I think I have identified what is causing my adaptive cruise to intermittently turn off.  It appears to only happen when I am driving toward the Sun.  The light must reflect in the camera and cause the issue.  The seat vibrates and the adaptive cruise is unavailable for a while.  The cruise will work off and on when the Sun is in my face.  Has anyone else had this issue and what is the resolution besides driving west in the morning and east in the evening?
Yes I've had this happen. Usually able to go back to adaptive cruise in less than 30 minutes.
Mine does that. Noticed it happening when going towards the sun. More often when going up hill. Apparently the sun aligns with the lane keeping cameras and the distance sensors causing them to shut down. Seems to reset in about 3 minutes.
Mine will 'disable' when sun is low in the sky and vehicle is driving into it.
Same sun conditions that make it difficult for the me to see down the road.
Have you thought about checking if there's a firmware update for your car's adaptive cruise control? Also, check out the settings - there might be an option to calibrate the camera. Sometimes, doing that can help with the sensitivity to sunlight reflections.
  • 10 months later...
Anyone else had an issue where ACC seems to be working, letting me cycle though the distance gaps and even shows the car in the heads up display, but does not slow down when approaching a vehicle?
I just purchased a 2019 high country with 92,000 miles and used ACC for the first time this weekend but it never seemed to work correctly. I was following my wife and I kept coming up behind her and having to slow myself down like normal cruise control. HUD would show a car out in front of me further out, and then jump to a red car really close almost like it just recognized it the last second. But the brakes never engaged or changed on its own. I’ve not experienced it automatically breaking randomly like some people have. Mine is the opposite. It doesn’t break on its own at.
after the trip, I did have some bugs over the front of the camera, so I’m going to clean those off and try again to see if that’s part of the problem. But I’m sure it was clean when I started since I cleaned the windshield before leaving.
Are you sure it has adaptive cruise?
(iirc, the first year for ACC was 2020, but could be wrong)
Forward collision alert / following distance indictor also has gap setting and shows vehicles ahead.
(following stuff and Lane change alert has been around 8 or more years)
If it has adaptive cruise it can be switched between adaptive cruise and regular cruise and will indicate which is active.
KSG should be the RPO code of you want to verify by scanning the QR code on the sticker at the bottom of the doorpost.
For 2025 model year KSG is standard on HC, optional on LTZ, ZR2, LTTB, RST, 1LT version of LT and WT.
Not available on Custom, Custom TB or 2FL version of LT
Edited by redwngr
Thank you.I’m pretty sure you’re right. I got out the book to review everything and there’s nothing that says adaptive cruise. It just looks like adaptive cruise. The button or icon actually is crash avoidance or something like that. While it’s sad, it’s also less frustrating. Thank you for responding.
Edited by Zambodi
Happens to me all the time when sun is low in the sky and I am driving towards.  Noticed that back in 2021.
My ACC will shut off usually due to ice or camera obstruction.  Nice feature though.
I bet it's not a 2019 (or earlier) model
and yes. crap in front of the windshield camera will make it kick out.
I'm not sure if there is a way to obstruct the lidar..?
Adaptive cruise and HUD are on my list of favorite options.
Edited by redwngr
    • While waiting for parts I have been working on installing the AC compressor, new accumulator, and orifice tube. Also changed out the high side ball valve (original). The orifice tube that was in there wasn't too bad. Slightly dirty, a little bit of junk, but not blocked. Glad I changed it out.   The accumulator, which should have been a 5 minute job, may have just burned $50. Put some PAG in it, wrote the date and mileage on the side, fresh o-rings and gooey'd up the threads and rings with Nylog. Got everything connected and snugged and was going to vacuum down the system, and....   My manifold gauge won't fit on the port. It's not an R12 service port. It LOOKS like an R134 service port but the diameter is a hair too large. There's a sticker on the accumulator that says it's designed to be used with R12 and R134a systems only. So it's not R1234yf. Even if I reduced the diameter slightly with a file, the shoulder on the port is too large so the quick-connect valve won't lock on. I'm stumped. It's going back, and 50/50 on if they'll give me a refund.   Also, I did a fuel pressure test.... Key on, the gauge spikes to about 60psi and quickly bleeds off, like 2psi per second. The fuel isn't going into the plenum, no smell, starts fine, so I'm guessing there's a bad check valve in the pump and the fuel is just draining back into the tank. oh, hell. But, it shouldn't be a problem, pump primes just fine and the truck starts right up. It just means I can't really ever use fuel pressure to verify a leak at the injector or intake.
    • Got this yesterday out of nowhere. Truck is a 25',6.6 gasser with 8k miles.  Only semi anomaly is that the truck had been sitting, uncranked for 6 days. Elec Stability Control showed immediately upon cranking, not while driving. No drivability issues, just the message. Battery didn't seem to be weak when cranking over.  I drove it, killed it, let it sit a few hrs with no avail.  Truck is 100% stock. No damage.
    • This can be done.  It is not cheap and requires an instrument cluster swap with custom programming, new steering wheel with the controls on it, and a special jumper harness.   The cluster upgrade - 12.3” Digital Cluster Upgrade – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The wheel upgrade - Steering Wheel Upgrade Kit – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The column harness upgrade - 2019 - 2026 Silverado / Sierra: Steering Wheel LIN Bus Harness - Harness Dr. - DIY Done Right     The problem with doing all of this?  You pretty much can't have any programming done to your truck that involves the cluster ever again.  The dealer won't be able to program the cluster as GM's system will only pull data for the cluster the truck came with.  So it would be advised also to turn off over the air updates.   TLDR;  Should have bought an LT double cab?  You'd have a power seat, the wheel controls, the cluster, all things that you've been seeking in your various posts so far about your new WT regular cab.
    • I was unaware of that, thanks for updating me.
    • Yes.  The 2.7 Turbomax has Active Fuel Management.  It is NOT the same as the V8s.  Totally different system.     Here is an article from GM when the 2.7 came out explaining the cylinder deactivation and the valve lift system.  Starts at the section called "SCS Valvetrain":   New Turbocharged 2.7L 4-Cylinder Engine Powers Full-Size Trucks – TechLink         This is an internet myth going around.  It was alleged that some 5.3s had this mystical 8th digit of the VIN as an "E" which somehow meant it had a new one year only 5.3 that didn't have DFM.  The writer of said article and the person that made the claim conveniently can't count because they posted the VIN.  The 8th digit was a "D" which meant its still the 5.3 with DFM.  The 9th digit of the VIN was an "E" and the 9th digit isn't the engine code.  At all.
