Greetings. I just recently (last couple of weeks) picked up a used 2019 Silverado LT 2wd.  I’ve noticed that the auto start stop has never activated. I’m not getting any error messages and I don’t have a check engine light. I’m guessing the battery may be the issue. If the battery is from the factory, it’s probably just getting old. If the previous owner replaced the battery, maybe he didn’t replace it with an AGM battery.  I posted a couple of pics of the battery, just wondering if anybody can tell if this is the original battery or if it looks like a replacement. I’m not seeing any brand labeling on the battery, just the warning label on top.
Edited by MadMatt3883
Added text.
7 hours ago, AntonyU21 said:
It is recommended to ask a professional mechanic
I’m not spending money to fix this. If it’s an easy fix I’ll do it, otherwise I’ll leave it alone.
1 hour ago, silveradosid said:
battery has nothing to do with the auto stop, start. previous owner might have an auto start stop delete installed in the truck
Are you talking about the aftermarket cable installed behind the switch?
Have you ever checked to see if the truck has an aftermarket tune. I'm betting thats your answer
Actually, the battery has a lot to do with the auto stop/start.  If the computer detects that the battery voltage is low, it will not allow the auto stop/start to function.  This has happened on my Silverado and Traverse.  Both times I had to have the battery replaced.  Problem solved.  One way to test, which I did on the Traverse, was to connect a battery charger to the battery and let it charge overnight.  Then for the next several days the auto stop/start worked.  After that, it quit working.  After a few weeks of driving it around and it wasn't functioning, I took it to the dealer who confirmed it was the battery.
I know a lot of folks on here hate the auto stop/start, but I look at it as the canary in the coal mine.  When it stops functioning, there is an issue with the electrical system.  Could be the battery, could be the alternator, could be the current/temp sensors, etc.  Just my opinion....
It could also be like the others have posted above, the previous owner did something to disable it.
Edited by PhilB
No. What type of ODB scanner would I need for that?
My money is on the battery. I was hoping someone would be able to recognize my battery as being factory or not factory. When I have time I’m going to take it to autozone and have the battery tested.
Edit:  pulled the top cover off. Factory battery. Now I have a check engine light after disconnecting the battery lol.
Added pic.
If you've exhausted the battery and it's not the cause,  you'll need to find a tuner to look if the truck has been tuned. The dealer can also look at the tune counter and tell you. Simple obd scanner won't tell you anything.
When I get a chance I’m going to test the battery.  That battery is 4 years old now.  I’m in south Texas and down here car/truck batteries suffer from early deaths due to the heat.
Could have been a loose connection that corrected itself when you removed and reinstalled the battery cover.  Just a thought.  IIRC, there was something about the bolts that hold the connector board in the battery cover that needed tightening.
Keep us updated.
Here is the entire possibilities list of why the auto stop would disable.  I bolded a few candidates that are either somewhat obvious reasons it wouldn't work, and some not so obvious inhibiting reasons.  The auto start disable list is about identical.
I don't see where these trucks use it per the description and operation, but some of the earlier stop/start that GM used had some sort of an internal timer counter or something that the dealer can go in and reset.  Chances are if these use the same thing, you pulling the battery reset the counter.
