1 hour ago, Doodle said:
Another update on mileage.  I took my 24 on a 600 mile roadtrip all highway this past week.  I was fighting a little wind from time to time (I live in Kansas) but I was traveling between 69-80 depending upon if I was on the interstate or state highways.  I noticed once you get above 70 mph mileage really starts to drop.  At 80 I was getting about 14-14.5 roughly.  At 65-70 closer to 16-17.  Think my average tank was about 15 or so on that trip.  Kind of disappointed in the mileage at interstate speeds as it’s holding 10th gear fine, but also realize these things sit way in the air and are heavy.  On one flat stretch I put it on 60 mph cruise just to see the difference and it was closer to 18-19.  Only 7K on it so far.  My 23 started to get a little better around 10K so guess we’ll see.  Also the first tank of fuel I ran was 89 octane.  Just wanted to see if there was a difference.  I guess I’d say there was no noticeable difference.
yeah, that exponential resistance factor over 70 MPH is a real pain for us lead-footed individuals.
To be fair I don't think my LML would do much better than 17-18 at 80 mph.  In my area diesel is approaching $1.50/gal more that gas.  So it's still cheaper to drive the 6.6 gas than the diesel right now.  Kind of glad I have both.  Just let the LML sit unless I need to tow heavy.
I know it’s apples to oranges but have found with my 1500 trucks with 5.3/6 speed/AFM/Double cabs/ARE cap gets their best mpg at 55 to 60mph driving like a sane person. Once you start hard acceleration to pass, etc., all bets are off. I drive 2 lane roads in VT 75% unless going out of state.
When my AT4 2500HD gasser arrives, I will drive it like my 1500 for the same trips to check mpg. In town trips will suck but I think that goes for any truck.
Yeah there are so many factors when it comes to mileage.  Every blacktop road around here is minimum 65 mph.  We are flat and wide open in western KS.  Nothing like Vermont.  If I drove 55 here I'd feel like a snail!  I also live at 3500' elevation so that makes a difference too, but the flat geography does help mileage.  Where I live there are essentially no hills and what we might call a hill people back east would laugh at.  No such thing as "steep grades" here.  Ha ha.
State speed limit here on 2 lane roads is 50mph unless marked otherwise. Interstate is 55 or 65. I generally drive 5 to 7 over unless in town and use cruise control when conditions allow. I’m retired and not always in a big rush! 😀
You should get great mileage.  I live in Arizona where 80 mph in a 65 zone is considered "keeping up with the flow of traffic."
so cal too, 90 is normal but wont get too far before traffic of some sort.....full throttle or zero
I averaged 13.8 with my 2023 gas that is somewhat combined highway and some city.
I also just installed a Borla S-Type Cat Back exhaust and hoping to gain at least a full mile per gallon.
Next step is to put an S&B Cold Air Intake to gain another mile per gallon.
Between the two add on's- if I can end up with 16 miles per gallon I'll be tickled pink.
Best interstate mpg at 65/70 was 19, so not too bad.
I live in PA so it's quite hilly here..
I am surprised by some of the numbers you guys are getting with the 2024's and the 10 speed. I thought the mpg would have been much better?.
I'll keep you all posted on any gain after I put the S&B Cold Air Intake on.
sorry man. lofty expectations that are not going to be realized
  • Like 5
I assume these are the MPGs from the onboard computer. Have you run a few tank fulls and calculated the MPG yourself from miles between fill ups and gallons to refill the tank?  My truck's computer is consistently 11% high on the reported MPG. When I calculate it myself, the number is quite lower.  And it is consistently like this, on every fill up.
I think GM is messing with us, trying to make us think the MPG is much better than it really is.
My 22 is damn near spot on.  I checked it and checked it numerous times, the dash reading was either .1 up or down.  I don't check it anymore...lol..
Cool. And my '22 is way off. But I don't really care. I calculate my own and I know what it is.
Peace.
Peace.
And why that is who knows.... different tire sizes maybe?
Edited by Jettech1
My lie-o-meter is anywhere from .8-1.2 mpg off from hand calculations. I would have to say it is the least accurate I have ever had of any of my vehicles.
That doesn't sound all that bad compared to what I've seen on other vehicles I've owned.
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
