2 minutes ago, customboss said:
It’s 3rd party abrasives in the castings that didn’t get cleaned out. The abrasives select the engine , bearings , crank, journals.
Does the Camaro and Vette 6.2 engines share the same crank forging as the L87? Isn`t the L87 basically a Vette engine with a truck intake?
29 minutes ago, PunchT37 said:
I`m having a hard time buying all this 6.2 stuff. Hard to believe all the reasons for failure are confined to one RPO, LT type engine.
Why is that so hard to believe? I don't understand what you are saying.
Never mind what I asked you in your previous post. I see now what you're getting at. That said, It's possible that the Vette and trucks lines used blocks from different builds, and those different builds used parts from different suppliers, or parts from different runs from the same supplier.
Edited by MrLeadFoot
I was a mechanic for 25 years. Including a large Chevy dealership. These LT engines share a lot of the same parts but only one has problems? It is hard for me to believe. Troubleshooting not the same as parts changing.
  • Thanks 1
Could be. Troubleshooting is getting to the bottom of the problem. I don`t have any to look at. Just going by what I`m hearing. Don`t make a lot of sense to me.
Somebody cleaned the block castings better than the trucks?  Make sense?  You know what swarf is? Ever bead blast a block or try to clean it up after it came back from the machine shop? Ever get a cast engine component that had fine granules of swarf?  Includes leaving soaps and solvents in the casting that neutralize the overbased oil additives in a casting and hiding.
Nevermind
Edited by customboss
Could be. Yes I do know what all that is. I have prolly put together more engines than most on this board. Have been on here since 2003. By my post count, I don`t talk just to get my post count up. Getting a little condscending. Notice I said, could be?
Not meant to be condescending just can't believe that as experienced as you are you never saw the casting facilities sending crapdirty blocks heads etc out.  I am a retired cummins engineer from Indiana and we watched GM eat small blocks the same way in the 70's 80's out of FABRICAST in Bedford Indiana.
I get it. Just can`t figure out why a large corporation like GM can clean all their blocks, crank oil passages, heads, etc except one RPO. They outta ALL be trashy.
  • Thanks 1
That's showing you understand mechanics not business.   Its not GM.  It's their contractors, sure they make a vette engine hand built now as I understand it.  But anything that's mass shoved down our throats gets missed. It's sad I agree and understand I think LIKE YOU !  I learned at Cummins that no one built stuff like we did. In house mostly.
I do understand outside vendors. Are the castings cleaned by the vendor or the GM assy plant before assy?
  • Thanks 1
From the looks of it not well enough either way! LOL
1 minute ago, PunchT37 said:
Most folks don`t understand how many parts are NOT made by the brand they bought. Getting fewer as the years go by.
It's like eating crawfish without washing and rinsing before boiling!  I see you are from the real part of LA.
    • This is interesting. My quote tagged here is different from my original quote. After I’m driving them longer. That isn’t me. I don’t talk that way. I definitely wouldn’t express myself that way. Interesting.
    • I have the same running boards on my truck and I do agree they are bulky. I also find myself stepping over them when getting in and out of the truck. Besides providing protection to the rocker panels, they aren't very useful.  I will be replacing them soon with the Amp Powersteps.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
