25 minutes ago, richard wysong said:
with the warnings and the scanner not connecting it's pointing toward a BCM or buss problem possibly because of a bad ground. There have been numerous posts of similar problems and I don't believe anyone has posted the cause or cure,PLEASE when you figure it out post the fix! Reading past posts I believe there is a ground splice pack up high in the dash on the left(?) side that has the grounds for the buss network. Hopefully someone more knowledgable than me will chime in here
Thanks Richard! You've given me an additional area to check!
UPDATE:
 I removed the starter relay and jumped it out, engine turned over. Also swapped out the relay with another.
Still won't start though via the ignition.
I guess that rules out the battery and starter?
look at the video posted by BlaineBug under popular forum topics. check the body and frame for ground voltage drop
  • 5 weeks later...
So without seeing a wiring diagram I would guess the wire from the relay to the starter must be broken, I would check it at the starter as that would be the most common trouble area. Are you sure you jumped the correct terminals at the relay and there was 12v at the relay?
I had something similar with my truck while it was under warranty.  It was the datalink wires shorting together up near the rear tire.
The key switch is wired to the BCM and it has to tell the ECM to engage the starter relay via datalink.  If those two aren’t talking, it won’t crank.  I also had all the dash messages you have along with an outside temp reading of -40 (it was around 60 F then).
This theory also aligns with your observation that a scan tool will not connect.
Thanks for that info! I need to scour that area again but It was tough due to the harness being sandwiched between the frame rail and bed. Gonna take the wheel off this time to look.
Which side were you having trouble on? Driver rear or passenger?
I finally end up taking the truck to the dealership and it's been there since 11/1 and they're just telling me "we're working on it". Sounds like I need to prepare for some expensive news.
Thank you!
My datalink short was right at the terminating resistor on the drivers side.  You should be able to check this datalink circuit by measuring resistance from Can H to Can L with the key off and all harnesses/modules plugged in.  There should be a 120 ohm terminator at each end and they are in parallel.  A good reading will be around 60 Ohms.  I believe you can check it at the DLC under the dash, but I don’t recall what pins.
OK, just spoke with the dealer and after 29 days, they have diagnosed my truck with a shorted HMI module.
I gave them the ok to repair at $1500. Ugh.
Once I got home, I had the opportunity to look up the module and found them for around $300. Zeesh......that's why they're called the "stealership".
Oh, after the dealer told me the price, he still tried to upsell me on a cabin filter and wipers!
Hopefully she will be fixed soon!
I was confused as to how a module that controls the radio and navigation prevents the truck from starting but, the video explains how there's a "network", a sort of LAN that ties into the ignition circuitry.
I wish I knew about this video before authorizing the dealer to complete the work but, quite honestly, when it comes to these computerized vehicles, I don't have any way to check for dead modules.
28 minutes ago, robert24b said:
This explains it better than I can
https://youtu.be/227dndw46JY
@pgamboais always a font of electrical information when it comes to these trucks! I have bought a few harnesses from him and he's very responsive and helpful.
harnessdr.com
Edited by MikeBMW
    • I started with a folding cover by BAK PAC on my 2500. It went bad after close to 5 years. Bent and vinyl coming loose. Contacted BAK and they gave me a very good discount on a Revolver. Had it a number of years. Mostly outdoor storage. Some garage storage. Vinyl started to come loose. Still under warranty so they replaced to cover. Sold the 2500, bought the 1500 and got another revolver for it. Had it a couple years now and no issues. I store it indoors. Got a bit of discount when buying it as well. If you are seeing problems, contact BAK or real truck and let them know. Customer service was pretty good. But I think they changed their warranty.
    • Its possible you never had the joy of the crappy boat launches we tend to have around here or really some of them are just grades down to the river if its a river scenario and the conditions change all the time with the river levels and silt deposits. Some of the lakes we went to years ago, there was no such thing as a cement pad that went down into the water that the trailer stayed on, it was gravel maybe up to the water line and then duck crap much beyond that so sinking the boat tires into mud. Of course some of the more established lakes had a cement bar type boat ramp but sometimes it was covered in green slime closer and certainly within the water and a two wheel drive had all sorts of fun if one had to touch that slime with the rear tires.    A neighbor of mine had made a comment years back with his chev truck that was probably about the same year as yours but a half ton extended cab 4x4 and he a a fiberglass boat with an inboard so it wasn't a feather weight and he had gone out to one of the large popular lakes in the area and don't ask me how this happened but he was in two wheel drive as he figured he didn't require four wheel drive for that boat ramp and somehow upon pulling the boat out he twisted one of his drive axles. I suspect it must have spun and then grabbed on the cement ramp and shocked it to the degree of twisting it. He would have had the standard 8.5 or whatever it was axle housing as the 9.5 ring gear like my truck has also has larger drive axles as far as I know. Anyway he was feeling a vibration driving home and had it checked out and a shop found that the tire/hub was wobbling because of the axle had twisted so in went a new drive axle. After that bad experience he said he made sure to put it into four wheel drive to lower the stress on the rear axle. Of course that is where an HD truck can handle a lot more stress and no doubt these newer half tons with their larger ring gears probably have larger drive axles as well to match vs back in the day.
    • Desirable - as in does someone WANT one, aspire to have one. Could reasonably buy any car they want and CHOOSE these instead.    I didn't watch the video, why did they win?
    • The use of absolutes like "always" to describe gear selection, and giving free advice at a boat ramp sounds like a recipe for disaster. It's a boat ramp, not a farm, for starters.   IMO gear selection should depend on the obstacle. If low range is working and this is a slower speed, controlled ordeal, I'd keep using that.
