It looks possible to put a block between the axle and the plate under the mono leaf. Just need to size the u bolts. They seam to be 9/16" but it's measuring 3 3/8" between which is not a common width.
IMG_0216.HEICIMG_0216.HEIC
IMG_0216.thumb.jpg.bf2270cce45c723f55a14ef0834355e6.jpgIMG_0217.thumb.jpg.849faa47daeeeb30605410bcd06228cc.jpg
Edited by latreille89
Wonder if it’s a taper block or if I could just use the one that comes with a 6 inch lift kit? Anyone try it on a mono leaf?
  • 6 months later...
Has anyone found a solution to this yet?
Would like to go with a block.
Also will the TB/AT4 leaf springs bolt right up to the shackles on these?
I'm just going to drop these right here because I think they might help somebody.  Find them about 2 weeks ago while playing on ReadyLift's website.  I remembered them while reading this thread.
https://www.readylift.com/rear-u-bolts-for-monoleaf-applications-only-gm-silverado-sierra-1500-2019-2023.html
https://www.readylift.com/mono-leaf-rear-block-kit-6-lift-kit-gm-silverado-sierra-1500-2019-2023.html
You can keep your leafs. There’s a few kits now. Rough country also sells rounded ubolts at 3.25” wide which fit perfect. There’s a 1/4” plate under the leaf that’s 3” wide to give the leafs full bearing for the axle. Keep that. Put a block under it. RC nylon blocks seem to fit well. Yes I know you shouldn’t stack blocks but I’m not considering that plate a block. It has lips and groves to hold it in place. Without it, the blocks are only 2.5” wide which I’m sure isn’t good for the leaf. Do at your own risk.
