Any one here running the 115t at3 here on the 20 in wheel? what tire pressure are you running?  I got some on my truck and they look a little buldged out at the bottom. Dont know if thats normal for these tires . Thank you
If a redundent post plese delete
Not running 20" rims but 40psi in the front and 35psi in the rear is what i am running on my 17", there is more weight in the front (unless im towing).  When i buy some 18 or 20" take offs ill probably end up running the same.
In hind side I should’ve got LT tires instead of p rated. Just didn’t want to run the added weight. I don’t tow anything more than a zero turn.  When these wear out I’m going e rated lol
If these are stock tires there will be tire pressure information on the drivers side door jamb. If not the tires should have recommended PSI info on them as a starting point.
  • 10 months later...
On 1/19/2023 at 2:45 PM, Jglew82 said:
285/60/20 @ 40psi
@Jglew82 do you have any rubbing or trimming with that size? I have a trailboss with the diesel and need to get rid of the noisy Goodyears and like the look of that size on your truck.
No trimming and no rubbing whatsoever.
