Thank you!!!!!! Looks like I have something to do this weekend. I did remove the bracket so looks like I just have trimming to do.
Looks good, reminds me of a bigger 2024 canyon at4. Where did you get the wheels? They look like OEM. Put me down as interested in the daytime running lamp mod if you do ever want to sell them.
On 5/26/2023 at 7:29 AM, GM90 said:
It was really smoky in those yellowish pictures.
Good looking setup. Amber DRL's very unique and set's it apart. Can you share the parts used/links and a write up on making this. Wouldn't mind taking a stab at this.
On 5/27/2023 at 11:25 AM, GM90 said:
I guess ya, if there's enough interest. I can manually make these, bu they are time consuming and parts are expensive. especially the PCBs.
They are cheaper to make in larger quantities, and instead of locally, they will be 1/4 of the cost if they are made in China.
I'm making two of these for my buddies but they're eating up the cost and labour.
Very impressed! I think there would be a pretty decent interest in these. I have a Refresh LT Trail Boss and would be very interested in this mod (I thought the Global B architecture would make this impossible) and it should function the same as the Sierras.
I'm really loving the amber lights. I think a plug and play harness would be a big seller.
Good business opportunity for the plug n play module. If it's something you want to tackle! A lot of stress involved.
Fair pricing can be tricky for both the builder to cover time, and parts for development, and customer.
Not opening up headlights: Win
Not having to deal with sealing headlights again: Win
Not having to send them somewhere and have weeks of downtime: Win
Not voiding warranty: Win
Still using OEM lighting: Win
I bet with some additional programming (maybe?) you could get the turn signals to be sequential.
I wonder if something like that would be applicable to the refreshed Silverado DRL lights?
Edited by jashaw
  • 3 months later...
  • 5 weeks later...
Would you be able to make me one or share exactly what you did?
On 5/26/2023 at 8:54 PM, GM90 said:
I saw that these trucks had full amber lights and wanted to use those as DRLs. I looked online and found only few options:
One was to bake the headlights in the oven and take them apart and replace the white DRL Led strip with yellow one. This is too much work and chances of getting it right are pretty slim. For me at least. Not to mention no more warranty on headlights.
Other option was to replace it with aftermarket headlights, but those are all junk and look very cheap with very dim dotted DRL LEDs.
I opted to design my own little circuit board that controls the function of these DRLs.
The circuit board I made is very small and compact, about 4x4in. The weatherproof case is about 6x6in. And for it to work you just unplug the harness from the headlight and plug this in between and you get amber DRLs which you can change with a switch in the cab.
It was a lot of trial and error and spent a good amount of money on versions of different PCBs that had to be printed and after a few revisions I got it working. And the OEM harness plugs were hard to find initially but lucked out and found em online.
I made it plug and play, because I didn't want to hack or modify any harnesses or headlights and maintain the warranty on those items. GM is notorious for voiding warranty for stupid ******. This way I can just pop these modules out before I bring it for a service.
What the PCB does is, when its on, the DRL signal to white LED stops and in its place the amber LEDs light up. The hard part with designing the circuit was retaining the turn signal and hazard lights functionality along with the amber DRLs. And making it all work with the turn signal feedback loop.
When the PCB is off, then it acts as a pass through, like its not even there. Then everything works in factory mode as GM intended.
Is there any way you could show some pictures or maybe even a diagram so I can try and replicate this on my AT4X
On 4/7/2024 at 11:28 PM, Juan Salinas said:
I will buy one from you. I need it for my HD though. Sen you a pl
What year is your HD? Should be a pretty simple hack. I’ll go through it this week and update everyone that is looking to do the amber drl. I went from 2021 to 2024 Front end on my 2500 still in the process not quite done yet lol
Edited by Dbeto54
    • 87 down as low as $5.14 here... winning!
