2008 Vs 2007 Nbs Silverado
the 2008 has better quality, both been made in ft wayne ,but...
there's no wind noise coming thru extended cab and front door.
there's no rattle noise coming from front driver door panel.
there's no dash board clicking noise.
no transmission bump(2-1 downshifting bump)
that's it...
that's it...
What body style was your 2007(ecrb)? Might want to resize your display pic to 500x350.
that's it...
Well, hate to debunk your theory, but my 07 has none of those issues. :lol:
that's it...
Sounds like you got a bad copy of the 2007. But at the same time that reminds me...never by a first model year! :lol:
that's it...
Has he had his tranny removed yet though???
that's it...
Well, hate to debunk your theory, but my 07 has none of those issues. :D
I did not say I haven't had ANY issues, I just stated I haven't had any of those issues. Yes, I did have the common "oil leak" issue (rear main seal) that req'd dropping the tranny to replace. :lol:
that's it...
I don't have any of those issues with my 07. My last truck was a 04 Colorado (first model year.) I had one of the first 1,000 built and I put 85,000 trouble free miles on it. I wasn't exactly easy on it either. It just depends I guess.
that's it...
Sounds like you got a bad copy of the 2007. But at the same time that reminds me...never by a first model year! :D
I agree. My 89 was a first (full) year model and was virtually flawless. My 2000 was also a first full year model (99's were the transition year) and it too was excellent. So far my 2007 is also very good (except for the oil leak issue I had....had to clarify so Daddy doesn't scold me again :lol: ).
Only issue I have had with my 07 is the drivers door molding coming off. Replaced by the dealer with no problem. Very very quiet truck.
Quality issues should continually improve from '07 to '08 to '09...duh! :D
The "never buy a first year truck" argument is getting less and less true it seems these days at least with respect to GM. '07 NBS quality is dam impressive :lol:
that's it...
Your next GM truck will be a lemon. The laws of statistical probablity demand it. :D
I have the 07 and love it. Although, I will be checking for an oil leak later today, I am sure they are not much different. If you can get it alot cheaper because it is last years model, go with the 07.
    • Any update if the new valve cover help with the oil consumption?  I have a 2014 GMC sierra and my truck is consuming a lot of oil so I’m wondering if replacing the driver side valve cover will stop some of the oil consumption. Thanks
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