Autostop Disable Reason - Transmission Range
Autostop Disable Reason - Passenger Compartment Heater On
Autostop Disable Reason - Driver Exited Vehicle
Autostop Disable Reason - 12V Start Counter Exceeded
Autostop Disable Reason - Vehicle Inclination
Autostop Disable Reason - Remote Vehicle Start Request
Autostop Disable Reason - Acceleration Request
Autostop Disable Reason - Transmission In Reverse
Autostop Disable Reason - Reduced Engine Power Active
Autostop Disable Reason - Ignition Switch Start
Autostop Disable Reason - TCM Request
Autostop Disable Reason - System Optimization
Autostop Disable Reason - System Voltage Low
Autostop Disable Reason - Engine Coolant Temperature Out Of Range
Autostop Disable Reason - Catalyst Test In Progress
Autostop Disable Reason - HO2S Test In Progress
Autostop Disable Reason - Misfire Test In Progress
Autostop Disable Reason - Catalyst not at Operating Temperature
Autostop Disable Reason - Intake Manifold Temperature Too High
Autostop Disable Reason - Engine Speed Test in Progress
Autostop Disable Reason - MAF sensor Test In Progress
Autostop Disable Reason - MAP Sensor Test In Progress
Autostop Disable Reason - Engine Oil Temperature Too High
Autostop Disable Reason - Engine Stop/Start Test in Progress
Autostop Disable Reason - Engine Coolant Temperature Test In Progress
Autostop Disable Reason - EVAP System Test In Progress
Autostop Disable Reason - Fuel Injector Test In Progress
Autostop Disable Reason - Fuel Pressure Test In Progress
Autostop Disable Reason - Fuel System Test In Progress
Autostop Disable Reason - Parking Maneuver Detected
Autostop Disable Reason - High Engine Rotating Torque
Autostop Disable Reason - BARO Pressure Too Low
Autostop Disable Reason - Fuel Temperature Too High
Autostop Disable Reason - System Malfunction
Autostop Disable Reason - Turbocharger Temperature Too High
Autostop Disable Reason - Hood Ajar
Autostop Disable Reason - ECM Request
Autostop Disable Reason - Run/Crank Not Active
Autostop Disable Reason - Minimum Engine Run Time Not Met
Autostop Disable Reason - Control Function Active
Autostop Disable Reason - Auxiliary Transmission Fluid Pump/Accumulator Not Available
Autostop Disable Reason - Engine Coolant Temperature Out of Range
Autostop Disable Reason - Invalid Data Received
Autostop Disable Reason - Vehicle Speed Too High
Autostop Disable Reason - Transmission Fluid Temperature Out of Range
Autostop Disable Reason - Brake Pedal Released
Autostop Disable Reason - Brake Booster Weak Vacuum
Autostop Disable Reason - Accelerator Pedal Pressed
Autostop Disable Reason - A/C Request
Autostop Disable Reason - Low-Voltage Battery Voltage Low
Autostop Disable Reason - Low-Voltage Battery State of Health Low
Autostop Disable Reason - Low-Voltage Battery State of Charge Low
Autostop Disable Reason - Low-Voltage Battery Discharge Current High
Autostop Disable Reason - Intake Manifold Weak Vacuum
Autostop Disable Reason - Engine Speed High
Autostop Disable Reason - Wheel Slip Detected
Autostop Disable Reason - Vehicle Speed Threshold Not Reached
Autostop Disable Reason - Maximum Vehicle Stop Time Exceeded
Autostop Disable Reason - Starter System Malfunction
Autostop Disable Reason - Stop/Start Select Switch
Autostop Disable Reason - Idle Boost Mode Active
Autostop Disable Reason - Generator Load High
Autostop Disable Reason - Low-Voltage Battery Temperature Out of Range
Autostop Disable Reason - Low-Voltage Battery State of Function Low
Edited by newdude
  • Thanks 2
I found the issue. There’s no problem. The transmission fluid temperature isn’t hot enough. Unlike my previous truck (F150) the transmission in this truck heats up real slow. My daily commute to work is about 17 miles one way and is mostly highway.  The hottest the fluid gets on one leg of the commute is about 115-135.  I noticed when the fluid gets to about 165 is when auto start/stop begins to engage. In my case, that hardly ever happens.
    RSTRICK
    RSTRICK
  • Who's Online   7 Members, 0 Anonymous, 627 Guests (See full list)
    • Coming back from towing a car to my daughter in Nashville truck started making a screaming noise from underneath.  Pulled over placed in park and sure enough whining noise from underneath.  Dropped at the dealer fearing new tranny or another front pump/cover replacement.  Service writer said it sounded like the tranny too...  Well $300, new idler and a belt all is good.  Pop the hood and give a listen. lol  Now I'm telling dealers I'm no longer interested in a new truck.
