Vortec 8100 oil filter
Hey gang. I did a search on the 8100 oil filter. Looking for something a bit bigger. I know the 4.8L I had, there were a few options. Does AC Delco make a larger one for the 8.1? Just want a little larger capacity if possible. If not, the stocker will do. Might opt for the Mobil 1 though.
Gonna go look at the Wix site.
Thanks all.
Lee
If you've got a 4wd, then your only choice is brand/type of filter. A larger filter will not fit unless you add a remote mount. If you have a 2wd, you have more options.
The stock AC Delco PF 454 has been rated very highly by many.
DEWFPO
I just researched this about 2 weeks ago with my NAPA filter rep. He showed me that there are several and how to spec them. I received a 2006 NAPA filter reference guide from him a few days later. Their filters are made for NAPA by WIX, the only differences are packaging and part#s if any.
The 8.1 uses the same thread size as the older big blocks:
Thread size 13/16"-16
Gasket size: O.D. 3.444", I.D. 3.100", Thk. .260"
The differences between all the filters that will fit besides size are these,
by-pass valve and PSI of,
Anti-drain back valve (not important when mounted vetically with open end up), and whether or not the gasket is attached or separate. Outer diameter differences are minor.
I'll list ones that are a easy fit (no by-pass, attached gasket, etc.) and their hieght.
NAPA#'s
7099: stock, hieght = 3.306
1060R: hieght = 5.170
1060: hieght = 5.178
1620: H = 5.196
There is one larger that has no anti-drain back valve, so must be mounted as stock to hold oil during shut down. I have one that I will test fit on my 4x4 next oil change.
1794: H = 7.822
All others without valve are sized similar to stock or smaller than those I listed above.
If someone beats me to trying the 1794 and it won't fit post up.
Vernon
    • Sir, economics doesn't have a moral compass. 😉 Just say'n.
    • One would think. BUT....This is what a Google search gives for the GM OLM system:    It doesn't measure oil condition save the highly indirect water temperature. It should measure oil temperature and as we've discussed they are not as closely related as one might assume. The algorithm is based on expected conditions at the end of a certain number of miles or revolutions. And sirs, this estimated value is not tilted in the engines favor. It favors the OEM's bottom line. There are no magical number of miles nor revolutions. No magical time limit. There is only what can be measured directly and only in the broadest of terms would the values used even come close to reality.    It samples nothing. It has no idea where the oil started or where it will finish given the limited values use to create the algorithm. It is just a reminder for the brain dead to do something at some time to keep the warranty in tact. Pure fiction.    Key Factors in Oil Life Calculation The OLM calculates the remaining oil life percentage based on the following factors: Factor Description Engine Revolutions Tracks the number of engine revolutions since the last reset, decreasing oil life with use. Mileage Since Last Reset Monitors the distance driven since the last oil change, capped at 7,500 miles for most models. Time Since Reset Decreases oil life over time, dropping to 0% after one year, regardless of mileage. Engine Temperature Adjusts oil life based on coolant temperature; exceeding 260°F sets oil life to 0%.
    • Towing power and I guess MPG matter that’s why I may end up going with a gear swap as soon as they’re available for this truck if I’m correct
    • If I may, I'd like to post my prediction of the trim levels for the 2027 GMC Sierra, based on what was released/introduced today about the Chevy Silverado.   Using the "Professional Grade" wording already in use by GMC, here are the eight (8) trims I believe the Sierra will offer (comparable Chevy trim in parenthesis): Sierra Pro (Work Truck/WT) Elevation (Custom) Elevation Premium -or- Ultimate (Silverado) AT4 (Custom Trail Boss) AT4 Premium -or- Ultimate (Trail Boss) AT4X (ZR2) Denali (High Country) Denali Ultimate (N/A) If GMC would rather simplify the trim levels, then I predict six (6) with package upgrades in parenthesis: Sierra Pro (with a Graphite package upgrade option) Elevation (with a Premium -or- Ultimate package upgrade) AT4 (with a Premium -or- Ultimate package upgrade) AT4X (with AEV and Ultimate packages upgrade) Denali Denali Ultimate  Let's see if I'm close.
    • I have to believe there are already a bunch of threads on this, but my searches didn't turn up much. While I like the ease of a plugin solution like the Carbyte, It appears it disables the AFM or DFM too, and is not configurable to only disable the auto stop/start. So, I'm looking at the Autostop Eliminator product. I like the idea of it better, but I'm concerned about the install and having to pull so many panels to get it installed. Mines a 2026 work truck, so from what I've read it's a less involved install, but having watched a couple install vid's, I'm still a little intimidated. Might need to buy some plastic trim tools to get it done without breaking or marring stuff. Any experience intalling in a WT greatly appreciated.
