Truck began to start taking a few extra seconds to start up, then finally wouldn’t start up on me. Got it jumped first time no problem. Now it won’t start at all. Put in a new battery, alternator and starter and still nothing. The 40amp IGN A fuse blows every time I turn the key. Still getting power, just won’t start. Any suggestions or help would be appreciated.
When did the fuse start blowing? After you put a new starter in? shakenfake is right, check all the wires in that circuit and make sure there are no shortable or dumpy connections. Worth your time to clean them all up.
Additionally, if that fixes the fuse issue but not the no crank, no start problem there are a few things you can do. First is put the key to the on position, do you hear the fuel pump prime? You can swap equally rated relays around like the fuel pump relay in order to take the relay out of the equation. Another one thats annoying is the immobilizer ring in the key tumbler/ignition switch. The three pin connector on the top of the ignition switch can get touchy and not allow a crank and start. You can pull that connector out and clean up the contacts, and also jam something non conductive in the connector to try and wedge the connector tight in the receiver.
If you have a multimeter, even a cheap one, it can help solve this whole issue.
I appreciate the responses and help from y’all.
I can’t get the fuel filter off, the connections have pretty much rusted together.
I can hear the fuel pump when I turn the key and I also hear a “clicking” in the fuse box when I actually turn key all the way and that’s the only noises/ reactions that I get. I don’t know for sure if the fuse blew after I installed the new starter but after installed I checked and it was blown, I then replaced it with a new one, tried it once and it also blew. The first time I tried starting it up after I finished installing the new starter it did sound like it was going to turn over but then I heard what sounded to be a metal grinding metal so I turned key off quickly.
Sounds like the starter install didn't go right. I'd pull it off and re-inspect.
One problem at a time, a no crank condition will not be resolved by the fuel system, get the cranking condition fixed, then move on to no start or hard start.
Edited by asilverblazer
    • Having bumper and other body damages can be very frustrating, especially as a result of a parking lot collision/bump. Our team wants to learn more about the damages to your truck so we can look into ways we might be able to help. When you get the chance, please fill out our support form with more details: https://s.gmc.com/support-request . A member of our team will follow up with you as soon as next available. We want to get you enjoying your truck to the fullest again.
    • Did you even read this article?   Even the title of the article says "U.S.-Iran Deal Doesn’t Mean a Swift Return of Oil and Gas Flows"   Remember, crude oil prices are based on FUTURE purchases by the oil companies.  Gas prices are based on FUTURE purchases by the station.  This article stated that many of the oil producing nations have to restart their processes to get the oil produced.  Then the oil has to be shipped to wherever.  And it doesn't get there overnight.  And most of that oil is not coming here. Check out this site:  https://afdc.energy.gov/data/10621   A graph will pop up to show where the US imports their oil from.  Notice that there isn't a lot of import from OPEC and Iraq.  Most of the US import comes from Canada. The US oil produces are selling their oil on the open market, which is why the US fuel costs went up.  So you're correct, the US oil companies are going to slow walk the price downward.
    • Having codes and an engine light with no hints on what might be causing it is nothing short of frustrating. How long have these concerns been present? We want to know more so we can look into ways we might be able to help you. When you get the chance, please fill out our support form with additional details on your experience so far. A member of our team will follow up with you as soon as next available: https://s.gmc.com/support-request
    • Knowing the life of your brakes is a highly important status to keep track of. If you suspect your brake sensors need attention, please fill out our support form with additional details on your experience. When did you last take it in for inspection? Our team will follow up with next steps as soon as next available. Please include your username and GM Trucks Forum in the form as well. Support Form: https://s.chevy.com/support-request
    • I just purchased a 2004 Tahoe with 148,******. I used to have a 2006 Suburban that had the push button Auto 4X, 2Hi, 4Hi and 4Lo. When checking out this truck I noticed it had push button but didn’t focus on it. After the purchase when driving home, this is when I noticed it was different and after a little research found out it has the AWD stabilitrak system. I don’t live in an area that requires AWD. I bought the truck to start a new adventure in life with off roading, now that the kids are all grown up. I purchased the truck knowing it didn’t have the G80 rearend but plan on re-gearing to drive on 33s or 35s and upgrade with a rear locker and still be able to tow when needed. Blah Blah Blah Anyway I know am thinking about converting the stabilitrak  to Z71. I know I will have to replace the transfer case. So now the information gathering stage is happening to see if it is worth it. Is the front AWD stabilitrak differential different when compared to a non-AWD front diff? Will I need a completely different front differential or can it be converted? What else should I be considering? I did see something in a video for GMT900 platform with removing the ABS fuse that disables the stabilitrak and turns the truck into a 2 wheel drive. Would that work in the GMT800 platform?
