When I first picked up the truck, the wireless charging would not work with my phone (Google 6 Pro).  Over the next few days, I put my phone on the charger and it would work occasionally.  For the last week, it has been working (although it charges very slow).  Yesterday, it stopped charging my phone again.  After playing with it for a while, I found that the charger will not charge my phone if the battery gets low (30 to 40%).  If I turn off the phone when the battery is low and drop it on the charger, the charger will start working again.
Is anyone else experiencing problems with their wireless charging?
Edited by homermacleod
Add more info
I have new refreshed 2022 AT4 and both of my phone wont charge on the wireless pad, they start charging then stop, does that a couple times then fails with an orange triangle on the screen. 75k on a truck and the tech dont work. anyone else find a fix?
Do you have a phone case that may be potentially interfering. My refresh charging pad works just fine, even with my case.
Edited by jaxcam02
I know on samsungs you have to have the wireless charging turned on on your phone. Did you check to see it is turned on in settings >  battery and device care > battery > more battery settings > fast wireless charging?
This is certainly not what we like to hear, cranetek74.  Please know, customer satisfaction is extremely important to us. Our team would be more than happy to take a closer look into the concerns with your 2022 AT4. To do so, please send an email to [email protected] with ATTN: cranetek74/GM Trucks in the subject line.
Please include your contact information, VIN, a brief description of your concern, and the name of your preferred dealership. We look forward to hearing from you. To learn more about GM’s privacy policy, please visit https://www.gm.com/privacy-statement.html.
Privacy Statement | General Motors
Your privacy is important to General Motors. This Privacy Statement addresses the personal information GM collects and how GM handles that personal information.
www.gm.com
On 9/2/2022 at 8:12 AM, cranetek74 said:
Confirmed Wireless Fast Charging is on. so not sure whats going on.. I guess a appointment at dealer is needed?
I have the same issue with 2022 sierra Denali, I had a 2020 At4 and never had a issue , it’s very frustrating cause you have to remove your case and then make sure it is in the exact place or it won’t charge, then it charges realy slow , spent $99thousand on a sub standard truck even though it is supposed to be a step up from the AT4
I have the same issue with 2022 sierra Denali, I had a 2020 At4 and never had a issue , it’s very frustratingcause you have to remove your case and then make sure it is in the exact place or it won’t charge, then it charges realy slow , spent $90 thousand  on a sub standard truck even though it is supposed to be a step up from the AT4
very disappointed
very disappointed
Snuggles,
Start a case with your dealer, the more exposure this get the faster they will come up with a fix or generate a list of non compatible phones, but in todays technology there should be any non compatible phones.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
