Hello, I have a 2006 Silverado 5.3. 140k
About 1000 miles into my last oil change I noticed a lifter tick and the oil pressure was reading 20(usually it would read 40 during driving). The oil pressure also started to drop with higher rpms instead of increase.
So I changed my oil and filter and did an engine flush because it seemed like oil flow was being clogged with something.
After the oil change everything was better and I was back at 40 psi and it would increase with throttle.
But this only lasted 400 miles before going back to the 20 psi.
I took it to a shop and they diagnose it as a bad lifter and to me it doesn't seem like a bad lifter would be causing the low oil pressure, to me it seems like the low oil pressure is causing the lifter to tick.
Any ideas? I don't have the money to replace a lifter and not fix the truck
Many many posts on this problem in the archives. Watch the utube posted by maddog820 on Jan 6,good info there. It may be the orings on  the pickup tube are allowing the pump to suck air. Probably not the lifters so good call there. Some oils rapidly lose their viscosity so you may want to try changing brands of oil and filter, I like Castrol and ACDelco filters both available at Walmart
You are correct with your thinking that the oil supply may be impeded where the pressure drops with rpms. Possibly the screen on the pickup is clogging or just the bad orings. Where the engine flush helped it may be time to drop the oil pan and investigate
Thanks everyone I was using mobil synthetic oil and an ac Delco filter, I think I'm going to say not to replace the lifter and just drop the pan and clean it out /replace the pickup tube o ring and see what happens, book time on that has to be a hell of a lot less than replacing a lifter
There are posts of modifications made to the pick up tube to cure the oring problem if you search the archives. Mobil1 is good oil so not likely the problem.
Edited by richard wysong
Richard Wysong, I've been getting oil changes at the dealer with their Dexos 5-20 oil and their PF48 filter (even though last oil change I told them to put on the upgrade filter....UPF-48r or PF-63.  Anyway, they just put on their standard PF48).  I'm thinking about doing it myself now.
I have 3 questions:
1. Does Castrol make 5-30 Dexos synthetic oil?  (I used Castrol conventional oil on a 94 GMC 4.3 and got 484k miles with it)
2.  Do you recommend the UPF-48R or PF-63 filters over the PF-48?
3.  I too had an issue once with low oil pressure dropped to 21 at any speed.  I changed oil & filter and oil sensor and it solved that.  Now I get 40 and around 25-30 at idle.  I too have an occasional tick sound "sometimes" but then it goes away.  My independent mechanic said forget it -- his Chev had it sometimes too.
I do not know if Castrol paid GM  for the dexos licence but would not hesitate to use it as I'm sure it meets or exceeds dexos specs. Lots of Gm trucks have the tick that comes and goes and even the dealers will tell you don't worry but if it is under warranty I would demand they fix it before the warranty expires. As far as filters I believe the UPFs just have different filter media so no preference. Castrol conventional is what I run in all my vehicles, if I run Walmart brand oil in my 98 the pressure drops after about 1000 miles and I am guessing it is because the viscosity stabilizers are spent. I do NOT want to start an oil war here again so will just leave it at that
Mechanic said that 20 psi is more than enough and it isn't worrying him and that if the psi was too low all the lifters would be ticking.
I asked why it stopped after a fresh oil change after it went back to 40psi and he said he didn't know, also asked why throttle was making the psi go down he didn't know.
Book time to drop the pan and do the pickup tube is 3.5 hours so like 400 bucks I dunno if I should just have them do that but he said it's not going to do anything.
Might be worth trying tho since replacing a lifter is going to be $$$$ they said they'd have to take the whole engine out but I don't know if that's true
Drop the oil pan and replace the pickup tube O-ring.  Had the same problem with my 05 Tahoe (same engine).  Replaced the O-ring and oil pressure is back up to 40+ psi and lifter tick is gone.  You're looking at about $40 for the oil pan gasket, $5 (if that much) for the pickup tube O-ring, and a few hours of your time.
sounds like you need to find a new mechanic if he is not familiar with the problems you are experiencing
Wouldn't hurt to pull the pressure sender and replace the screen under it too. Those sensors are known to fail and the screen under them clog too. Reasonably cheap and I would consider it a maintenance item on these engines.
Had them do an engine flush and oil change and all is good now back to 40 psi and no lifter tick.
If it drops to 20 psi again I'll probably drop the pan and check out the pickup tube
There is no screen on non AFM engines.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
