Hi,
A dealer offered to trade my 2024 High Country for a 2026 ZR2.
Mine is heading out of warranty in August.
It has been a perfect truck and planned on keeping it for 7-10 years. I do mostly highway driving and have a 5,500lb jet boat that I tow.
The dealer is offering to beat my current payment and gets me into a new 2026 with a full warranty.
Would you consider this or just stay with the High Country.
I would be gaining the 2" lift, better shocks, locking diff, HUD and camera rear view mirror.
I would be losing the Cadillac like comfort of my HC, moonroof, wood trim, and I am thinking an extra speaker in the dash.
Both are diesel and has the same options plus or minus the ones listed above.
I am just concerned how the ZR2 is for highway driving and driving in the rain. The HC has been flawless.
Edited by gregus73
Tires determine how they drive on the highway and in the rain. Being lifted by 2in means really nothing here when it's just bombing down the freeway.
Good chance that your current truck runs all season passenger truck tires of some sort and the ZR2 is going to run a minimum a C rated or even an E rated LT truck tire. They will be heavier, likely louder and have an offroad tread to them. All of those things can make a ride worse feeling is some cases if you are so used to riding in luxury. Most name brand offroad tires are just fine in the rain until maybe half tread, then you might notice them being easier to spin with enough power in the wet.
Also expect less fuel mileage in the ZR2 with the suspension and tires.
The young me would do the deal. The older me would keep the HC, possibly buying extended warranty.
12 hours ago, gregus73 said:
Hi,
Nope.
Doesn't matter if the dealer is "beating your payment". I'm guessing the term is getting extended, and you just took a 2-year thrashing on depreciation on your High Country. You're likely not saving any money, just prolonging the pain. ZR2's are, IMO, are a ridiculously overpriced 1500 trim.
The ZR2 tow rating is down from the regular Silverado because of the lift. Taller entry/exit, IMO less comfortable for everyday driving. And while driving in the rain wouldn't worry me, driving in mixed snow conditions would as the ZR2 on has selectable lockers, no G80/ limited slip. You're either running the lockers or not, and those are for offroad use only.
Now, I'm biased for the 3.0 diesel. It's a great engine, but it's not something that would make me switch from a V8 that's served me well and is only 2 years old.
What drives you—emotions or reason?
Let’s say you hadn’t received this offer from the dealer, who is driven by reason. Was trading your current truck part of your plan anyway? If not, there’s your answer.
On the other hand we live only once so ... 🙂
Thanks for the replies. It would be for 2500 ZR2.
My wife thinks the extended warranty makes most sense.
I am still waiting for their quote on the gasser ZR2 as well.
The dealer approached me with the temptation of something shiny and new, with a new warranty. I test drove the gasser and diesel ZR2s yesterday for grins, with no intention of mailing an immediate deal. I also have reservations about losing MPG, if I were to go with the gas.
On the plus side of gas, no more yearly emissions tests, def or expensive services.
Yea, I would lose ground for owning the vehicle 2 and a half years and start over with a new payment. Not fun.
I am on my second diesel and love the Duramax engines. I am hesitant about the 6.6 gas.
The driving experience on the 6.6 gas was very different. The Duramax does seem to have more get up and go. The gas was peppy, just different. I am only towing 5500-6000lbs so do not need the diesel.
Edited by gregus73
I wouldn’t do that deal but if my dealer wanted to trade straight up for another ZR vehicle, the ZR1x I would take that deal haha.
  • Haha 2
I was running it by my nephew, who thinks it is a bad deal too.
i also called insurance and it would run me $40 extra per month for the ZR2. The biggest thing that is holding me back is the miles to empty on the gasser ZR2. I am use to 670-700 miles per tank on the HC diesel. The dealer said 650 per tank on the gas ZR2 and I am calling shenanigans on that.
I believe you said a gas ZR2 2500? If that is the case, it's BS 100%. I have a gas 2500 and get around 11 in the city. It sure as hell isnt jumping to 18 on the hwy. Most likely, if youre talking hwy MPG, it will get 14. That would put you at 504 a tank.
If you are averaging 12mpg on a gas ZR2 HD, x 36 gallons, 432mi total estimated range.  Definitely not 650mi lol.
A regular gas HD typically averages 12-14mpg empty driving per tank.  You "could" squeak 15-17mpg on a long highway run.  I'd garner a ZR2 would get 1-2mpg worse across the board because lift (lower aero) and 35" Goodyear Territory MT tires.
A Duramax ZR2 HD, expect a similar loss of 1-2mpg.
Edited by newdude
Monthly payment for insurance tells me you need better money management.
That depends. Small monthly payments while a lump sum earns interest could cover the small payments amount. One never knows.
Cheaper to pay yearly, works for me.
There are lots of use cases for a 2500 instead of a 1500 but I still don't see the value add in a ZR2 package on one unless you're specifically using it off-highway.
Another $480 per year for insurance on top of it all is ridiculous. It's still a Chevy pickup.
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
