I'm really leaning toward this unit.  Looks nice, big, and clean
9 hours ago, 04palass said:
I was actually just researching that one yesterday! This one too
https://www.ebay.com/itm/234939100106
That's a d@mn big screen! I'll be looking into this one as well. I was also thinking about just keeping my stock 8  inch and adding the bypass adapter to watch DVD's on that screen.
My goal is to finally get this rear sliding window wired up next week. I am no expert but there is not a ton of info online about this retro-fit. I have come up with this diagram. I also ordered a universal power window harness to start from. If all goes well I will go in depth so if anyone wants to do this in the future there will be a guide.
Switch diagram that was provided (after I did some digging, the kit didn't come with printed instructions)
https://www.amazon.com/gp/product/B07L162PC5/ref=ppx_yo_dt_b_asin_title_o00_s01?ie=UTF8&psc=1
Annd some pics I took last night for good measure lol
So, I know a while back you had a quick markup attached. I found someone had marked something up on here (couldn’t find the thread I came from so apologies if it is biting off whoever did it) that was basically explaining from point a to b, I was searching for something else and thought of this thread here. I haven’t verified it completely as I am not there yet. But thought it might help.
POWER SLIDING REAR WINDOW INFO.pdf
That is extremely helpful thank you so much!!!!
Had a great road trip, 790 miles got plenty dirty but hey that's what its for
I did give it a quick coin wash after the trip there to get most of the bugs off
  • 5 weeks later...
Success!
Alot of work but I now have a fully functioning sliding rear window! I will do a write up shortly but I used a universal power window harness, spliced it all together and boom she works!
I had trim my rear window molding to fit with the sliding rear window.
I also did some other interior touch ups. When I got the truck it had the plane work truck interior with the matte black dash trim. I added trim from a LT Silverado but I did not know at the time that the Sierra and Silverado LT trim were different until I added the steering wheel. So I got some OEM Sierra SLT dash trim, but that came with an issue. It had the holes for the factory heated/cooled seats which my truck does not. So after some brain storming I decided to use the factory switches that came with the bezel to make it look as factory as possible while using my aftermarket switches.
I found through trial and error this paint matches the factory console metallic gray/black very nicely
I also wanted to do something with the door and console trim, I really like the carbon look on the All Terrain but they are out of stock through GM, so I smoothed my textured work truck trim and wrapped it in some vinyl which looks fantastic I will link it below.
https://www.amazon.com/VViViD-Black-Carbon-Gloss-Realistic/dp/B00YLFSFWA/ref=sr_1_3_sspa?crid=3I38QUGL81LQ5&keywords=gloss%2Bcarbon%2Bfiber%2Bvinyl%2Bwrap&qid=1691428419&sprefix=gloss%2Bca%2Caps%2C111&sr=8-3-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&th=1
Edited by 04palass
2 hours ago, 04palass said:
Success!
Any photo's of dash trim ??
Here is a side by side showing the difference (if that is what you mean). The Silverado is a more glossy/metallic silver. The Sierra is a low gloss almost stainless steel look.
Yes the Denali has more of a bronze/silver look and the SLT was all Silver. I had two 2018's.  One was a fully loaded SLT. And now I have the Denali. The Bronze/Silver has grown on me. I just can't stand the wood grain door handle and console trim.
In my never ending quest to dress up this truck I ordered some chrome speaker bezels. They look nice but fitment was terrible would not recommend them. But after some massaging they came out nice.
Can't resist a photo op
Scored some winter wheels! 18's from a 2020 Tahoe but same as any K2 Silverado.
Also ordered brakes next will be tires for the wheels, unfortunately time to start thinking about winter
On 9/19/2023 at 4:12 PM, Bowtie01 said:
Where did you find the paintable fender moldings?
I used my factory ones, I sanded down the texture and used a really good adhesion promoter
    Randy Ginoza
    Randy Ginoza
  • Who's Online   4 Members, 0 Anonymous, 2,015 Guests (See full list)
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • Just don't turn the steering wheel as much?