    • Progress... sort of.   Intake is disassembled, spider is out, fuel lines removed. Used a torch on the stripped screw with the lower intake off, much easier when I've got the intake sitting on my workbench, I made it talk. Walked right out with a pair of vice grips once it was nice and toasty hot.   New parts are piling up on my service cart waiting to be installed. Distributor, temperature sensor, new gaskets, fuel line kit, themostat, water neck.   My new pickle is I don't want to spend $600 on a replacement spider. I'm not sure IT is bad. I'm probably splitting hairs. Or it's $300 to send mine away and another 3 weeks of the truck just sitting. I have half a mind to assemble everything with the old spider to see if I can get away with just replacing the fuel pressure regulator to be safe. The obvious issue was the gushing high pressure fuel line which will be replaced. Getting to the spider really isn't that hard, and now I know what I'm doing , swapping it would be a breeze should it absolutely need one. Stupid, or smart?   The part that gives me pause is replacing the distributor. Well, it's already out. And I didn't mark it, whoopsie! Engine was at TDC when I removed it, I know that, so upon correct reinstall the metal tip on the rotor should point to the TDC mark on the distributor because that's where it was pointing on the old distributor. Worst case I'm a tooth off and have to re-stab it.   But then, what? I assume the truck will start. It doesn't appear the timing can be set. Here's the problem: These distributors can't be rotated but a degree or two, by design. What I read is Cam ****** needs to be -2 to +2 degrees, ideally at 0 (and checked/set above 1000 rpm). There should be enough wiggle to get that properly set, but checking the reported value is another potential issue. My Actron 9185 scanner says it supports enhanced GM PIDs and Cam ****** is one of them but it's unclear that I'll be able to correctly see it over OBD 1.5. I can see why people end up junking these things with life left in them. They're an absolute nightmare with tweener-year diagnostics/electronics and unobtanium parts.   Fingers crossed it starts and idles nicely. There can be hope, right? I'ma buy a lottery ticket the same day just in case.   Next steps..DO IT. I have not installed an intake before so I've been reading and watching a lot. Some say NO RTV except on china walls, some say DO RTV on water ports but not fuel/air intake. 1/4 or 3/8 bead on China walls? I think my strategy will be, obviously, RTV china walls with overlap on the gasket corners. Chapstick-style RTV the water ports. Leave intake ports dry. The only set of intake gaskets I could find locally are Edelbrock performance gaskets (uh...for an asthmatic 190hp V6? LOL) so we'll see how they do.   #NoToolLeftBehind. It took an hour, but my recovery mission for my deep 10mm socket was successful. It had rolled down the bellhousing and wedged itself between what I think are the fuel lines? I couldn't see it at all, but with a junk antenna I had laying around, I blindly went poking/sweeping for it, heard it clink, raised the truck, and caught a sliver glimpse of chrome with a flashlight way up there in Narnia. I had pushed it farther along the lines holding it captive, but within access of severely improvised tools, poking and cursing at it to finally knock it free to where I could get a fingertip on it to bring it home.    Not much to see.
    • Thats crazy considering im right next door (Indiana)
    • For a limited time, retail and commercial accounts receive an AMSOIL Vinyl Tool Tray with their order of $500 or more when they use code TRAY726 at checkout. The promotion runs through July 21, 2026.   Order at https://syntheticadvantage.com   Want to use AMSOIL in your business or sell at your store, apply here.  https://www.amsoil.com/business-opportunities/?zo=521390
    • It wouldn’t have happened if the government hadn’t mandated outrageous fuel mileage standards. It does very little for the consumer. It adds cost. Back during Covid there was a chip shortage. They gave a rebate for your truck if it didn’t have the chip to turn on cylinder deactivation. It was 50$ because at best you may see 1/2 a mile increase per gallon. Splitting hairs each fuel mileage trick wasn’t mandated. The government doesn’t do the engineering work and say use this until it’s already in use and they like it. The fuel mileage was mandated. And those add ons the results. There’s a mandate and they are the results.
