I have a 2020 SLT 8spd with a single exhaust. I see what appear to be identical trucks with dual exhaust (HDMI exhaust). Why the difference in the two. Is it a option or maybe 10spd vs 8spd. Mine is also a standard bed and most I see are short bed. Maybe that is the difference.
Edited by Megalomegalodon
It's single from front to rear and the split for exit -- for appearance.
3.0L is a straight pipe from front to back -- all cat/scr/dpf stuff is under the hood.
I don't know if all 3.0's are split at rear for exit, but mine is.
Yes, we understood that.
Point is the dual outlet's are not dual from front to back.
I know they are not dual from front to back. I'm just wondering why some models have dual and some have single at the back. My SLT is a 5.3 with a single exhaust at the back. I see other 5.3 SLT models with the dual exhaust at the back. A previous post said it was an aesthetic package. I'll just go with that.
Regular 4x4 or Z71/X31 is the deciding factor.
On LT/RST/LTZ and SLE/Elevation/SLT trims, if you have regular 4X4 you get the single side exit exhaust.  With Z71 or X31 you get the dual exits in the bumpers.
SLT with 6.2s come with the dual with or without X31.
High Country, AT4 and Denali the dual is the only exhaust configuration.
Edited by newdude
I'm none of the above.
2020 Sierra SLT 5.3V8 2x4 with side exhaust. I've seen other of what appear to be the same model visually, but with dual exhaust. I'm thinking it has to do with 4x4 vs 2x4. Thank you all for your input.
So there you go its 2WD.  You've left that detail out until now.
Regular 4X4 have the same exhaust outlet setup that you have.  I have a regular 4x4 truck, has the single exit.
Z71 and X31 trucks have the duals, as do all Denali (2wd and 4wd), High Country (2wd and 4wd) and AT4.
Edited by newdude
On SLT for 2021, the dual outlets are on SLT if it  has 6.2 or if it has X31
Presumably it was similar for 2020
NB5    Exhaust, single outlet                          S       S       S       S       S       --       --
N10    Exhaust, dual with premium tips       --       A1    --       A1    A2    S3    S
SLE and #SB ELlevation --  Included and only available with (X31) X31 Off-Road Package.
SLT -  Included and only available with (L87) 6.2L EcoTec3 V8 engine or (X31) X31 Off-Road Package.
AT4 -  With (PCP) AT4 CarbonPro Edition the exhaust tips will be black.     --       A1    --       A1    A2    S3    S
Denali - dual outlets are standard.
  • 2 years later...
I’m looking to do this on my 2021 - Silverado LT - 1500 2WD truck.  I recently grabbed a bumper in black from a local guy. @newdude thank you for all you do sharing valuable info.
Reading this, I’m starting to think it might be a PITA lol.
The goal was to get a black bumper and chrome delete it. Ended up with the dual HDMI port bumper and thinking maybe I go with a single exhaust.
    White.6.2
    White.6.2
  • Who's Online   3 Members, 0 Anonymous, 672 Guests (See full list)
    • I have never seen GM instructions for the other trucks as per the HD with the 6 speed or the half tons but had got the impression that the HD trucks with the 6 speed were not having the same problem that the 10 speed and pan presented. Also video that I have seen of the HD 10 speed with the gas engine starting in 2024 model year showed that it was a real struggle to even make it work when pulling down hard on the exhaust after undoing the exhaust hanger bracket on the side of the transmission as after all there is little room for the pipe to even go down behind the Y joint as it soon would hit a frame cross member. Also that they had tried just like I did with the gasket off and no way was that pan coming out any way they tried to manipulate the pan. From that as well as the local transmission shop talking about the pain in the rear issue, I was not expecting my pan to come out because GM shows it was not even intended to come out without dealing with the exhaust piping.    It would be nice to claim, here's what you do and its easy to remove the pan guaranteed on any HD truck with the gas 10 speed but dollars to donuts the next guy trying what I did would not have the same luck as the exhaust was just manufactured slightly different and be pissed off at my claim that the pan comes out with no issue. Its more of a try and see if your particular truck might work like mine did .... or not !.
    • Sorry I didn't see this until now, but it works on both the 6 speed and 10 speeds, as well as all the half tons too.
    • Hello, I have a 2018 GMC Sierra 1500 that I recently changed both motor mounts on due to the driver's side being blown out. After replacement I seem to have a steady vibration that I can feel in the pedals and the back of the seat. At this point I'm convinced that the aftermarket "Anchor" branded mounts I used are not performing as well as OE, the only real reason I ended up using the mounts in question was because my local dealers were out a few months to get a Driver's side mount. I've tried "Neutralizing" the mounts according to the motor mount TSB published for these truck to no avail. My trans mount is also in great shape and seems to be absorbing vibrations swimmingly. As far as I can tell there is no issues idling, my idle RPM is steady and I've recently put GM plugs and wires on, however, I have not cleaned the throttle body or intake valves. Any one else have a similar experience with aftermarket mounts? Patience certainly is a virtue that I wish I exercised here. Thank you!
    • I still saw people out for runs, on their bikes/motorcylces, jeeps with the doors off driving around here the past 2 days. I guess we are just used to it here haha.   Tasted like a bonfire the last 2 days.
    • The TCM has to be flashed before it can drive.   If you installed it the way it is, it has the OS (operating system/program) from the 2010 truck you got it from. That will not match with the VIN/OS pair that your 2013 truck has.   You can do the full install. Then tow it to a dealership and they can flash the trucks PCM/TCM with the latest program for your VIN.
