I'm trying to find out if the old TPMS sensors (like on a 2021) can be read by the new TPMS trucks (like on a 2023)
I had a set of AT4 take-offs that I ran during winter on my 2021. (during 2021, so before the new sensors were released)
Trying to learn if the sensors in them can be read by the 2023 TPMS system.
If they can, I'd expect that the tire fill alert and auto-learn will not function.
I have a teach tool that I can use with the old sensors if that can help get the job done.
Accessories shows they do have the same description and frequency
but they are physically different and of courses also different part numbers.
2021
2023
Can anyone shed any light on using the old sensors on a 1500 with the new TPMS system?
38 minutes ago, bwoodsmn said:
No, they are different and are not cross compatible.
bwoodsmn is right the sensors from the 2021 will need to replaced with 2023 sensors to work on your new truck. When I got my new Trail Boss I had to install new sensors in the 20" wheels from my 2021 T.B.
Yea, you need the new ones.  They are totally different sensors.
The old ones may or may not synchronize during a manual relearn (with a relearn tool) but will immediately drop out once you start driving.
The old sensors are considered a "manual" learn sensor.  You need to trigger them to the truck in order to sync them to the truck.
The new sensors so 2022 refresh and newer 1500 and 2024 HD are an auto learn sensor.  You rotate or install a new sensor, and the truck will automatically learn it to the truck and its position on the truck for rotates, etc.
Both operate on 433mHz frequency but have different operating protocol past that (GM Global B/GM VIP), so the auto learn 433mHz won't work on a 2019-2022 LTD, and a 2019-2022LTD sensor won't work on a refresh 2022 and newer 1/2 ton or 2024 HD.
Edited by newdude
Thanks everybody.
I suspected that was the case, but wanted to verify.
Getting ready to put the winter shoes on....
Edited by redwngr
  • 10 months later...
Ha .. I have the reverse question.  Can 2024 sensors work on older years .. mine is a '21.  I purchased 2024 GM takeoffs that has brand new sensor and want to install them on my '21 Denali. Im not concerned about the self learning position as mine doesnt have that software. I just want the pressure to work. If not I will be selling them
Thanks
I would look up both on Rock Auto and see if part numbers are the same.
Thanks
No.  This was answered a couple posts up too.  They will learn and then immediately un-learn because the sensors are changed in their operation.  Same frequency but they don't work the same way because of the auto learn change.
You need the 19-22 pre refresh sensors.  13528563.
Quote
Edited by newdude
    • Conditions for Meeting a Cold Start   The ignition voltage is between 10 and 15 V. The barometric pressure (BARO) is more than 75 kPa. The engine coolant temperature (ECT) at start-up is less than 42°C (108°F). The intake air temperature (IAT) is between 2–32°C (36–90°F). The engine is OFF for greater than 6 hours or the following conditions must be met: The start-up IAT minus start-up ECT are within 12°C (22°F). The start-up ECT minus start-up IAT are within 50°C (90°F). Fuel level is between 25 and 75 %.   Circuit/System Verification Verify that all I/M System Status indicators report YES, and that no I/M Test DTCs are present.If any I/M Test DTCs are set Refer to Diagnostic Trouble Code (DTC) List - Vehicle. If no I/M Test DTCs are set All OK. Inspection/Maintenance (I/M) System Set Procedure   Warning: Refer to Road Test Warning. Note: Do NOT touch the accelerator pedal until told to do so. A change in TP Sensor angle or an increase in engine speed may invalidate this portion of the test.   Note: An I/M Test DTC will not be stored or erased from the ECU except at the end of trip processing, which occurs 5 s after ignition OFF.   Ensure that the vehicle meets the conditions for a cold start listed above. If the EVAP I/M System Status indicator displays NO, perform the EVAP Service bay test if applicable. Turn OFF all of the accessories; HVAC system, other electrical loads, including aftermarket/add-on equipment, etc., and open the hood.   Set the vehicle parking brake and ensure the vehicle is in park for automatic transmission or neutral for manual transmission.   Start and idle the engine for 2 min.   Close the hood, release the parking brake and Accelerate at part throttle to 72–80 km/h (45–50 mph) with this speed maintained until the engine reaches operating temperature, 8–10 min.   Continue operation under these conditions for an additional 6 min.   Accelerate at part throttle to 90 km/h (55 mph) with this speed maintained for 2 min.   Release the accelerator pedal for at least 10 s. This will allow the vehicle to enter the decel fuel cut off.   Safely stop the vehicle, with the engine in drive for automatic or neutral with the clutch pedal depressed and parking brake applied for manual. Allow the vehicle to idle for 2 min.   Shift the vehicle to park for automatic and neutral for manual. Turn OFF the ignition and exit the vehicle. Do NOT disturb the vehicle for 45 min.   Observe the Inspection/Maintenance (I/M) System Status with a scan tool. All of the I/M System Status indicators should display YES.   If the EVAP I/M System Status indicator displays NO, turn OFF the ignition, ensure that the vehicle meets the conditions for a cold start, and repeat steps 6-11 three more times, or until the EVAP I/M System Status indicator transitions to YES. If the indicator continues to display NO, refer to the Inspection/Maintenance (I/M) System DTC Table to identify the DTCs that did not run.   If any of the I/M System Status indicators display NO, refer to the Inspection/Maintenance (I/M) System DTC Table for the indicator which did not display YES. The I/M System DTC Table identifies the DTCs associated with each I/M System Status Indicator.   Observe the I/M Test DTC information with a scan tool. Verify there are no I/M Test DTCs present. If an I/M Test DTC is set, diagnose the DTC using the Diagnostic Trouble Code (DTC) List - Vehicle and refer to Inspection/Maintenance System Check.   Observe the engine DTC information with a scan tool. Verify no DTCs are present. If a DTC is set, diagnose using the Diagnostic Trouble Code (DTC) List - Vehicle. After repairs, perform the Inspection/Maintenance Complete System Set Procedure to verify no further DTCs are set.       Looks like one procedure to me.  Repeated as necessary.
    • My 2020 AT4 6.2 has had the valve spring issue addressed at ~200 miles, front cover/pump replaced at 18k, water pump at 34k and idler pully at 65k.  I would agree with ditching by 100k unless you elect to go with upgraded hardware...say built 10l80 and an lt4 or l8p swap.
    • I also need one of your modules for my 1993 chevy c2500 7.4 Thanks! My email is [email protected]
    • Chevy needs to do a black regular cab short box SS model with the new 6.6L.  400SS.
    • You might find the drive cycle you need somewhere on charm.li (website), otherwise I suggest a subscription to alldata.com to get them for your truck.
