Been lurking on the Gas HD site for a while now.  Had ordered a new 2022 GMC 2500HD with the 6.6 gas last year, then supplier lost allocation.  Had to wait for a 2023.  I was "hoping" the 2023 HD's would get the new interior.  Doesn't appear like that will happen.  I've been looking at the 2022 interiors and I'm impressed.  I was messing around on GMC's website building a few half tons just for fun.  I saw the LM2 can be had with the Max Tow package that offers a 3.73 rear, better leaf springs, a 9.76" axle (I guess is bigger?) and enhanced cooling.  That seems like a lot for $850.  Then I saw the tow ratings are near 13K!  I was like maybe I should look into a half ton diesel with the kind of mileage I've been hearing.  I am keeping my 2015 LML, I'm just needing to add a second vehicle for my business.  I do occassionally tow heavy so that's why I was looking at the HD gas as I really couldn't justify a second HD diesel.  I'll always keep one diesel around because of the heavy towing I do from time to time, but I don't necessisarily need to tow real heavy with the second pickup, maybe 10-12K.  I know that would tax a half ton even with the tow package but I live in western Kansas where it's flat, no traffic, and towing would be local, just delivering seed/ag products.  We have old GMT 400 half tons at the farm we tow ridiculous weight with sometimes but that's not out on the open roads either.  So are these new half tons with the max tow package kind of like the old 1500HD's?  I know those were 8600 GVWR and it looks like you can spec these new half tons up to 7300, but just wondering if that's where this may be headed.  Anyone on here towed with a new 2022 with the Max Tow?  Leaning towards the 3.0 because of unloaded mileage.  I know the 6.2 is a beast but with premium fuel and a lower unladen mileage I'd rather stick to the diesel as I put on 30-35K a year.
I know this is a long post but what are thoughts on a B&W gooseneck hitch in one of these new half tons?  All my trailers are gooseneck 24-26' with 7K axles.  They weigh 5K empty.  Was thinking air bags if I went that route.  I did see that the ratings for gooseneck towing is way lower which doesn't make a lot of sense to me but maybe it's to do with pin weight and axle ratings.  May ultimately end up doing the 2500 but I didn't realize they had bumped the ratings up so high for 2022 on the half tons.  I wish the At4 had the higher tow rating.  That's the model I want.
Any feedback appreciated.
I would buy a used 3500 or 2500 before I tried actually working a 1/2 ton this way.  Tow quality is going to blow.  Airbags will help...LT tires will help...  How much do you care about the tow limits established by the manufacturer?
Depending on the weight of the cargo you might be better served with a tandem axle bumper pull utility trailer.  Big tex has a lightweight trailer with cargo capacity of 5500lbs.
If you want to gooseneck, get a 2500 or 3500.  Not enough payload on a 1500, even with max trailer.
I was looking at getting a bumper pull deckover maybe 20’ or so with the 7K axles if I went half ton. . Looking at the specs on those they only weigh like 3600 lbs empty.  Figured I would load 7-8K in cargo and stay within the tow limits of 13K, but maybe that is not realistic.  I totally see what you are saying an HD would be better suited for towing, but I’m keeping my 2500 this will really be a backup with the potential for some heavier towing locally.  Not running around the country on a 500 mile trip.  I think the mileage with the 6.6 unloaded is gonna be pretty poor but I know the tow experience will be way better.
Just watch your tongue weight....most of your weight is going to be way back by the axles to make this feasible...and you're going to need weight distribution too.  2500-3500 do not have a requirement for a WDH at these proposed weights.
I don't think frame and brakes change with the NHT package.
IIRC, the 1500HD's did have their own frame.
I wouldn't even think of hooking my 1500 diesel to a trailer and load like you're talking about.
My primary reason for 2500's (for the 10 or 12 years I ran them) was also for hauling seed/chem products on a flat deck.  Mostly flat 'here' too, at about 850' asl.
Despite the bump in trailer rating, NHT adds only a small amount to payload.
Otoh, the 3.0 is a great little rig for doing all the other things you are likely doing if the heavier towing is seed/chem....
