i have a 2018 silverado 1500 with the 5.3 and speed engineering LT headers and at a higher rpm or between 80-85 i can feel my headers touching and vibrating on my frame. has anyone else had this issue? i read one forum where if you replace the motor mounts the problem is fixed
On 6/21/2022 at 3:07 AM, CajunFries said:
Give it some heat from a torch and massage it a bit.
so you have the same issue on the driver side that i do. i guess im gonna have to take them off this weekend and do this
also Speed Engineering's line is "replace motor mounts" a crock of ****** that is
Yup. Just beat it a lil at a time. Make sure you get some new OEM gaskets.
Because that normally is the problem.
