We had a bear visit yesterday, got the bird feeder. What's unusual is the time of day, usually at night they visit, get them on the trail cam. We take the bird feeder down every evening to prevent this. Stood back from the window so I didn't scare it when I took the pics, also through the screen.
Cool! I have never seen a bear in the wild but have seen the damage done by them when they smell food. They destroyed a friends gas grill to get at the grease. It is the time of year when they try to fatten up for hibernation I think.
