How many miles do you have on your 6.0 liter motor?
  • Replies 319
01' gmc 2500.
Just under 142k. Runs great. No problems reported from the previous owner(only owner). The only thing wrong with it is exhaust manifold gasket leak. Getting fixed right now.
200000 miles and just now my first problem. low oil pressure at start till warm than good to go. replaced altornator that is it. I have slowed down but trust me there has not been one easy mile on this truck. I still pull 12000 lb gooseneck trailers anytime i need. This is the greatest motor and truck i have ever owned
What octane gas are you using? I see some high mileage trucks having knock sensors replaced. I'm wondering if its because they are using lower octane gas, and the knock sensor is getting more use, rather than running higher octane.
knock senors get water in them which cause them to go bad :thumbs:
I was just curious as to how many miles some of you have on your 6.0 liter motors without any problems. With the cold engine knock etc, it would interesting to here how many miles you have on this motor. Thanks for your input.
Oil pressure regulator stuck open at 104,000 miles (see my "Lost Oil Pressure 2500HD" post). 2004 Silverado 2500HD 6.0L gas. Prior to that I loved my truck. It has a 6" lift w/ Bilstein shocks, Gibson exhaust, and a Hypertech chip. I used it to tow about 5,000lbs once a month, with no difficulties. Full documentation of all oil changes every 3 - 4k miles.
Water pump at 50k miles, Left wheel bearing at 70k miles, Steering pump 75k miles.
The incidentals, like the window motor, air conditioning fan controls, center console lid, hood latch, and tail gate, all fell apart within 40k miles. I didn't beat the truck up - in fact the supposedly sensitive Alpine audio system still works perfectly after 104k miles.
Oh well, now it will never be the same. Not too happy with GM! A supposedly "HD" engine shouldn't have a catastrophic failure at 100,000 miles!post-74806-1270480685_thumb.jpg
  • 8 months later...
218K on my work truck and 53000 on my personal both have been pretty good. the work truck was not well taken care of before i got it so it knocks pretty bad but i'd drive it to california no problem.
Checking back in to report 223K on my '01 2500HD 5-speed, replaced 2 slave cylinders, alternator, fuel pump, brake MC. It's been a great truck
I love my 6 liter like everyone else, but damn if they aren't hogs. Gonna pick on you 2500hdee...Quick number game for you. 223k miles at a GENEROUS 14mpg equals just under 16000 gallons of fuel run through that bad boy. So at a CONSERVATIVE $2.00 per gallon, you've spent over $32,000 dollars in gas over your trucks life. I played the same game with my truck. 94000 miles and 6800 gallons of fuel burned (per the digital display). Kinda sucks looking at things that way...
2002 with 95000miles,bought it from my brother. So far no problems ,althought the usuall steering clunk and my passenger window dosent work.
I had the same problem so I replaced the motor and regualtor in the door. Worked for about 4 months and went out again. I finally got my meter out and found the probelm was not the motor or regulator but the plug thats plugs into the motor. Went to the junk yard and found one in a Avalanche that looked like it would work. Paid 5 bucks for it and spliced it right in. Been working perfect for over a year now.
I have a 2000 GMC 2500 with the 6.0. My fuel pump whines something awful so I'm sure I will have to fix that soon but that's normal for a truck with 120,000 on it. I had the loud chatter when it's cold but it still runs like a top. My truck would not start with the key the other day and I had to use the remote start so maybe my ignition is going out. Not sure about that one. I love my truck. I'm always hooked to a trailer and alot of the time it's a 25' GN loaded with hay or tractors. The 6.0 is in my opinion the BEST gas motor out there. Only other truck I would have would be a diesel.
Well I only have a mere 6,700 but it will be increasing rapidly from here on out as the secondary vehicle has died and this is all I have for transport now.......I suppose It could be worse.
1989 honda accord 210,000 miles RIP
YOU MEAN TO TELL ME YOU GOT RID OF AN 1889 HONDA ACCORD?!?! Do you have any idea how rare that is?!?!?!?!? :cheers:
Thanks for reminding me :cool: I sold my 89 Accord Coupe (that I bought new) in 2003, but I did so to buy my mother-in-laws 93 Accord SE sedan :D. The 4-door was a better fit for me, and had 93k miles at the time. Have ~135k miles now. Love the 93, and still have it garaged. Rebuilt the front end, and have a few projects for it this winter. It's a spare for us, and will probably go to my oldest when he's ready (maybe). Excellent quality car, and I really prefer it over the 89.