    • HD uses the 6.6 gas.   Oil consumption while heavy working is considered normal.  1 quart per 100 gallons of fuel is the normal rate above 8600lbs GVWR.  If more than that, it is considered excessive.   They will have to perform an oil consumption test using the guidelines in TSB 03-06-01-023J.     Information on Engine Oil Consumption Guidelines All engines require oil to lubricate and protect the load bearing and internal moving parts from wear including cylinder walls, pistons, and piston rings. When a piston moves down its cylinder, a thin film of oil is left on the cylinder wall. During the combustion process, part of this oil layer is consumed. As a result, varying rates of oil consumption are accepted as normal in all engines. Oil Consumption Oil usage has a direct relationship with the amount of fuel used. The harder an engine works, the more fuel and oil it will use. Therefore, oil usage as a factor of fuel usage is a more accurate indicator of acceptable oil consumption levels than vehicle mileage for vehicles at or above 8600 GVW. The accepted rate of oil consumption for gasoline engines in vehicles at or above 8600 GVW is 1 liter (1 qt) within 400 liters (100 gallons) of fuel used. This rate only applies to vehicles under warranty, maintained in accordance with the appropriate maintenance schedule, driven at legal speeds and within design intent of the vehicle. Many factors can affect an owner's concern with oil consumption. Driving habits and vehicle maintenance vary from owner to owner. Thoroughly evaluate each case before deciding whether the vehicle in question has abnormal engine oil consumption. Gasket and External Leaks Inspect the oil pans, engine covers, and the engine oil cooler for leakage. Inspect for oil leakage into the engine coolant. Improper Reading of the Oil Level Indicator (Dipstick) The vehicle must be parked on a level surface to obtain accurate oil level readings. Verify that the dipstick tube is fully seated in the block. When checking the oil level, make sure the dipstick is wiped clean before taking an oil level reading and fully depress the dipstick until the shoulder bottoms out on the dipstick tube. The dipstick should be the proper part number for the engine/vehicle that is being checked. Not Waiting Long Enough After Running Engine to Check Oil Level The vehicle should be allowed to sit for at least 15 minutes, after the engine has been shut off, before taking an oil level reading to assure the oil has had enough time to drain back into the crankcase. In order to ensure accurate results, the temperature of the oil should be close to the same temperature as the last time the oil level was checked. Improper Oil Fill After an Oil Change Following an oil change, verify that the proper amount and type of oil was put in the engine and that the oil level on the dipstick is not above the full mark or below the add marks. Refer to the Owner's Manual or Service Manual for information on recommended oil quantity, viscosity, and quality. High Speed or High RPM Driving Continuous driving at high speeds/high RPMs may increase oil consumption. Because this may not always be an everyday occurrence, it is hard to determine exactly how much the oil economy will be affected. Towing or Heavy Usage Towing a trailer or hauling additional weight will increase oil consumption. Large frontal area trailers will further increase the work required from the engine, especially at highway speeds, and thus increases the rate of oil consumption. PTO Operation Operation of a PTO will increase fuel and oil usage, as the PTO driven accessory uses engine power to operate. Crankcase Ventilation System Verify that the positive crankcase ventilation (PCV) system is operating properly. Blockages, restrictions, or damage to the PCV system can result in increased oil use. Oil Dilution from Condensation On vehicles that are usually driven short distances, less than 8 km (5 mi), especially in colder weather, condensation generated from cold engine operation may not get hot enough to evaporate out of the oil. When this occurs, the dipstick may indicate that the oil level is over-full. Subsequent driving on a trip of sufficient length to enable normal engine operating temperature for 30 minutes or more, in order to vaporize excess moisture, may give the customer the impression of excessive oil consumption. Engine Temperature If an engine is run at overheated temperatures (see Owner's Manual or Service Manual) for more than brief periods, oil will oxidize at a faster than normal rate. In addition, gaskets may distort, piston rings may stick, and excessive wear may result. Verify that all cooling system components are in proper working order. Engine Wear Piston scuffing, excessive piston-to-wall clearance, tapered or out of round cylinders, worn, damaged or improperly installed valve guides, seals and piston rings will all cause an increase in oil consumption. Measurement of Oil Consumption Engines require a period of time to BREAK IN so that moving parts are properly seated. Therefore, oil economy should not be tested until the vehicle has accumulated at least 6400 km (4000 mi). An exception would be allowed only if an engine is reported to be using more than 0.946 liter (1 qt) in 1600 km (1000 mi).   Verify that the engine has no external leaks. Repair as necessary. Verify that the engine is at normal operating temperature (see Owner's Manual or Service Manual). Park the vehicle on a level surface. Wait at least 15 minutes, after the engine is shut off, before checking the oil level to make sure that most of the oil has had time to drain back into the crankcase. Check the oil level and record the vehicle mileage, date, and exact oil level on the form included in this bulletin. Next ensure the oil level is at, but not above, the full mark on the dipstick. add oil if necessary. Also ensure the proper viscosity and quality oil are being used as recommended in the Owner Manual Ask the customer once they have consumed 100 gallons of fuel schedule an appointment and return to the dealer for inspection. If the final evaluation shows that the engine uses more than 0.946 liter (1 qt) in 379 liters (100 gallons) of fuel used, follow the published symptom diagnostics as described in the appropriate Service Manual. If the oil consumption test shows that the engine uses less than 0.946 liter (1 qt) in 379 liters (100 gallons) of fuel used, explain to the customer that their engine meets the guidelines for oil consumption.
