Tried replacing my reverse light bulb today.
Someone said you can't because they're led's, and I didn't know what he meant.
But it appears to be one sealed unit that you cannot replace bulbs on.
Is a bulb replacement really going to cost $500+ (I'm guessing).
No you cant replace the bulb on your 23 Denali. It sucks but LEDs are supposed to last for many many thousands of hours.
We will see.
There is no bulb to replace.
Edited by newdude
8 hours ago, steve8 said:
I was wrong about price.
ONLY $230!
Absurd!!
Well alrighty then, get two of them so you have a spare. 🤭
To be clear.
I get it. It's a sealed unit and you cannot replace a bulb.
But if your brake light bulb part fails (used most often) you're on the hook for well over $200.
This is an improvement?
Not imo.
32 minutes ago, steve8 said:
To be clear.
Not imo.
Keep going.  Retail price on one single OEM tail lamp is $698.28 for a 2023 Denali.
  • Sad 1
I’ve seen them for $200/ea now that Ive looked in a few places.
still crazy.
still crazy.
You aren't finding a new one at that price, that's for sure.  If you are, not OEM.
Edited by newdude
Curious.  Do the 2022+ Refresh have a different taillight assembly than the 2019+ ? The 2019 New Body to 2022 LTD you could change the reverse light bulb to led but nothing else in the assembly.
Yes, but, OP has a Denali.  Denali has had full LED tail lamps since the T1 came out in 2019.
Ah ok.  Learned something new.  Thanks!
My '23 LTZ has LED tail / brake lights but a normal incandescent reverse light bulb. I installed CAN bus LED's in it, no issues in 18k miles now.
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • Checked the pads today and there's plenty of meat on them. If the message keeps coming up, I'll just answer YES that the pads were replaced and wait for the squeal.
    • Welcome to the Forum! Always post the code definitions along with the codes. there are over 18000 possible codes, no one remembers them all and most will skip over your post rather than look them up
