new with a 07 silverado(pics)
cerbomark
I think you're the first one to buy one and post pics here.
Congrats on the spiffy new ride, and welcome to the boards man :cheers:
And it IS spiffy. :cheers:
love that cocaine white, first white one ive seen
NICE RIDE good choice on the 4dr
nice ride, I guess the chevys arent as bad looking as I thought.
what do you think about the steering on that. Did they change it from that crap they have now?
Great looking truck!! The local dealer has one like that but it has the color keyed front bumper(no chrome piece). Everytime I drive buy it, I want to go buy it.
Can you give us some feedback on how you like it, and how it drives?
Good lookin ride. I saw your thread over on SS.com about the new ride. I really like the SS trucks but those new silverado's are sharp. I think you made a good trade.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
