. The cracker harshness determines the feed for distillation. Those feeds come from less profitable products like diesel and gasoline.
So...there is a swap cost. How much market is there TODAY and what crude am I running TODAY..... what is my process capable of always.
There is this as well. The USA uses allot more gasoline than it does diesel so in the cracker the process is tilted to gasoline production which....limits supply of diesel. OTR uses the most and it has different requirements than automotive and agricultural.  Limiting auto products.
You are correct however. It is less refined, just less of it. Allot less.
It added a cost layer to an already limited production supply. True that.
I figured you would know about it.
$5.19 regular and mid-6's for diesel here. Ethanol-free 92 is back up near $7 at the stations that offer it
  • Sad 1
Big oil is raking in billions from the Iran war. Can it avoid Trump’s fury?
Remember I said Big Oil is 'Vertically Integrated"?
Even as they no longer own the majority of the "Pump" they still own the "Well". Crude price upward pressure does not translate into that same pressure on production. Pumping cost remain unaffected and the gap is pure profit. Even after subtraction of a minor, comparatively, lower amount from supposed, but not always, realized refining volume. Consumers hate war, Big Oil, not so much.
Edited by Grumpy Bear
$5.19 after Kroger discount for 87 today. Moses!
Somehow I've already put 560 miles on the Blazer with the last tank clocking 19mpg.
yo-yo prices on the hi-way the last couple days, Sunoco was $3.75, went down to $3.74 then up to $3.81, the twin Gulf stations ( 1 on both sides of the divided hi-way, same owner) was $3.84 and went to $3.89, Mobil went down a nickel, $3.89-$3.84 and dropped the plastic price a dime, to $3.89,truck stop went up a nickel to $3.85
Edited by richard wysong
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
