I have a 2020 silverado, and I just replaced the driverside front cv axle. Went to get alignment, and they say I need lower ball joints. I'm not surprised since my summer tires that I just took off showed signes of wear on the inner tire. I drive mostly highway, with 137 k on the truck. I feel that it is early to replace ball joints. Does anyone else have issues with this?
Anything over 100,000 miles is great. You definitely got a lot of use from the original ball joints.
137k km, so a little short of 100k miles, but still, decent.  They fail along the bathtub curve, the low, flat middle part is low, but not zero.  There will always be some that fail "too soon", possibly exacerbated by driving conditions and things like oversize wheels or lift if you've done that kind of stuff.
i have a 2020 with 170k kilometers, i am putting my snow tire on today, i will check them and let you know. i don't have any wear problems but every once and a while it will pitch to the right
The only thing different is I have 1.5 inch spacers when I am on my summer tires. I dont need them for my winters. I know they are a little hard on the suspension.  But didn't think they would go this quick. I am still on my original break pads. But will likly have to do them in the spring.
did you do the alignment with or without the spacer. from stock when you add a spacer it changes camber and toe in which might be why you have inner wear. i just checked mine when i put my snows on and they are still tight
I went for the alignment without the spacers. I put my winter tires on which I dont need the spacers with them.
160K, mine are good.
If you have a 2wd truck, I can guarantee you that your camber is off if your still on your original shocks.  There isn't a 2wd truck on the road running factory suspension that isn't wearing out the inside tread of their front tires.  Take a look at any stock suspended 2wd truck that has more than 20K miles, and the camber is noticeable even when parked.  You can actually see it on some of the 2wd's that are brand new on the dealer lots.
  • 1 month later...
I had the lower ball joints go bad before I hit 65,000 miles on a stock height, stock tire and wheel, no spacer, '21 Denali 4x4 that's almost 100% pavement driven.  I think they billed my extended warranty about $3,600 for the repair, which was nuts.  I also find it crazy that GM has dealers replace the entire lower control arm instead of having a more serviceable ball joint mount.
    • Here's the second UOA on my 22 Wrangler with the Ecodiesel. This has 5k miles on AMSOIL Signature Series DEO 5w-40. The first one was dealer installed oil, no clue what it was, the second is what AMSOIL recommended, European FS 5w-40, Most of the Ecodiesel world is showing great results using the European MS 5w-40, I figured I would see how the DEO works. This is using an Ecoguard oil filter. It's my understanding this engine likes to shed aluminum.  We will see. So far I don't think this is too bad.
    • I'm surprised nobody seems to offer a solution like the start/stop device I put in my new truck. Remembers my setting when shutdown. And while it still starts up in start/stop, it stores/evaluates what mode it was in when shut down and will change it whithin a second or 2 of startup. It'd be nice to have something like that for the DRLs.
    • 2015 Sierra 1500 here. Leaks from the sunroof to front driver side and soaks carpet. How do I fix this? Thanks!
    • I will be doing that for sure, but I need to solve who has/ where I can find a bidirectional scan tool that will support OBD 1.5. I'm kicking myself because I ebay'ed a Snap On MT2500 that I didn't think I'd ever need anymore. D'oh!! I'd rather not buy another, so I'll contact a few local shops to see if they have one and how much they'd want to do the procedure. I'd rather have the ability to do it myself... I wish there was a modern tool that could do it all, but I'd have no idea what to buy.   The theory with the pulled timing is that it mimics a rich condition. The delayed spark causes incomplete burn and the O2 sensor picks up low oxygen levels. That's interpreted as a rich condition so the PCM pulls fuel and that shows up in the deeply negative fuel trims.
    • An ultra wealthy man had the most beautiful daughter. But, there was a problem. Everything she touched would melt in her hands. No matter what, Metal, Wood, Stone. Anything she touched would melt. She could not feed herself. Because of this, men were afraid of her. Nobody would dare marry her. Her father was despaired. What could he do to help his daughter? He consulted doctors, scientists and anybody who could solve this problem. Finally one of them said, "If your daughter touches one thing that does not melt in her hands, she will be cured." He was overjoyed and came up with a plan. The next day, he held a competition. Any man who could bring his daughter an object that would not melt in her hands would be given billions of dollars to marry her. Three extremely intelligent and handsome young men took up the challenge. The first brought a very heavy steel rod, But alas, when the she touched it, it completely melted in a matter of seconds. He sadly went away. The second brought a beautiful diamond, knowing diamonds were one of the hardest substance in the world and would not melt. But alas, once she held it in her hand, it melted. He too was sent away disappointed. So now, there was one left He was very nervous & sweating. He approached the daughter & said, “put your hand in my pants pocket and feel what is in there." She did exactly what he asked. She felt something very hard. She held it in her hand, squeezing it as hard as she could. It did not melt & remained extremely hard. Her father was overjoyed. Everybody was overjoyed. She was finally cured. Nothing never, ever melted in her hand again. They married and they both lived happily ever after, raising a wonderful family. Question: What was in the the groom’s pants pocket??? Answer below ↓ M&Ms of course! They melt in your mouth, not in your hand. What on earth were you thinking?
