I have a 2006 Sierra 1500 ext Cab 4x4 with the 5'8" box. I also have this code happening, but I can't find this part under my truck. Where would it be? The only part of the fuel system by the tank is the big rectangular box that I assume is both a fuel filter on the pressure line and something else for the return line. There are no wires or anything like that nearby for this.
Where would I find this evap solenoid on this specific truck????. I have the replacement part ready to install....
Found it above the tank over the frame rail, almost inaccessible. The engineer that chose that location needs a serious kick in the nads.....inexcusable..
There ought to be a law......
Edited by 3beejay3
Yep, easy to just pull the bed to replace.
No thanks. Plus, it's actually under the cab & wouldn't easily be accessible by lifting the bed.
Got it out and moved it to a new location above the main charcoal? canister. See pics.
Also, was able to use the bracket by putting a bend in it and using the existing bolt on the crossmember for the main filter/canister bracket. Used the same wiring connector by pulling it out of the main loom for about a foot or so.
This new location is where the thing should have been mounted in the first place. It's inexcusable that the bed, or cab should need to be lifted, or tank dropped, to do any type of maintenance, incl. the fuel pump.......That's :bs:
Edited by 3beejay3
Good to see you were able to get at it. Mine is under the bed. I pulled the bed to change out my fuel pump. Yes is sucks and shouldn't be designed that way. But it is one way to bring $$$ into the dealership. I'm now getting a P0442 code and think it is where I had to fix a broken line I did when I changed out the pump. So off the bed will come again for that fix and I ordered a new line. Here is my fix that is now two years old.
AMSOILsignandtruckfuelpump029_zps3a3762d
AMSOILsignandtruckfuelpump019_zps40f9677
Geez look at how nice and rust free everything is! Mine is a rust factory and its 4 yrs newer than yours.
  • 11 months later...
I have a 2004 Sierra with 5.3 engine.
Every interchange that I see for the recommended part #214-2149 says it is for 07' up new body styles only. Can anyone confirm this will work on the older body style 2004's?
Mine does not have a clip at the canister like some do. The hose is heat on from factory. Instead of putting heater hose from the canister to the old hose, I would think it would be better to use heater hose from the new canister all the way to the filter box. In my mind it would have less chances of any evap leaks this way. - thoughts on doing it this way?
  • 4 years later...
I have a 2006 GMC Sierra 5.3L Ext Cab Short Bed. I can't find my evap solenoid either. Its not at the back of the fuel tank and its not visible sighting down the space between the cab and bed. My charcoal cannister is in front of the tank lying flat with the three ports facing towards the passenger  side of the truck. All three hoses disappear going up and towards the drivers side.  If you don't know where the vent solenoid is, which of the three ports is attached to the vent solenoid?
Thanks,
George
I have the same set up, how did you get this thing out of there? Any help is appreciated. Nads definitely need to be involved. Thanks,
George
George
Hi George- Sorry for not responding sooner- I haven't been on here for a bit. I responded to your pm.
Is this okay the TSB says to relocate remote filter to top of transmission? I relocated to above fuel pump on top of gas tank will that be okay I don't think any water should be getting up there right? It was a tight spot but doable and it helps to cut the old hose off then just slide out old solenoid between outside of cab and bed and hose from under the truck for those wondering how to get this thing out. So think I'm good with this spot for my filter everyone or should I run it to the top of my transmission? Ty
Edited by Robert Paul
It's dust that caused the filter location to be shifted above the trans. housing.
So that's not a good spot for it then? It is alittle dusty there I guess. I'll have to get more hose.
Not the best of spots when you see all the debris that collects on top of some tank. It'll probably do fine up there. I'm still running the OE valve on the back of the tank, but then I'm not driving on dusty roads all the time either.
Some people have run it up by the gas tank fill hose and I guess it's worked for them
    • Compression test? Weird noises? Fuel trims?
    • I suspect at some point in the near future, the hardware will be free and you pay a subscription to access the vehicle - alldata style.
    • I've been eyeing an upgrade to my tonneau cover for a bit now.  Intrigued by the BAK MX4 EZ-Lift with the torsion spring and went for the upgrade.  Thoughts and musings during unpacking, install and a few days of usage.   Once my order went into Realtruck, it took about 4 days to ship.  Unfortunately, FedEx Ground destroyed the box and contents and it was unusable upon receipt.  To Realtruck's credit, one email with pictures and an RMA was sent to me to send the first one back, and another unit was shipped out.  It arrived 3 days later, unscathed.   I opened the box and it looked like every other BAK MX4.   Biggest differences are the rails and retaining clamps, and of course the spring attached to the cover itself.     NOTE - if you are upgrading from a MX4 to the EZ-Lift, you will have to replace the rails.  The EZ-Lift rails have a notch cut in them to allow the new style retaining clamps to fit properly.  The new retaining clamps also have 2 knobs/carriage bolts and there are two tracks underneath the front panel. The strap clips are mildly different (more like the Undercover Flex clamps) in that the screws go in from the underside.  Personally I prefer these over the BAK clamps that use the nutserts that are a nuisance to install.  The remainder of the parts in the box (drain tubes, rail clamps, and bumper pads) are standard issue BAK.     I did not replace my front bed seal at the time because it seemed to be in decent shape.   BAK recommends shims on the GM trucks unless you place the clamps on the flanges about 1/3 of the way in from both the front and rear of the bed.  I shimmed the front and the middle, and initially placed the clamps equidistant.  This also turned out to be a mistake, because when I set the cover in place, the new style retaining clamps wouldn't clear the front clamp.   New style clamp inserted in the track:     And the issue which occurred because the front rail clamp was too far forward:     Once I removed the shim from the front of the bed, and slid the clamp back to the front flange, everything cleared fine.     The cover set on the rails without issue and I installed the strap clamps.  After I completed my adjustments, I pulled the pin to activate the torsion spring.  Mistake #3 on my part.  PULL THE PIN AS THE VERY VERY VERY LAST STEP!  The reason is, once you pull the pin, the torsion spring is activated.  If you have to loosen the front clamps and adjust the cover, the front panel will - by virtue of the spring, refuse to lay down.  The only way to get it to lay down so you can reinstall and tighten the clamps is to fully open the panel against the back of the cab, which will then allow the front panel of the cover to lay down and be tightened.  Not a big deal unless you haven't installed the foam pads yet (typically the last step) because minus the foam pads, you will need to place something between the frame of the cover and the back window so it doesn't get scratched.  The next time I install one I will install the foam pads before I pull the pin and activate the spring.   After using it for a few days:   The spring assist is great.  You literally can open it with one hand.  My shoulders aren't getting any younger and this was part of my motivation to swap out. The second panel latches and unlatches itself as you open and close the cover.  Neat in concept, however it took me a minute to get used to closing the cover and not hearing the "latching" sound that would tell me it was locked in place. The paddle handles are a huge upgrade and I wouldn't be surprised to see them become the standard across the Realtruck line.  They effectively eliminate the concern that a thief could coat hanger the cover open and get to the contents in the bed. I'm not sure why the very front panel on my cover has a different finish from the other 3 panels.  I have a request into Realtruck to find out if mine was not manufactured properly or if it was by design.   All in all I'm pleased.  Same level of protection, looks good, keeps stuff mostly dry (they all leak around the tailgate) and easy to install.
