10 minutes ago, Seadaddy said:
recently replaced compressor, condenser, and expansion valve. system is holding refrigerant but still blowing hot air. im
stumped
Does the compressor clutch engage when A/C is turned on? Is the high pressure line hot to touch & low pressure line cold to touch when compressor is running?
My previous truck had an issue where the driver side wouldn't get as cold as the passenger side. Took out the blend drivers blend door actuator, cleaned the contacts and greased the internals and that took care of it. Sounds like you are probably not dealing with a mechanical issue either.
Confirm the compressor is engaging, maybe a temperature sensor is faulty telling the computer it is too cold to run the A/C.
My neighbor had a truck that had lost charge over the years.  He asked if I would be able to recharge it.  I said I'd try.  I vacuumed it down and it held.  So, I put in the charge.  Still no cooling.  Eventually, I took a shot and replaced the dryer, and recharged it.  That fixed the problem.  If the desiccant becomes saturated, apparently it blocks flow and the high side pressure switch limits the compressor engagement.  Most of the guidance I've read says to replace the dryer whenever servicing the system
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
