Black smoke = normal.  GM DI V8 engines double pulse injectors during cold starts and its more noticeable when its colder ambient temperatures.
1 hour ago, Big_Kahuna said:
Wind chill feels like -20  al night .
You and your dog might feel it being -20°F, but your truck and house doesn't. Wind chill will cool your truck down faster to the ambient temp, but never lower.
Exactly right, wind chill is only felt on living things.
If you're concerned I suggest using better oil for cold starts. Amsoil Redline
  • Haha 1
I have right now castrol edge EP gold, seems to be doing goods have redline coming I will be changing as soon as a get it and ill be sending a sample of my castrol to blackstone
Another reason to use well formulated clean burn fuels. Good luck determining that.
Edited by customboss
20 degrees? I would love that. We haven't been above zero now for 8 days straight.  🙂
Edited by wurgs
I don't buy the concept that our gas/fuel is poor quality. I have never had an issue with any motor that I could blame bad gas/fuel.
I have always used a major brand gas/fuel, not the discount joints. Also for the last 10 years Top Tier only.
I also use fuel system cleaners regularly.
  • Confused 1
🧐     You must if you don’t use discount gas?
Why regularly use fuel system cleaners?
I agree with you. At least the part where you use best quality fuels and adding cleaners to remove the crap deposits they leave.
    DM22
    DM22
  • Who's Online   1 Member, 0 Anonymous, 2,793 Guests (See full list)
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