I thought the HD half ton package came with a little thicker frame like the F150 did.  Any more info on this ?
yeah airbags on a 1500 frame overloaded is not smart, neither is the braking power that impressive on the 1500's when compared to hydroboost on a stought 2500
FYI, my 2022.5 3.0 Crew Cab Standard Bed High Country with NHT max tow package has a max payload of ~1480 pounds.
Nope.  Frame is the same.  Higher spring rate, shocks, heavier radiator, 9.76" axle and lower (higher numeric) gearing.  That's what makes up the NHT package.
Edited by newdude
4 minutes ago, newdude said:
Nope.  Frame is the same.  Higher spring rate, shocks, heavier radiator, 9.76" axle and taller gearing.  That's what makes up the NHT package.
Lower gearing!  Low gears are higher numerically.
1500HD was built from 2001 thru 2007
They were originally a way to get a crew cab on a 1500
(remember that the 1500 crew/short wasn't introduced until 2004)
Here's an article about 1500HD.
Todays max tow (NHT) option is not the same thing as 1500HD was.
https://gmauthority.com/blog/gm/chevrolet/silverado/chevrolet-silverado-hd-heavy-duty/chevrolet-silverado-1500hd-heavy-duty/
Edited by redwngr
    • Here's the second UOA on my 22 Wrangler with the Ecodiesel. This has 5k miles on AMSOIL Signature Series DEO 5w-40. The first one was dealer installed oil, no clue what it was, the second is what AMSOIL recommended, European FS 5w-40, Most of the Ecodiesel world is showing great results using the European MS 5w-40, I figured I would see how the DEO works. This is using an Ecoguard oil filter. It's my understanding this engine likes to shed aluminum.  We will see. So far I don't think this is too bad.
    • I'm surprised nobody seems to offer a solution like the start/stop device I put in my new truck. Remembers my setting when shutdown. And while it still starts up in start/stop, it stores/evaluates what mode it was in when shut down and will change it whithin a second or 2 of startup. It'd be nice to have something like that for the DRLs.
    • 2015 Sierra 1500 here. Leaks from the sunroof to front driver side and soaks carpet. How do I fix this? Thanks!
    • I will be doing that for sure, but I need to solve who has/ where I can find a bidirectional scan tool that will support OBD 1.5. I'm kicking myself because I ebay'ed a Snap On MT2500 that I didn't think I'd ever need anymore. D'oh!! I'd rather not buy another, so I'll contact a few local shops to see if they have one and how much they'd want to do the procedure. I'd rather have the ability to do it myself... I wish there was a modern tool that could do it all, but I'd have no idea what to buy.   The theory with the pulled timing is that it mimics a rich condition. The delayed spark causes incomplete burn and the O2 sensor picks up low oxygen levels. That's interpreted as a rich condition so the PCM pulls fuel and that shows up in the deeply negative fuel trims.
    • An ultra wealthy man had the most beautiful daughter. But, there was a problem. Everything she touched would melt in her hands. No matter what, Metal, Wood, Stone. Anything she touched would melt. She could not feed herself. Because of this, men were afraid of her. Nobody would dare marry her. Her father was despaired. What could he do to help his daughter? He consulted doctors, scientists and anybody who could solve this problem. Finally one of them said, "If your daughter touches one thing that does not melt in her hands, she will be cured." He was overjoyed and came up with a plan. The next day, he held a competition. Any man who could bring his daughter an object that would not melt in her hands would be given billions of dollars to marry her. Three extremely intelligent and handsome young men took up the challenge. The first brought a very heavy steel rod, But alas, when the she touched it, it completely melted in a matter of seconds. He sadly went away. The second brought a beautiful diamond, knowing diamonds were one of the hardest substance in the world and would not melt. But alas, once she held it in her hand, it melted. He too was sent away disappointed. So now, there was one left He was very nervous & sweating. He approached the daughter & said, “put your hand in my pants pocket and feel what is in there." She did exactly what he asked. She felt something very hard. She held it in her hand, squeezing it as hard as she could. It did not melt & remained extremely hard. Her father was overjoyed. Everybody was overjoyed. She was finally cured. Nothing never, ever melted in her hand again. They married and they both lived happily ever after, raising a wonderful family. Question: What was in the the groom’s pants pocket??? Answer below ↓ M&Ms of course! They melt in your mouth, not in your hand. What on earth were you thinking?
