That's false advertising if I have ever seen it! Between engines spinning bearings and kicking rods out the block to transmissions that can't even make it out of warranty, GM should be ashamed of themselves.
  • Thanks 1
2 hours ago, newdude said:
Update(s)
GM sent dealers a new special tool to use with an existing tool, the Picoscope (fancy high end oscilloscope plus a whole bunch of other fun stuff it can do).  Its a knock sensor that is wired to be used with the Pico.  This is for recall N252494000 which is still in "incomplete/remedy not available" status.
Trucks with N252494001 are still the verify P0016 is not set, if not, switch the truck to 0w40.
N252494002 has been appearing as "open" on some VINs.  This one is the put an engine in it recall #.  The one we have that is currently already getting an engine actually has this recall as open status now so GM knew by VIN that either the original or the replacement engine are/were suspect and therefore it was given the 002 recall version and to put an engine in it.
Thank you for posting these upates. I, for one, really appreciate you keeping us in the loop.
Do we really believe this has been fixed for the 25 model years? Let’s say your dealer wanted to do you right and traded you into a 25. Would you have concerns?
Don't see why not 🤷‍♂️
GM knows the window for the problems, March 1, 2021 to May 31, 2024.  Post May 31st 2024 they had the improved production in place for whatever concerns were going on.  Is it possible that one bad one could sneak out here or there?  Sure, can with any of the engines they have, but I'd imagine if one popped up that GM would nip any issues in the bud quickly after this whole fiasco.
  • Thanks 1
So my engine build date is 21 Feb 26 ... Truck build date 03/21 and it is on the list.
Just got my truck back from the dealer yesterday with the new engine installed and today the truck is back at the dealer because the engine is miss firing. They did give me a brand new diesel to drive today
  • Confused 1
Is the recall for Engine build date or Truck build date? My build date was 6 days after yours on 3/27.
Sorry to hear. That’s the next thing. Lots of opportunities for them to screw things up during such an invasive repair. I could never get dealers to do the simple things correctly let alone something like this. They completely destroyed multiple pieces of the interior on my Silverado fixing the rear window leak twice. And then the Ram “wing” of the same dealership installed a shock backwards on my other truck and destroyed that. $1200 repair they had to eat at least. 😂
  • Sad 1
I believe its the truck build date, the 03/21 came off the door sticker not sure if its the month & day or month  & year?
I'd trade in a heartbeat! My local dealer has a 25 that's an exact duplicate to mine and I would not hesitate if they offered me a real good deal
Did you buy your truck new or used?
Yes new had 4 miles on it, Right off the lot 4/22/21
Edited by WeGone
I believe it is the engine build date. There is a sticker on the back of the left side engine cylinder head with the date code. The engine build date will precede the truck build date but not by much, natch. A few days, maybe a week.
Does it matter in terms of the recall?
My truck is on the recall list by the vin # and the engine built date is Feb. 21.
Edited by WeGone
Per the NHTSA 25V-274 (N252494000) document....
"GM’s updated field data analysis identified a build period from March 1, 2021, to May 31, 2024..."
    ChristopherDobson
    ChristopherDobson
  • Who's Online   0 Members, 0 Anonymous, 1,320 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
