Here I go again, I change fluids more often than the severe schedule. It has served me well, my 93 Silverado trans went 250k, my work truck, not easy duty.
Then I switched to Amsoil OE products, worth the cost to me.
  • Like 3
  • Thanks 1
late to this thread but yeah replace ATF.  you have nothing to lose.
bought my truck with 5 miles and around 19k the 6l80 acting goofy.  called dealerships to utilize my precious warranty and got told transmission guys are backed up 6 weeks and i'd have to leave the truck and no loaner.  After losing my previous truck to the 6 speed rumble strips i started swapping out a gallon atf every 6 months and added the thermal bypass.
I think you are starting this fluid change late, good luck.
  • Thanks 1
He might be, but I have seen good results from customers that started this late so there is hope.
Why not drop the pan, change the filter, and do a couple of successive drain/refills while it's warm (thermostat open, if still equipped).
It's not that hard, or expensive, and accomplishes replacing 95% of the fluid at once.
It's like when people do this with power steering and use a little turkey baster to suck a little bit of fluid out and replace it with new over several oil changes. Jeebus... Pop the dang return line, hang it into a pan, plug the reservoir and have someone keep it full with new fluid while you crank the wheel lock to lock (with the engine off). It takes 10 minutes to do, and then you're done, completely flushed the system with clean fluid which should be good for another 20-30k before you should change it again. Hang a power steering filter on there for a gold star/ bonus points.
Edited by Atlas
  • 1 month later...
This may come back to haunt me, but I've had my truck in every 5000 miles for a drain and refill, with filter, on the transmission - never a transmission flush.
Along with the fix from Chevrolet TSB 21-NA-199.pdf, no issues with 98K so far.
Edited by MikeBMW
  • Like 4
    Fishboat
    Fishboat
  • Who's Online   7 Members, 0 Anonymous, 491 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
