Does the factory lift give a full two inches or is it "close"? I thought about going this route just for the warranty etc. Thanks.
Full 2 inches.  Its all the components right from the Trail Boss/AT4.
On a crew short (assuming factory tires) that takes your ground clearance from 8.09" up to 10.88" and your overall height from 75.51" to 78.35".  So per those measurements, over 2 inches will be gained in ground clearance and overall height.
IMO the best parts about the GM kit is A) its warranty friendly and B) GM includes updated calibrations for the electronic power steering module and for front facing cameras if equipped to account for the change in vehicle height.  No aftermarket lift kit has such support for that part.
Edited by newdude
Thanks for the clarification. I wanted to make sure Im gonna get at least the 2". I know sometimes folks buy stuff and says 2 but really means 1.5. Wouldnt be cool to spend the money and not get what I wanted. I realize its what makes the AT4 and TB what they are. Now just to find time.....
Funny enough, when I asked about calibrations, the dealer didnt seem to think there were any lol.
Edited by Byrds8
Yea it will come with an authorization sheet and they phone it in to GM Techline who then issues the calibrations.  Dealer then simply programs the modules that GM requests.
18 hours ago, redwngr said:
GM's lift kit for a 2019 1500:
Lift Suspension Upgrade System for 4WD Vehicles
You couldn’t pay me to put Rancho shocks on my truck.
  • Thanks 1
  • Haha 2
Just giving an idea of the number parts and pieces involved.
If I was interested in a taller truck I'd still be running a 2500.
A stock 2500 is still taller than a 1500 with the 2" lift.
Well it came with Rancho shocks stock. I know they suck compared to others.
Yep a 2500 is taller...and more expensive. So may as well just make this one a bit taller :D
Byrds8,
Did you end up going with the GM 2" lift?
People seem to overlook the fact that you also get longer CVs with the 2" lift. Everybody seems to focus on the Rancho shocks but overlook the longer CVs.
I'm likely going to go with this lift to retain my warranty and all the recalibrations. Then, if I ever decide to level the truck as a TB/AT4 I'll already have longer CV's to help with angles.
If the truck already has Rancho shocks does the GM lift replace them with longer Rancho's? If anyone's done this what's the cost parts and labor total?
would like to hear the difference about these also, if anyone out there that can explain differences and why seems only gm worried about this and all the other lift outfits don't?
I'd like to know as well. I don't know the details either but remember reading that they were longer.
I couldn't find any other detailed information on them.
  • 3 weeks later...
I plan on putting this lift on once the 20% off coupon hits. I was quoted $900 for installation plus the cost of the lift kit at my local Chevy dealership. The CV axles issue was explained to me like this: the longer CV axles are important because they allow you to retain (safely) the ability to use the AWD/4HI on your truck after the lift. When you lift your truck a few inches, without doing a differential drop, the increased angle on the short axles causes an increased possibility of failure. Other lift companies actually do talk about this and some caution against using 4hi. I have no real world experience with this.
Thought our newer trucks had the narrower front diff and longer axles then last gen so this wasn’t an issue any more? Also less uca issues due to less angle. Sounds like last gen speak carried forward like an echo to the next gen making assumptions they are the same.
  • Thanks 1
It’s a longevity issue. Especially for a vehicle lifted from the factory with a warranty they have to honor.  Over time and miles, yes, it’s not a bad thing to have.
When I put my TB spec Bilsteins on I kept the original CV’s. They’re fine. When they need replacement I’m going with TB spec axles.
    • Thanks for all that information, I might purchase one and see if it will work for me, if not they may let me return it! Yes for sure the tires are definitely within limit for my truck empty, and when I do tow I'll definitely make sure to raise the rear psi for the amount of weight that's going to be on it.
    • Yes exactly, more and more these days people/companies are afraid of liability issues so its easier just to say no rather than risk putting their neck on the line.    I will say with the Autel unit or when I used it last year on my truck, it wasn't like I could choose the 2025 model year or even the 2024 model year as that option was not there to manipulate the placard pressures but had to go back to 2023 or there abouts and then it showed up as an option, odd but that was how the software was then and I can't say one way or the other now as they throw out updates every so often. I still would talk to your tire dealer though to start with and they may do it for nothing but also they may have a comment on a better unit to purchase. All I know is that one of the large tire shops in my area happens to use these Autel units for their use and set them up to use the wifi and all of that jazz for constant updating because each tire tech has one handed to them by the shop but I just plugged it into my laptop to update it and yes if one is bought it has to be registered so you can get the link to do updates and then the unit has to be updated before its even used. I am not at all techy so it took me a bit but anyway just a heads up for anything you buy, most likely it will need to be connected to a computer to access the internet to have it updated to the latest software version before you can put it to use.   If your truck is near empty, those tire pressures you listed are a very safe upper range pressures to carry the weight, both the front and rear as I know they could be run lower yet with an empty truck. And if its a trailer and not some motorcycle your going to strap onto the front of your truck on a rack, you shouldn't have a need to inflate your front tires if your at 55 front already, its the rear ones that would need more air if you have much hitch weight.
    • Thank you, I'll check that Autel scanner out and see if it will work for me! Ya I can see GM's point of view if they lower the psi set value for someone and the person sell's the truck and the new owner puts the factory tires back on then their could be liability issues cause the psi warning light wasn't coming on when the tires were under inflated for towing their load and then it might be able to be traced back to GM lowering it.
    • I had a similar but different response when I talked to the service manager where I bought my truck in that he said GM corporate won't allow them to lower the placard pressure setting as they would get their hand slapped but that of course they have the ability to make that change. His suggestion was simply go to a tire dealer or third party shop that is willing to reset the pressures lower. However I chose to buy a tpms tool and partly based off of this very forum as it had been proven to work on the 2024 model ( Global B system ) and while I could have paid lots for a full two way diag tool, I didn't want to spend that much and bought the recommended Autel TS 508 and it will reprogram the 2025 model and assume it should do the 2026 as well. However the tool is rather proprietary to reprogramming Autel tpms sensors so that is a function I will never use, where as a real two way scanner would have many uses but also have yearly subscriptions etc where this 508 is free updates for as long as they put updates out for the unit. In any event it worked to lower the placard pressures and I often use it to adjust my actual tire pressures although will check with a mechanical gauge as well sometimes just to make sure that tires tpms sensor isn't lying to me.    My suggestion is either buy a tool that you know will work to adjust the system or start out by getting the tire shop you bought your tires from to reset your truck and if after that you still want a unit to do it yourself, get one at that point.
    • Here is an image of a quick Google search about these tires on my truck and it's exactly same psi recommendation the Toyo tires company gave me!    I'm not looking for anyone else recommended psi or anything, I'm just looking to see if anyone knew a way to get rid of the factory low psi warning light, because I'm not running high psi and ruining my tires when I'm not towing!
