How-To: GMT900 Cargo Light Mod.
  • Replies 64
Did anyone find out if the GM-style switches or a rocker-style switch that matches could be purchased for this? I'd like to use the blank spot next to my adj. pedals/rear park assist switches......I suppose I could just cut a hole on the left side of the panel too...
JP
JP
Yea Id like to do this mod too, but would also like to use the factory switch so nothing looks out of place. This is a great mod!
You'll need to check an electrical diagram to see if any switch in that cluster would be suitable for this application.
Techs?
Techs?
Yeah, and I mean a switch that will mount and look stock, not necessarily re-purposing one I already have. I would like to add a rocker in the middle of the dash by the pedal adj. and the rear sonar turn off buttons in the leftover blank spots I have....those blanks only remind me of all the cool stuff I'm missing. :P
Parts guys?
JP
Techs?
Yeah, and I mean a switch that will mount and look stock, not necessarily re-purposing one I already have. I would like to add a rocker in the middle of the dash by the pedal adj. and the rear sonar turn off buttons in the leftover blank spots I have....those blanks only remind me of all the cool stuff I'm missing. :lol:
Parts guys?
JP
Ah I don't mind not having that stuff. Id rather just use those slots for buttons of things I will acctually use.
  • 2 months later...
I have a 2011 and you can turn on the cargo light without the dome light. There is a switch that turns off the dome light and leaves the cargo light on.
  • 4 months later...
OH YEAH! I forgot about that lol!
My 2011 makes everything come on even with the dome override pushed in. Weird.
I installed the LED lights into my cargo light and oh my gosh are they a thousand time better! I also did interior lights at the same time and they look great too. I can't understand why people like Putco sell interior light kits for 150 plus when the bulbs are actually very cheap. I will post pics when it gets dark again.....
dlewis1111,
Would you be so kind to list the p/n's needed to do the interior, cargo, and back-up bulbs from that site that you ordered yours from?
Thanks,
-John
dlewis1111,
Thanks,
-John
John,
I got all mine from here
http://www.gorecon.com/index.php
They have a complete set for the domes, there part number is 264162.. they are 10mmx31mm 212-2 bulbs. The cargo lights and third brake lights are 921.Make sure when you get the 921 bulbs that the LEDs are on the sides of the bulb and not just the tip.
you want this style
NOT this style
2011 guys- what are you doing to allow the cargo lamp to come on without interior lights? I have the dome override button and that will turn off the domes for when doors are open or when you unlock the truck but if I turn the dimmer knob all the way to turn on the cargo lamp the domes come on too, no matter what position the override is in. I'd like to be able to use the cargo light without having to do any of this wiring stuff- I'm totally blown away that GM ditched the cargo lamp button my 03 had.
  • 2 months later...
Bringing this back from the dead.
Like asked above, I'm assuming this switch disallows the cargo lights from coming on when you unlock the doors, correct? There should be a way to wire a switch without cutting the wire from the BCM to the junction box, retaining the normal cargo light function.
    • I am sorry if this was misleading. That was a document attached to our most recent work order number (Doc# 7105804) that summarized all the current updates. These programs were ‘redone’ in the past but these versions dated 4/1/2016 were the ones that actually made all of the problems disappear. These programs were relayed to the dealer from the technical services group at GM. Here is the exact wording on the last work order:   “Front view camera reprogramming with SPS. A new version of FCM software was released to the service dept. In addition to providing general robustness and stability enhancements, this update includes all enhancements from previous software version releases. SPS camera and calibrate camera. OLH to perform extended camera relearn procedure after camera calibration. Would not take with first GDS learn. Front camera SPS – BDYZ333157450 GDS2 – camera road calibration performed 2810835 Front view camera reprogramming with SPS LT 0.6 OLH – extended camera relearn procedure OLH LT 1.5”   I got the truck back on 4/8 – since that time it has been great no problems whatsoever. The lane keep assist, active cruise control and AEB all work very well around town and at highway speeds up to 80mph. During this time I had been away for a week and purposely let the battery sit without a batter tender. Even with the battery a bit lower there were no problems exhibited. I really think this one has it fixed after dealing with these issues over a couple of years. These new programs and relearn process when completed seem to make all the parts (and newer replacement parts) ‘talk’ to each other without any glitches. Hope this helps
    • I turned 72 today. My day began with a trip to the pharmacy to pickup meds for me and the dog and then a stop at my chiropractor before heading home. Once home I started the job of replacing the rear brake pads and one rotor on our 2018 Silverado which will probably end up taking me 3 days to finish, gotta pace myself you know. Sometimes I question myself on why I still do most of my own repairs but if I wasn't then it's more than likely I would be sitting in front of the TV all day. It seems like the list of things I need to do gets longer no matter what I accomplish. I'm not complaining but being retired was so much easier when I was 62.   Peace
    • google "bathub failure curve". Basically, any part of the vehicle can fail at any time.  It starts off as being more likely (early failure), then the failure rate goes down (but does not go to zero), then it goes up over time because it wears/ages out.
    • I went from every other day to about once in five since the rain abated. I'm not unhappy about that. Took most of the month for the ditches to dry enough to mow.
    • Good for you and her!   Lots of brushing and grooming to be done
