I have a 2020 silverado, and I just replaced the driverside front cv axle. Went to get alignment, and they say I need lower ball joints. I'm not surprised since my summer tires that I just took off showed signes of wear on the inner tire. I drive mostly highway, with 137 k on the truck. I feel that it is early to replace ball joints. Does anyone else have issues with this?
Anything over 100,000 miles is great. You definitely got a lot of use from the original ball joints.
137k km, so a little short of 100k miles, but still, decent.  They fail along the bathtub curve, the low, flat middle part is low, but not zero.  There will always be some that fail "too soon", possibly exacerbated by driving conditions and things like oversize wheels or lift if you've done that kind of stuff.
i have a 2020 with 170k kilometers, i am putting my snow tire on today, i will check them and let you know. i don't have any wear problems but every once and a while it will pitch to the right
The only thing different is I have 1.5 inch spacers when I am on my summer tires. I dont need them for my winters. I know they are a little hard on the suspension.  But didn't think they would go this quick. I am still on my original break pads. But will likly have to do them in the spring.
did you do the alignment with or without the spacer. from stock when you add a spacer it changes camber and toe in which might be why you have inner wear. i just checked mine when i put my snows on and they are still tight
I went for the alignment without the spacers. I put my winter tires on which I dont need the spacers with them.
160K, mine are good.
If you have a 2wd truck, I can guarantee you that your camber is off if your still on your original shocks.  There isn't a 2wd truck on the road running factory suspension that isn't wearing out the inside tread of their front tires.  Take a look at any stock suspended 2wd truck that has more than 20K miles, and the camber is noticeable even when parked.  You can actually see it on some of the 2wd's that are brand new on the dealer lots.
I had the lower ball joints go bad before I hit 65,000 miles on a stock height, stock tire and wheel, no spacer, '21 Denali 4x4 that's almost 100% pavement driven.  I think they billed my extended warranty about $3,600 for the repair, which was nuts.  I also find it crazy that GM has dealers replace the entire lower control arm instead of having a more serviceable ball joint mount.
    • 2023 GMC 3500 HD, SLE, 6.6L Gas, 4x4, 6 Spd Options:  SLE Convenience Package; Driver Alert Package 1; Spray on Bedliner; X31 Off Road Package; TRAILERING MIRRORS, HEATED POWER -ADJUSTABLE, AUTO DIMMING, WITH TURN INDICATORS WHEELHOUSE LINERS, REAR INC. REAR AXLE - 3.73 RATIO INC. GVWR, 11,350 LBS. (5148 KG) INC. FRONT AND REAR PARK ASSIST, INC. ULTRASONIC     I have been launching my new boat and noticed some things related to the parking brake.. I usually set the parking brake (habit) when on flat ground for typical driving.    When backed down on the launch ramp to launch the boat and I place gear selector into Park, the parking brake activates automatically. My second nature is to set parking brake manually and noticed I was turing the parking brake off.  The parking brake appears to be setting itself automatically.   I looked all over my owner's manual and only found references to being on an incline and manually setting parking brake, or at times parking brake will be auto engaged, but nothing specific to my situation.    When is the parking brake automatically engaged?  Under what specific circumstances?  Can the auto set parameters be changed?     I like the auto set feature.  It would be nice if always engaged when shifted into Park and released when shifted out of Park (like my wifes 2025 RAV4).   Thanks!
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
