Head lamp and flashlight in the center console.  Easier to get light exactly where I need it.
Out of curiosity, does anyone know when was the last year on the upper level trims they stopped providing the under hood lights?  I'm wondering if it was fairly recently, and the hoods are the same, and whether that lamp can be retrofitted?
i remember when my 96 silverado had the under hood light that could disconnected and be pulled all the way to the bed.
x2, thankfully someone said the easy button before me on this one 😉
infinitely more versatile, these are gm 1500's, we don't need to spend much time under the hood, certainly not enough to do more than a headlamp in the glove box, which comes in way handier for gutting deer or looking elsewhere under vehicle etc.
On 10/24/2023 at 7:14 PM, lapoolboy said:
Nice.  I just wish the OEM would still put an underhood light like they did 10 years ago in even the cheapest of cars.
Back then they were using mercury switches.  That's not allowed anymore.  Besides, vehicles are allegedly more reliable today, except for F150s lol.
Loop is magnetic and can be adjusted to direct light as desired. (yes, there is a lot of plastic and aluminum to avoid)
Comes with usb cable so it can be recharged (in the truck).
Could be used for underhood, roadside tire change, etc...
Edited by redwngr
3 minutes ago, DHBWA said:
Never been a headlight user although I see the advantages…..
For under the hood I still prefer a light like this.
Never used a headlight either. Ever since  I tried one I realize that they are very useful to put light right where you need it.
I have really learned to appreciate them even though they look kind of geeky.
Pickup trucks the last year they had one was 2002.  Yes, its been THAT long.
Edited by newdude
    DM22
    DM22
  • Who's Online   4 Members, 0 Anonymous, 2,202 Guests (See full list)
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
