So getting older, hopping up in the bed of my 2024 is a little harder on my knees. While the bumper steps help tremendously in that aspect, I still thought I needed something else.
Cue, Boost Auto and their retractable bumper step kit. Man, it makes it so much easier to get up into the bed now. Knee saver for sure. Its a nice solid unit that retracts nicely up to the bumper, and doesn't look too out of place. When lowered it gives you a foothold about halfway down between the OEM bumper step and the ground. The step pad is customizable a bit for your liking, with different pad designs and colors.
Check out my full install video below.
On 1/13/2026 at 7:22 AM, silveradosid said:
great idea if you live in the south, wouldn't work long in the snow belt
I think it would be OK. Boost Auto is based out of the Chicago Suburbs, plenty of winter weather there. They do pretty rigorous testing and engineering on their products.
On 1/13/2026 at 11:09 AM, johnnyquick said:
Boost auto has excellent products!
Agreed!
I just had their Lumastep M2 installed on my truck. Dont care for the way the guy wired up my engine bay at all Id play hell trying to decipher through it to fix it. The boards seem fine so far. The only thing I dont care for is the fact that the rear of the cab has a curve inward so the boards stick out on the backside.
Byrds,
Do you have pics?
This is from directly above. there are no adjustments on the brackets. The boards were all the way to the rear originally so I moved them more to the middle to try to take some of it out but it didnt help much.
Edited by Byrds8
That don't look right. I'd get a hold of Lumastep and see what's wrong.
I like the steps though.
I had the M2's installed on my 2022 1500 and it looked about the same, just the way the cab curves.
I have a set of M2's coming from Boost Auto for my 2500. I'll see how they look on there.
I did get in touch with BA. They said due to the curvature of the cab, it's the way it's supposed to look. They did say if I slide the boards all the way forward it would take of it out. I just cant have them sitting all the way like that. Would drive me nuts looking off centered.
Let me know how it turns out.
    • Some clarification may help with some of these issues.   - Rev Industries is/was the division of BAK (now Realtruck) that makes covers under the OEM names.  So if you see one with a Ford logo on it, or if you are buying the GM Accessories cover, you are essentially buying a BAK G2 cover with different branding.   - Rev Industries now markets under RealTruck "Advantage."   - As of May 1, 2025, the Advantage covers now have a 5 year warranty.  Anything before that was a 36/36K warranty.   - Parts for the covers are available from Realtruck or BAK.  The email address to reach them is [email protected] or you can call them at 818-365-9000   - If the entire cover has to be replaced, you have to go through your local GM dealer.  Service dept opens an RO, notes the damage and submits it as a warranty claim.  Keep your paperwork handy so they can confirm when you purchased it and it's within the warranty timeframe.  Once the warranty claim is approved, Parts orders the replacement cover.  When it arrives at the dealership, service will remove and install the new one for free as labor is included under warranty.   - The Advantage covers are not the latest and greatest Gen 3 covers.  They still use the old school clamps, elevator bolts, etc...If you want the newer technology, consider buying your cover in the aftermarket world.  That way, if you have an issue you can deal directly with the manufacturer.   - Finally, RealTruck has a program with many of their authorized dealers that doubles the warranty to 10 years if the authorized dealer does the install.     Hope this helps.
    • Welcome to the group!  My '22 just crossed 150K miles.  Runs perfectly.  Oil pump belt will be done in the next 30 days or so and onward hopefully for another 150K.  Love the truck.
