 I did that often with the cars my wife drove. She would drive mostly in town. The acceleration would pick up and the in town fuel mileage would increase. Later with trucks if they didn’t already come with 373s or 410s I would change them. My trucks early on would carry weight in the bed or pull loads. We would add gear vendors in some. Today with the transmission and final gear combo unless you’re messing with over sized tires. I don’t know if it would be necessary. It much easier to buy the combo to fit your needs.
3.23, 33” tires, 4wd. Looking for improvement in acceleration..
Edited by M1ck3y
If you have the 8L90 with 7th and 8th OD ratios, I would be tempted to go with the 4.10 ring and pinion set especially if you occasionally load or tow heavy. The 3.73 will be a huge improvement over 3.23, but with the expense of 2 differentials, you don't want to be left just wanting a tad more. Besides, I see gas prices being stable for the foreseeable future.
5 hours ago, newdude said:
When you say 33" tires, are they floatation size?  What size are they?
They’re 285/65r18. Sidewall says 33”, tire Calc will say 32.6”
Yeah I was thinking 4.10s, maybe even 4.30s max. Problem is 3.73s is the max size for 9.76 and the shop I’m working with won’t do a gear kit that has a spacer (to fit a larger gear).
Edited by M1ck3y
You can change the carrier to run a lower gear.  The carrier you have is only good for 3.23 and lower (numerically) and the other one is good for 3.42 and higher.
Here are your effective ratios and rpms at speed as configured now:
3.42s:
3.73s:
4.10s:
4.30s:
https://demandaam.com/expview/976-RearAxle-Salisbury-12Bolt
The Ram with the 5.7 Hemi and ZF 8-speed transmission can come with 3.92 gears.  You're equivalent would be 4.10 gears.  So, it's not too much 1st gear as some say.  Those trucks leap off the line at the track like nobody's business.
Any thoughts on how changing gears will affect the driveshafts critical speed?
The driveshaft's critical speed (in rpm) will not be changed.  What changes is how fast the vehicle is going when the driveshaft is going at that rpm.
A lower gear ratio (3.73 for example), you will be going faster for a given driveshaft speed/rpm, vs a higher ratio (say 4.10).
Right, I’m wondering how much my top speed will drop after changing gears…
Unless you're tuned it won't matter anyways since it's electronically limited to 112mph.
Actually, you would get a different top speed just changing the gear ratio, because most GM trucks have the VSS at the rear of the transmission or transfer case, so the ecm miscalculate the speed the truck is going, and the limit it applies will similarly be off.  Tuning the truck to fix the speedo would then return it to the 112 limit, unless the limit is also changed as part of the tune.
    RyGuy43
    RyGuy43
  • Who's Online   3 Members, 0 Anonymous, 421 Guests (See full list)
    • This is NOT impact damage nor neglect. There were previous class action lawsuits because of such paint preparation st GM manufacturing plant. Not just the Cherry Red Color. This paint is applied in three processes to obtain the desired color.  The manufacturer will cover for 36 months or 36k miles only. That rust is actually corrosion because of the paint process failure. Corrosion is covered for 100,100 miles or a certain months. However their corrosion doesn't include this type. Go figure. Clearly manufacturer knew from previous paint issues. This started 3 weeks ago out of the blue.
    • Is it time to put a piece of tape over the CEL?
    • consider doing electrical testing?  I would guess some power or ground wire/connection has a problem.   alldata.com has wiring diagrams, connector pinouts and diagnostic procedures you can use to find where the problem is.
    • can you tell if the reader is actually trying to get codes, and the pcm is reporting none, or is your reader just silently failing because it's not communicating with the pcm?
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