    • So speaking of oil consumption with my L8T as I just changed the oil yesterday and made the switch over to Amsoil SS 0W-40 from the Mobil 1  5W-30 Truck and SUV I just dropped out. 2900 miles on that oil as well as  68 hours on that oil ( so used to equipment with an hour meter and that becomes valuable information to compare with others as well ). Once again the oil use was so very little, I am going to say it dropped under 1/16 of an inch on the dipstick. No towing was done and this interval was from early spring until now.    One interesting item to note is that going by the 5 quart jugs I was using before from Mobil, it was showing that I was putting in 8 US quarts to bring it to full if not slightly over the full mark according to their jug markings. Granted I did allow more drain time this time and in part because the engine oil was only lukewarm as I started it and let it idle and not for long enough to get the oil itself hot ( the engine was up to operating temp ). The oil in that state just seemed to take forever for it to drip out but not only at the drain plug but at the oil filter housing as well, perhaps I had never quite gotten all the oil out before and I could have still waited longer but as it was I waited well over 3 hours. I think next time if I have the time I will do an experiment by dropping the oil and lets say leave the pan under it for 15 minutes, then switch to another pail and let it drip out overnight and measure how much more oil comes out. So this time and yes I ended up getting it just over the full mark as I was experimenting with trying to get the level to the add mark after I had run it and then waited some and then added a bit and waited for a certain amount of time for it to settle to the add mark. I very well may not have waited long enough for that experiment but I got to the add mark, then dumped in a full quart and waited some and checked and then waited some more and it crept up more ... and then finally oops, it was slightly over full some hours later when it really had settled all it would. I find this engine sure takes time for the last bit of oil that gets poured in to finally make its way into the crank case. I can only guess at how much too much I added as per maybe a 1/10th of a quart. I had poured in 8.5 quarts going by the quart containers as per 8 quarts and 16 us ounces. I was shocked at how much this was off compared to the prior oil changes and if those larger jugs and they are not marked accurately enough or they contain slightly more than what they say, or the drain time factor made that much of a difference. But I know on this forum there have been others who have said they have put well over 8 quarts in their L8T and now I have also going by the Amsoil true quart containers. Its a confusing convoluted mess up here in Canada with some oil manufactures packaging is in true US quarts, some is also in true US quarts containers on an even number of quarts but also marked in liters which becomes the odd ball volume of a fractional amount of liters. Then there is the Liters only containers, no US markings as its a true metric container and only measured in Liters to an even number of Liters. But remember we used to have Imperial Gallons and Imperial quarts as well !.
    • Holy smokes. Clearly not a deal on that truck. I just mean in general, matte or painted trim is becoming more normative than chrome, but I know the Black Optics packages on various vehicles are being sold as uplevel trims. They look really good, but sheesh. It's just paint and plastic.
    • I Wouldn't Know Where to Begin    Oh I know where I would begin but I'm just one of over eight billion people on this rock. Eight billion versions of where the goal post is. How large it should be. How far to kick from. What ball is the right ball. Elevation. Age.....are you getting the point? It isn't about disagreeing with one individual. It's about agreeing only with one individual. One's self.   Agreement comes when multiple people hold the same point already. THAT is the goal of an education. Building the Social Contract. That thing that allows us to all read this sentence. We've agreed on the alphabet and how to arrange those letters into words we agree upon whose meanings hold true for everyone entering into that contract. Those words arranged into a sentence form an idea and several sentences strung together in a paragraph convey an argument for or against or inform the reader of a state, condition or perhaps reveal a things nature. Paint a word picture. Make oneself known.    This contract is not limited to words although they are often explained by words. Things like numbers and their usefulness. Physics, Chemistry, Medicine, Music, Art and so on.    The frequency of middle C (C4) is 261.63 Hz is a first principle. We build on that to make music we all can enjoy even if we all can not compose or play. You don't have to master it to make it enjoyable and useful.    So why is the Beginning so difficult? Why is agreement so elusive?   Everyone "Signs" the contract (when receiving that education in obtaining it)  but fewer and fewer in this world have any intention of living by that contract. They find exploiting that contract more advantageous. Disruption. With intent. Without intent. In Ignorance. In your face. With a double dog dare you. With a hold my beer. In resistance to that contract and in spite how it looks on us. It permeates the very air we breath.    In this way the contract is subject to advantage. Abide by it when it serves you, disregard it when it doesn't. Unpredictable and self-serving. Corrosive.....Toxic........   It says a lot about a persons character to disregard the contract, the truth, first principles. None of it good.        ********************************************************   https://medicine.yale.edu/news-article/character-vs-personality-who-we-are-and-who-we-aspire-to-be/   Just an interesting article.
    • It costs $5,250 for the Yukon Nightfall option (black wheels, emblems and illuminated black GMC grill badge). What a "deal".
    • I keep getting the above error message on my 25 Sierra.  If I reset the infotainment unit (via the phone hang up button) it will work again for a day or 2.   But I dont want to do have to reset  all the time. Works fine in my 2023 Corvette. On both vehicles I connect wirelessly.   I have a Google Pixel 10 Pro XL, phone is up to date.  Any Ideas.  See attached
