Did They Destroy My Frame?
Took the 08 1500 Sierra Z71 ExCab into a local RV dealer for 5th wheel hitch. Warned the service manager not to damage the truck in any way as it is a lease. When I picked it up they said they couldn't find no-drill hitch rails so they installed their regular sliding hitch which means I now have three holes per side drilled into the frame under the hitch. :smoker: I flipped out and they gave a huge discount for the mistake but it's not like they could "undrill" the frame.
Aside from that fact that GM will now crucify me if I try and return the lease (my research so far is showing holes in frame are considered extreme wear), another RV dealer in the area where I ended up buying the trailer is saying that the frame may be screwed. He says that it is hydroformed and cannot support being drilled. It needs to be "filled" at all the drilled points to prevent collapse. When I asked him what that meant and how much he said he wouldn't touch it... Anybody know anything about this? Is the second dealer correct? If so, what does he mean by filled?
Appreciate the response...
I've seen many bolt in fifth wheel hitches pulling large commercial loads over long periods of time quite successfully. The frame is supported by the hitch structure at the bolt holes. It's probably actually stronger at that point.
I'd get another unbiased opinion from another trailer or truck outfitter. Too many "old wives tales" exist in this business that have little or nothing to do with fact. A lot of shops believe "their way is the only way" and "any other way is just plain stupid". It's a common problem... Hell, look at ANY oil change thread ever posted here... Nuts from all camps will swear that they have the only answer.
As far as "hydroforming" goes it just means that the metal is formed in a hydroform press. It's simply a method of shaping the frame that doesn't use typical dies. Composition of the metal is a much more important factor. If the hitch they installed was one engineered for your truck, there is probably little reason for concern.
Once you take the 5th wheel out and trade the truck in, they probably wont even know .. do u have a bed liner in there? That should camouflage the holes well. Also from the last 2 trucks i turned in to my dealer after leases , they never once looked in the bed when they did the walk around with me.
As for holes in the frame that they drilled... i highly doubt that a (what is it , 1/2" ? 3/4 " ?) hole will weaken the structure of the truck ... I know when i ran wires and air lines under my truck there were plenty of holes allready in the frame from the factory that technically did not have to be there.
Holes can be drilled in the frames or structures without decreasing their strengths provided these holes are not drilled in high stress areas. Such holes are often drilled in frames for mounting of support brackets, , for mounting of skid plates, etc. The truck frame is basically a ladder frame with C channel (full box in higher stress areas) for sides and rungs. Typically, frames are made of A36 structural steel, meaning that the tensile yield strength is 36,000 psi. This is not considered a high strength steel structure. When you look at the cross section of a C channel, each drilled hole will remove some metal and make the effective area somewhat smaller, theoretically decreasing the strength. However, small bolt holes will not remove any appreciable amount of material.
As Zembones said, once you bolt the hitch to the frame, you create a bolted connection with the hitch rails actually strengthening the frame, as it is now more resistant to buckling and bending in that region.
If any repairs of the welded holes were desired after removal of the hitch, this can be done by using a plug weld technique.
all these holes and holes topics are driving me nuts!
Well, Joey. It's a pretty short drive. :smoker:
I agree, they don't get all that technical. Worst case scenerio is they refuse to take the lease back, you buy it outright, then trade it in somewhere else.
In my 2003 Z71, the previous owner had installed a 5th wheel. When I bought it they had removed it and left bolts through the rails that look to be welded in. Truck is still on the road, hasn't collapsed yet, and I've had 8,000lbs on the receiver hitch before. I don't know if the 2008 frame is different, but I'd say not to worry about it.
There is one rule about leasing, never lease if your going to exceed the mileage of the lease & if you modify or customize the vehicle. Its not yours its the lease companies, and you will pay pay pay for anything they deem abuse or wear.
Buy your vehicles for that purpose.
EvansDad,
I don't think you have anything to worry about as far as damage to the frame. As others have said, it is probably stronger where the hitch is bolted in, than it was before.
If you are worried about big charges when you go to turn it in, there are several ways to probably bypass that.
What I would probably do when it is time to turn it in.... after taking the hitch out, I would take it to a GOOD welder and have him fill in the holes in the bed.
DO NOT WELD ON THE FRAME.
Grind it SMOOTH and have a bedliner sprayed in it. The holes would be undectable unless you got up under the truck and were actually LOOKING for them and the new bedliner would make it LOOK GOOD. :smoker:
An even cheaper way... just put in one of the dropin plastic / rubber bedliners to cover everything up.
Jim from Texas
I would not guess at this considering I cannot find the upfitting of a fifth wheel hitch to a 1500 series truck.
What GM Says
http://www.gmupfitter.com/publicat/2007_BB...nstructions.pdf
Section 2 — Frame
Hole drilling, welding, modifications, or alterations to the frame assembly are the responsibility of persons performing these operations.
These same individuals assume complete responsibility for frame assembly, reliability, performance after alterations and compliance to
applicable FMVSS requirements.
The following procedures and specific precautionary instructions are recommended for proper installation of special bodies and/or
equipment on GM frames. Failure to follow these recommendations could result in serious damage to the basic vehicle.
Flanges
Do not drill holes in frame flanges.
Holes
Holes to mount brackets, supports, and out-riggers must be drilled in the vertical side rail web with the following restrictions:
• Material between edge of hole and inside of upper or lower flange must not be less than 37 mm (1.50 in.) for HSLA
• The minimum edge distance between any two (2) holes must be larger than twice the diameter of the larger hole.
• No holes should exceed 20 mm (0.75 in.) in diameter.
• All holes should be drilled in the frame using appropriate drilling practice and safety precautions.
Or you can call the Upfitter Integration hotline at 1-800-875-4742
or fill out the form here
http://www.gmupfitter.com/hotline/index.jsp
Aside from that fact that GM will now crucify me if I try and return the lease (my research so far is showing holes in frame are considered extreme wear)...
My experience with lease-returns (I've leased one or two over the years, have a standard finance on my present one) is that they really don't look at them that closely.
I HAVE heard horror stories from folks that return leased vehicles and get nickled and dimed to death, but they are few and far between.
Bottom line is THIS: If you return it, and look to take something new off the lot, they will leave you alone, unless there are agregious cosmetic faults and/or you are WAAAAAAAY over on mileage.
For now, and some time to come, it appears--- the customer is in the driver's seat. It's not like vehicles are flying off the lot. They are selling vehicles, but nowhere near what they were, or would like to be.
The bed liner is a good idea. I wouldn't lose any sleep over it.
Now, to the question regarding the reduction of strength of the frame, I am not the person to answer that, as I don't know.
I can't imagine that three holes will destroy a frame --- but I do not have expertise in that arena.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
