There is a T1 pics thread going, but with the rarity of the crew cab and standard bed (long bed) compared to the short bed, let's get a thread together to see pics; this was we don't have to dig through hundreds of pages just to find this particular setup. Pure Z71 has one of the most prominent CCLB trucks but let's have others with that post. Stock, leveled, lifted or even lowered, just post them up here. I am leaning more and more towards this bed when it comes times to replace my current truck so would like to see how some of these look in different trims and set ups. I don't have one so I can't contribute but let's see them.
Tyler
Sorry, I wish I had a photo to share. My only regret on the truck I ordered last year is that I didn’t get the standard bed. Silly. I get by OK without it but I often find myself wishing I had the extra space.
To the best of my knowledge, the long bed (8') was only available in regular cab configuration.
Crew cabs had the choice of short bed or standard bed.
Edited by cwtech
spelliing
Tyler
CCLB would be a 2500/3500.
Short bed is only available on 1500 crew (not available on 2500).
Standard bed is available on both 1500 and 2500 crew
Long bed is available on 2500 crew (but not 1500 crew)
I know a long bed isn't the same as the standard bed, but most people use that term when referring to the different lengths. That is why I put both in the name as this is the half ton (1500) section. The Crew Cab only has two bed choices, short and standard in the half tons; but historically people interchange the terms short/regular and long/standard, so I put both in there. People also us the acronym CCSB for the short bed and CCLB for the long bed instead of having to type it all out each time. So standard bed would also be CCSB and that acronym wouldn't work now...
If it makes everyone feel better, I can rename it to just standard bed and hope no new members think the standard bed is the short bed that most everyone has.
Let me know what you all think, and I can change it. Just trying to get pictures in there so people can see different set ups with the longer, err I mean standard, bed.
Thanks LAAC for the pic, it certainly looks longer at some angles.
Tyler
Appreciate the kind words.
This is my first truck and when I was shopping for it, the bigger bed just made since as it was about the same price and added more storage. So far, I've never had a setting that I wished I had the short bed (still fits in parking spots, malls, fits in the garage still, etc).
Here is our 2022 Silverado Crew Cab 1500 LT with the standard bed before putting a shell on it.
It was only $300 more to go with the standard bed when I ordered mine. I was going to go with it, but the dealer said it would delay getting it built because they batched them together when they built them. I don't know if the Indiana plant built that configuration or if it was only the Mexico plant. I opted out of it since I have a 6x12 enclosed cargo trailer if I need to haul really large items that won't fit in the short bed. The parking spots in WA must be longer than here in MI. My truck with the short bed just fits in most parking spots and most of the time my bumper is hanging out.
My 2022 with the standard bed was built in Indiana.  While we did not order it, it was one of very few within a few hundred miles.  When I took it to get the cap put on, the manager called the truck a unicorn because of the scarcity of standard and long bed trucks.
    • If it has a stick I can have fun with it. When my wife first got her Acura years ago I used to tease her about it. I was only interested in muscle cars. They’re gone now. So once a month I drive the Acura. Every once in a while I’ll take it to Redline. But just normal driving on some twisty back roads usually does the trick.
    • I went through again with a test light and everything checked out.    I suppose it could be the MAF itself but I've tried 3 different sensors, 2 of which were in running vehicles previously (the one in this truck, and the one in the donor truck), as well as a new one I picked up from NAPA. I would just be surprised if all 3 were bad.   EDIT/UPDATE: I swapped in the MAP sensor that was originally with the 2010 PCM, that made the code for map sensor voltage high Go away, and the map sensor seems to read normal with key on engine off (14psi or so), but it still doesn't run and does the same thing as before.
    • In addition to a cell or wifi connection, the infotainment needs to be enabled to download software updates. That's a toggle within the system settings.   But...if the truck was prevented from receiving updates in a past life, missing a bunch of updates may mean it won't go back and download all of those because they're not available or the system is too far out of date.   If a formal recall depends on a software update, the recall for that truck remains in an open status until it's applied. The dealer would need to apply the software update in that instance.   Most updates downloaded and applied via the infotainment aren't recalls/safety recalls, they're enhancements and usability fixes which aren't critical.
    • Recently I've been getting a message, "New Brake Pads Detected. Reset Brake Pad Life?", But I haven't had the pads replaced and the truck only has 28,000 miles. The Brake Pad Life shows Front 64% and Rear 79%. I select NO to resetting the brake pad life and the message goes away but comes back at the nest restart.   I stopped by the dealer and was told that it sounds like a software glitch that would require reprogramming. Even though I have the extended warranty, they tell me that reprogramming is not covered unless a module was actually bad and needed to be replaced. Simply reprogramming is not covered. So, they want $200.00 just to diagnose the problem. If it turns out no bad module, another charge on top of that to do the reprogramming. If the cause was an actual bad module, everything would be covered under the warranty.   Just wondering if anyone else has had this problem. Should this issue be covered under the warranty?   Thanks
    • NHT is diesel only, correct.     The GVWRs for NHT on 3/4 ton bring them to the same numbers as many of the 2WD 1 tons.  A crew 4x4 standard 3/4 with NHT is 11,750lbs, a 1 ton same cab/box/4x4 is 12,100lbs.     Hubs and hub bearings are the same for 11.5" and 12" axles.  Housing, diff carrier and ring/pinion are larger for the 12".   All gas use the 11.5" axle, 3/4, 1 ton and 1 ton DRW.
