Garmin Update...worth The Money?
Luvbelly
I hooked up my Nuvi today and it suggested I check the Garmin site for map updates. I was a bit shocked when I saw the prices. Expected $30 or $40 for the new maps but was a bit shocked when they wanted $70 for a one time update. I don't use the deivce often but if needed it doesn't serve the purpose with the maps out of date. Are you guys shelling out for the update or just buying a new unit every couple years?
I did for mine and I have been trying to upload the new maps onto mine for a few days now. I have a new computer and it is currently downloading so we will see. Is it worth it? Mine is a few yrs old and it doesnt find alot of addresses I put in so I think it will suit me fine. I went with the lifetime update.
Depends on what year map it has and what Nuvi you have. I what every couple of years with all the construction going on it is not worth doing it every year where I am at.
I updated mine once and won't do it again. I had gotten used to the routing of the previous firmware level, and the new routings of the new firmware level didn't make any sense to me.
But did you update just the firmware, or just the maps, or both? Firmware updates are free but map updates are not. You can also update the maps without updating the firmware.
I did both... the firmware screwed me and the maps didn't seem any different... :thumbs:
i think the maps more or less add more info to places and address more than add new streets and stuff
You're right. My neighborhood wasn't on my nuvi until I updated it. It also had some POI updates for new places in town.
It's gonna depend where you are and what you do. Around here, the roads don't change that much. :dunno:
I rarely use POI, more often just directly type the address. :thumbs:
Of course, I updated mine when I got them new. Both Garmins. The first Garmin I got was a few yrs ago that my wife bought for me. This last yr, my brother bought me a new Garmin 265 or some such model from Costco. He also bought a topo map pkg for California and gave me a copy on a SD card that plugged into the gps. Pretty neat stuff.
I haven't updated the old unit and don't plan to. But, I travel for work and pleasure thruout the west, to the eastcoast, or the Seattle area enough that I want reasonably recent mapping software. I take the thing with me for use in rental cars quite often. In October, I drove from Calif to South Dakota and back thru Yellowstone and many other places on the way home. The week of last Thanksgiving, I took my gps with me in a rental car from NJ down to Norfolk and over to Roanoake, then back thru PA and back to NJ and up to Boston. I would have been a lot more frustrated in the cities with just maps. I'll be in Seattle next week. Current software is important to me.
    • Conditions for Meeting a Cold Start   The ignition voltage is between 10 and 15 V. The barometric pressure (BARO) is more than 75 kPa. The engine coolant temperature (ECT) at start-up is less than 42°C (108°F). The intake air temperature (IAT) is between 2–32°C (36–90°F). The engine is OFF for greater than 6 hours or the following conditions must be met: The start-up IAT minus start-up ECT are within 12°C (22°F). The start-up ECT minus start-up IAT are within 50°C (90°F). Fuel level is between 25 and 75 %.   Circuit/System Verification Verify that all I/M System Status indicators report YES, and that no I/M Test DTCs are present.If any I/M Test DTCs are set Refer to Diagnostic Trouble Code (DTC) List - Vehicle. If no I/M Test DTCs are set All OK. Inspection/Maintenance (I/M) System Set Procedure   Warning: Refer to Road Test Warning. Note: Do NOT touch the accelerator pedal until told to do so. A change in TP Sensor angle or an increase in engine speed may invalidate this portion of the test.   Note: An I/M Test DTC will not be stored or erased from the ECU except at the end of trip processing, which occurs 5 s after ignition OFF.   Ensure that the vehicle meets the conditions for a cold start listed above. If the EVAP I/M System Status indicator displays NO, perform the EVAP Service bay test if applicable. Turn OFF all of the accessories; HVAC system, other electrical loads, including aftermarket/add-on equipment, etc., and open the hood.   Set the vehicle parking brake and ensure the vehicle is in park for automatic transmission or neutral for manual transmission.   Start and idle the engine for 2 min.   Close the hood, release the parking brake and Accelerate at part throttle to 72–80 km/h (45–50 mph) with this speed maintained until the engine reaches operating temperature, 8–10 min.   Continue operation under these conditions for an additional 6 min.   Accelerate at part throttle to 90 km/h (55 mph) with this speed maintained for 2 min.   Release the accelerator pedal for at least 10 s. This will allow the vehicle to enter the decel fuel cut off.   Safely stop the vehicle, with the engine in drive for automatic or neutral with the clutch pedal depressed and parking brake applied for manual. Allow the vehicle to idle for 2 min.   Shift the vehicle to park for automatic and neutral for manual. Turn OFF the ignition and exit the vehicle. Do NOT disturb the vehicle for 45 min.   Observe the Inspection/Maintenance (I/M) System Status with a scan tool. All of the I/M System Status indicators should display YES.   If the EVAP I/M System Status indicator displays NO, turn OFF the ignition, ensure that the vehicle meets the conditions for a cold start, and repeat steps 6-11 three more times, or until the EVAP I/M System Status indicator transitions to YES. If the indicator continues to display NO, refer to the Inspection/Maintenance (I/M) System DTC Table to identify the DTCs that did not run.   If any of the I/M System Status indicators display NO, refer to the Inspection/Maintenance (I/M) System DTC Table for the indicator which did not display YES. The I/M System DTC Table identifies the DTCs associated with each I/M System Status Indicator.   Observe the I/M Test DTC information with a scan tool. Verify there are no I/M Test DTCs present. If an I/M Test DTC is set, diagnose the DTC using the Diagnostic Trouble Code (DTC) List - Vehicle and refer to Inspection/Maintenance System Check.   Observe the engine DTC information with a scan tool. Verify no DTCs are present. If a DTC is set, diagnose using the Diagnostic Trouble Code (DTC) List - Vehicle. After repairs, perform the Inspection/Maintenance Complete System Set Procedure to verify no further DTCs are set.       Looks like one procedure to me.  Repeated as necessary.
    • My 2020 AT4 6.2 has had the valve spring issue addressed at ~200 miles, front cover/pump replaced at 18k, water pump at 34k and idler pully at 65k.  I would agree with ditching by 100k unless you elect to go with upgraded hardware...say built 10l80 and an lt4 or l8p swap.
    • I also need one of your modules for my 1993 chevy c2500 7.4 Thanks! My email is [email protected]
    • Chevy needs to do a black regular cab short box SS model with the new 6.6L.  400SS.
    • You might find the drive cycle you need somewhere on charm.li (website), otherwise I suggest a subscription to alldata.com to get them for your truck.
