On 4/5/2023 at 1:30 PM, DDogg said:
I'm at 230 000 km on my 2015.  It's clunky (especially when I put it in reverse) but still doing the job.
Had the same thing and this might sound wierd but ive been pressing the brake way harder than normal then changing into reverse and have not have it happen since… i thought something was seriously messed with it but more brake pressure seemed to work
  • Thanks 1
  • 4 weeks later...
I'm at 260 now and its still going!  I'll try the brake trick, but it clunks whenever it hits the lower gears.  Higher, not so much.
  • 2 months later...
Up date nearnig 400,000 miles just started to occasionally  to cunk shifting between 1st and second  gear. Last service they wanted to replace  temp sender. Passed on that will run it tell it breaks
We'd like to take the time to celebrate this impressive milestone with you for your 400,000 miles. To do so, please send us an email to [email protected]. We will watch for your email.
  • 2 months later...
I have 72,000 on my 2018 , trans is getting rebuilt as we speak ($5500) thanks GM for the warning. Would have changed the fluid to Mobil 1 if you had warned me. 3 GMCs  in my driveway 4th will most likely be a Ford
My 2017 8L90 6.2 Z71 just passed 132k. I did have a few hiway speed jolts prior to downshifts about 500 miles ago. Into the dealer now for diagnostic. Only 15k miles since fluid and filter change.
  • 5 months later...
On 6/5/2023 at 10:51 PM, SuperOldSchool said:
130k on my 2015 8L90.
fluid and filter changes every 45k.  New temp sensor/harness at 100k.
Now at 151k.  Plan to do a fluid suck and fill (no filter) in spring.   Have changed fluid at 45k, 89k, 100k (temp sensor) and 130k.  At the 130k (30k on fluid), magnets were clean and fluid was nice and red, thus just going to do a quick 5-6qt refresh in a few months…
I did install the Sure Cool STL010 at 130k, so that should help the fluid’s longevity a bit…wish I had put the thermostat on long ago..
Data point: 145K on our Yukons. Had the fluid changed at 90K for its poor shifting manners, with little change.
It still works, but it is by far the worst GM transmission I've ever experienced. Out of... dozens with all over 100K and many over 200K. Only one rebuild in the mix.
I wish this one would fail so that it could be rebuilt, if I were convinced changing mechanical parts would alter its behavior and shift quality.
    d.lowrey
    d.lowrey
  • Who's Online   3 Members, 0 Anonymous, 1,253 Guests (See full list)
    • Fix one problem and find another.   Truck didn't have a thermostat in it so I flushed out the system today and refilled with 50/50 Dexcool. This truck is so old (LOL) that it has a sticker under the hood alerting people to the fact that it contains such. There is also an orange supplement with the owner's manual alerting the owner that "Your vehicle is one of a number of late production 1995 General Motors vehicles that use a newly developed engine coolant in the cooling system..."   I was still a little flummoxed by what seemed like a rich condition (exhaust smell, and a puff of carbon with a punchy rev). While watching the coolant temperature and testing the thermostat with my scanner, I happened to notice the IAT (incoming air temperature) to the intake was -40F. I know the temp is below average today, but I can still feel my face, and I was wearing shorts.   D'oh!! I realized I had never plugged the IAT back in, and the airbox was out while I was doing coolant. So I paused, reinstalled the airbox and plugged in the IAT, and viola. Things cleared right up, and I watched the coolant temp climb to a reported 198 degrees on the scanner (195 thermostat) and then it dropped to 194 (open) and then back up to 198 and held. Let it cool, came back, checked the coolant level and was satisifed.   Victory lap?   It needed more than the couple of gallons of gas I put in it from almost bone dry, so I ran it up to the gas station. It had earned it, or, at least I was pretty certain I wouldn't be draining or removing the tank anytime soon.   CEL popped on just as I was cruising a nice steady 40mph, just after coasting down a slight downhill curve.. Of course, it did, because, why let me enjoy not having dash emojis for a little while.   I just happened to have the scanner plugged in. I don't text and drive but I might scan and drive. Don't tell the police.   P0401, EGR flow insufficient.    Well, hello, EGR... ...my old friend! Welcome to the party, now that the engine reaches the factory-programmed operating temperature. I'm sure it was gagging on hostile, rich exhaust and carbon this whole time so I'll take it off and look again.   At least it's easily accessible, and worst case, about $65 to replace.   To keep, or to sell... Hmm. I want it running correctly either way. It's easier to sell when there are no fault codes.   It needs tires (they're aged out and cracking)   It could probably use an oil pan seal, or maybe the timing cover gasket/ junction with the pan needs redone because I've got an issue there that leaves a drop of oil on the floor.   If I do tires I'm sure they'll say the ball joints could use freshening, and, and, and, and.... At some point I'll have to stop. I can't (shouldn't) make it perfect, that's not what this rig is.
    • Take it back. That's about all you can do.  Mark
    • Gloss black would look better, but I'd paint match the grill before ditching the chrome bumpers.
    • Mine has done that since new. The colder the worse.
    • Yeah, that's my understanding. The newer trucks are 433Mhz vs the older 315Mhz TPMS. Putting these wheels on is costing me a small fortune, but so far, I'm still OK with it.    Next week the chrome bumpers are scheduled to be replaced with flat black ones. That would complete what the dealer still owes me.
