Hi just got my truck back from shop for new transmission and now the truck some times wont start seems like bad fuel pump. i have lots of codes my guess is bad ground im here to get another opinion. what should i do? shop doesnt open till tuesday.
thank you
P1682 ignition 1 circuit 2 fault
U0422-71 invalid data from bcm
U0029 poor can bus performance
B1024-53 driver airbag short to ground
b2575-04 left headlight  open
b2699-04 right headlight open
both headlights are working fine i do have aftermarket hids with capacitors
C0765-29
C0760-29
both are tpms yes there dead
B127B-2B reverse camera signal missing
stinger aftermarket radio should still have signal?
Edited by Gregory Krisa
Check the ground wires on the top bellhousing bolt and the rear of the passenger cylinder head
From R&Ring the transmission on my '04 3500 w 6.0, I didn't have any ground wires on the bell housing bolts.  top center is for a bracket holding vent tubes, next bolt over to the driver's side is for the fuel/evap lines bracket, to the passenger side is the brace for the trans dipstick tube.
What's the point in asking if it's too cold for you to work on the truck?  Were you hoping there was a switch in the cab you had to flip to make it work?
If the truck just had the trans replaced, and these problems weren't happening before, but are now, then, most likely, they are related to doing that work.  So, some wiring harness is getting pinched, or not fully plugged in, or similar.  So really, the starting point is getting the truck up, and crawling underneath it to see what's up.
options.
well thankfully i know where to look but trying to squeeze my hand in there and feeling around is not working right now as its too cold maybe before my check in appointment it will warm up and i can find it or i can get lucky.
january 6 they were going to check for leaks maybe. there is a note on the paper work that they may have a immobilizer installed. i couldn't find anything.
the can bus performance issue could be poor communication to transmission module.
On 12/30/2025 at 2:37 PM, Black02Silverado said:
How old is the battery?  That can cause issues as well.
True. I had a relatively new battery and, at times, I would forget to turn off my dash cam while at home for a few days. The radar detector would shut off on low battery sensing (Uniden R8) but my dash cam (VanTru N4) would keep going and deplete the battery.
I replaced with an AGM and, lately, on the occasion I still forget, it (the battery) keeps going.
No more bringing out the MaxiSys to reset all of the codes after a battery low issue triggers all sorts of temporary codes. Now, I just do it for fun to reset transient temporary codes from time to time.
battery is about a year old agm i have a battery shunt says its 100% charged. there is a possibility its it the ignition. how often does the ignition go out on these trucks?
What year is your truck? My 2016 Sierra had issues that I was able to clear up by replacing the negative battery cable, cleaning the connections of course. You need an oem replacement for this. But first, if I had work done and then had problems I'd be all over that shop blaming them.
    250.6k
    Aries68
    Aries68
  • Who's Online   5 Members, 0 Anonymous, 425 Guests (See full list)
