Tried replacing my reverse light bulb today.
Someone said you can't because they're led's, and I didn't know what he meant.
But it appears to be one sealed unit that you cannot replace bulbs on.
Is a bulb replacement really going to cost $500+ (I'm guessing).
No you cant replace the bulb on your 23 Denali. It sucks but LEDs are supposed to last for many many thousands of hours.
We will see.
There is no bulb to replace.
Edited by newdude
8 hours ago, steve8 said:
I was wrong about price.
ONLY $230!
Absurd!!
Well alrighty then, get two of them so you have a spare. 🤭
To be clear.
I get it. It's a sealed unit and you cannot replace a bulb.
But if your brake light bulb part fails (used most often) you're on the hook for well over $200.
This is an improvement?
Not imo.
32 minutes ago, steve8 said:
To be clear.
Not imo.
Keep going.  Retail price on one single OEM tail lamp is $698.28 for a 2023 Denali.
  • Sad 1
I’ve seen them for $200/ea now that Ive looked in a few places.
still crazy.
still crazy.
You aren't finding a new one at that price, that's for sure.  If you are, not OEM.
Edited by newdude
Curious.  Do the 2022+ Refresh have a different taillight assembly than the 2019+ ? The 2019 New Body to 2022 LTD you could change the reverse light bulb to led but nothing else in the assembly.
Yes, but, OP has a Denali.  Denali has had full LED tail lamps since the T1 came out in 2019.
Ah ok.  Learned something new.  Thanks!
My '23 LTZ has LED tail / brake lights but a normal incandescent reverse light bulb. I installed CAN bus LED's in it, no issues in 18k miles now.
    DaleB
    DaleB
  • Who's Online   7 Members, 0 Anonymous, 1,139 Guests (See full list)
