Hello I am new member to the sight and I was looking for some advice to this issue. Recently purchased a 2020 Silverado 4x4  45,000 miles 5.3 motor with 8 speed transmission. Never noticed when I test drove it but when I first take off after it sitting all night, transmission like slips or hard shifts between first and second gear. Only on the first take off. The next take off it is fine, but it does it every time I take off after it sits all night. Anyone experience this issue? I read some things about fluid change. Not sure about this but seems more like possibly electrical or software issue. I let it warm up first and it makes no difference. Heck I had a 2000 Silverado for 20 years 200k miles and I don't think transmission fluid  was ever change. Never an issue. A little nervous because warranty has expired and not sure if this is covered under powertrain warranty. Thanks for any help on this issue.
  • Sad 1
Pull the trans. dip stick and smell the fluid. Does it smell burnt? Wipe the stick off on a white shop towel or paper towel. Is the fluid clear or does it look dirty? If dirty or burnt you should change the trans. fluid, That said dirty or burned fluid is usually only a symptom and not a cause for transmission problems. You should take it to a dealer, leave it overnight and have a mechanic test drive it cold with you. The powertrain warranty should cover the transmission but the dealer will ultimately have to decide.
common with the 8 speed, my 2020 also will do this first thing on the morning. i remote start mine for a couple minutes and then put it in reverse for 5 seconds before i put it in drive, seems to help
Just wondering if yours did this since it was new? Or did it start after more miles where put on the truck?
I will check fluid color and smell, probably just go a head and change fluid it does have 45k on it. I have no record showing it being changed. If this is a regular occurrence, its's very strange that it only does it on the first shift sequence. If I would have felt that when I test drove it I would have parked it back in there lot. Just hoping I didn't buy myself a nightmare. Thanks for your response's
Had/have this in a 2017 Camaro 8 speed, and its showing up now in a 2023 GMC Sierra 8 speed. Not much the dealer will really due, there was a TSB for the Camaro years ago, flush and fill trans fluid, but it can and does come back.
It is always on the first start and drive of the day, you need to really have a light foot to get rid of most of it.
Edited by GOMD
Not a good selling issue, but if that is all it is, I can live with it. Just seems kind of crazy that GM can't get this ironed out. I was reading they had the newer ones straightened out but if your 2023 is doing it as well, I guess not. Thanks for info.
Just put my 2014 in, going to be  $1500 - $4500 depending. I was told they were notorious for this kind of failure.
Edited by octobers fade
Welcome to the #1 normal issue on the 8 speed.  First 1-2 shift of the day, the clutch pack that handles 2nd gear is rather large and the fill time is a bit longer than the other clutches for the first time its shifted into.
Silveradosid posted a great link via GM explaining it.
Fluid fixes the shudder issue, not the 1-2 first shift.
Thanks for all the info. This eases my mind a bit to find this is a common issue and it is not transmission failure.
This is certainly not what we like to hear, Brian Wegher.  Please know, customer satisfaction is extremely important to us. Our team would be more than happy to take a closer look into the concerns with your 2020 Chevrolet Silverado. To do so, please send an email to [email protected] with ATTN: Brian Wegher/GM Trucks in the subject line.
Please include your contact information, VIN, a brief description of your concern, and the name of your preferred dealership. We look forward to hearing from you. To learn more about GM’s Privacy Policy, please visit https://www.gm.com/privacy-statement.html. The information you provide may be monitored and recorded and is subject to the GM Privacy Statement.
Privacy Statement | General Motors
Your privacy is important to General Motors. This Privacy Statement addresses the personal information GM collects and how GM handles that personal information.
www.gm.com
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
    • This is for those over 70 years of age contemplating joint replacement surgery involving general anesthesia. Even some 55 yrs. ago when I took my pharmacology class the dangers of developing dementia in the elderly that had general anesthesia were beginning to be recognized. Over the years there has been some refinement in the cautionary warnings, avoid general anesthesia if possible if you've had close to 10 priors, especially over the age of 70 and/or a family history of dementia. I'm not including the twilight anesthesia induced by propofol often used in cytoscopies or colonscopies. Seriously think about seeing a neurologist and undergo cognitive testing before proceeding if any of those criteria apply to you. Spinal anesthesia may be an option in some cases. I'm in the above camp and although I could use a new right knee, I get fidgety according to a prior orthopedic surgeon when the bone saw spools up or maybe it was the smell of saw blade meeting bone, anyhow I may have one general anesthesia left in me which I will pocket for now and I'm choosing mind over mobility, anyway where did I leave my damn cane!
    • We understand your frustrations with your auto start/stop, fuel gauge and cruise control concerns since your latest update, @LarT-26. You mentioned getting repairs completed, however, have your concerns been resolved? If not, we would like to learn more so we may explore the best path of assistance moving forward alongside your local dealership. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
    • We understand your frustrations with being unable to open your Sierra’s top inner tailgate, @smitty81503. Your concerns are frustrating, and we would like the opportunity to explore the best path of assistance to pursue their resolutions. There are many different factors that could be the root cause of vehicle concerns, and we handle each one on a case-by-case basis. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