    • I have a 2024 Chevy Silverado 2500 with the 6.2 liter engine, Vin: 2GC4YME79R1273849, with 27,437 miles. Recently we took a trip from Candor, NY to Townsend, TN pulling our fifth wheel, when I got close to the Townsend, TN area The truck gave me a message of low oil. I checked the dip stick and found it was 2 quarts low. Today, August 27, 2026, I had the oil changed and the technician Found the truck was very low on oil.  Is there a Recall for this? What is my recourse for this issue? Do I call the dealer where I bought it or any chevy dealer?   Robert Strickland 292 Owego Road Candor, NY 13743 352-502-6588 [email protected]
    • We understand the importance of understanding how your Sierra performs, @SoCal Angler. Our team would like to gather the proper details to assist you with your inquiry about your truck's automatic braking. When you have a moment, please visit: https://s.chevy.com/support-request and fill out the request form with pertinent details. This will ensure your request is routed correctly so we may take a further look. We will keep an eye out for your outreach.
    • That is the funnel kit I bought and for being here in Canada I did get a better deal than what other sources were charging through a certain supplier in town that sources more directly and they ordered it for me. There are other items now on the market which would be perfect as well but this has worked well which was the hope when I bought it. I mentioned the Amsoil quart bottles as they have that squarish shape up top and it props nicely on the rim of the opening without falling into the funnel so I can leave them sit and drip a bit. You may have already figured out that to get the cap off the valve cover unless one is 7 + feet tall its not going to be reached without standing on a step of some sort and so when I do that I put the right adapter in and just leave the elbow on the funnel all the time anyway and open the lid and then if using quart containers for sure I can stand beside the truck and leisurely add the oil, and I can leave that funnel on when starting the engine to let it idle to fill the filter and then add the rest of the oil to top it up before removing the funnel and putting the factory cap back on. I put the cap back on the top and slide the bottom cap on as it fits onto the elbow adapter also and then store the funnel in a clean household plastic garbage bag along with the adapter so I have no reason to be washing out the inside of the funnel as I keep it completely clean between uses.    Draining the oil as per the under the truck portion, yes indeed that is slick as someone was thinking on GM's part there and admittedly I don't drop the oil screaming hot in this truck due to the exhaust being there and makes it safer as far as the oil temp if its just warmed up some instead as I don't have the truck on any ramps etc as I do it as the tires sit on the garage floor. The filter is not boiling hot then either and can drop it off into another pail after pulling the drain plug and just leave it drip out. Go back under a few hours later with new filter in hand and clean off the filter base and put the new filter on and install the drain plug. The filter is a little cramped in there as per wrapping ones hand around the filter and I am so used to using the band style filter removal tool that its no big deal and same for snugging it up. My filter wrench is many years old now but I think this is the current version and sounds like the right size, just in case my explanation was not great ( those nylon strap wrenches that one tool fits all filters are not my favorite tool to use, I much prefer this style personally )     57020 Swivel Gripper - No Slip Filter Wrench - Small | Lisle Corporation   And again about the oil draining and filter setup under these GM trucks, I've watched Ford videos of them struggling with oil flying sideways out of the oil pan on the gas 7.3 due to the sideways drain plug onto other components or cross members and guys trying to make shields out of carboard etc and other Ford pickups that Ford insisted they have sideways drain plugs. One win for GM there anyway with this engine.
